a'pexi S-AFC helps u pass smog test???
my friend with a GSR said he passed the smog test with V-AFC. he tuned down the fuel ratio etc... u think the max can do it with S-AFC?
If he was running super rich then leaning it out would make less fuel go through. So I guess theoretically, yes :)
But on our cars the ecu resets if you set the high to anything lower then 50% I believe. I dunno if during a inspection they give that much throttle? |
Wow!! Never really considered that. That's all the more reason to get an S-Afc
anybody else thinks it's possible?
since in my state, NC, the state inspections are done through the OBDII system and don't even do a sniffer test anymore, i don't think that it could help in my case
mike |
It might. But if you car is na and you can't pass smog, then there's something seriously wrong with your car to start with. The safc would just be a bandaid fix. Not the real way to good emissions or real hp.
In some cases when we get a car with too many miles, that was poorly maintained ans has alot of carbon buildup, it is harder to get it too pass. If you fail by just s little bit, even an oil change and coolant flush alone could easily help you pass. Today we mad a 92 Ford truck pass but doing a oilchange and retarding the timing 6 degrees, then after it passed returned it back to normal :nervous: :D Messing with the timing that much isnt a good idea for the max. :sprint: for what Jeff said, but sometimes you gotta do it.
| All times are GMT -7. The time now is 06:43 PM. |
