how many of u w/ modded max's drive w/ the 'check engine' lite on?
Old Feb 1, 2001 | 02:29 PM
kafene's Avatar
i do, but i was wondering how many others have the light on also. not talking about stock max's now, cause if it is, then there's probably a good chance something is actually wrong 8)
Old Feb 1, 2001 | 02:41 PM
Shingles's Avatar
The missing moderator
do you know exactly what the code is? What I mean is, are you only assuming that the lights on because of a mod and that it really doesn't matter, or have you checked into it and KNOW it doesn't matter?
With CAI and y-pipe, I don't have any check engine lights.
-Shing
Old Feb 1, 2001 | 02:54 PM
emax02's Avatar
Yep, you should not have a check engine light on,
even if you have all the mods since none of them will set it off,most likely you have a bad o2 sensor some were,just run a diagnostic and see what you come up with and fix it.
Old Feb 1, 2001 | 03:17 PM
plrod Black 95 SE's Avatar
Get this
I had the light on about 2 months ago before I did any mods. It had been on for about 2 years as I had ignored it after the dealer had reset it twice after I got the recall notice regarding this light being on w/o any other symptons. Last month, after installing my intake and mandrel bent tubing from the resonator back and a new muffler, I diagnosed the trouble lite and came up with error code 35 stored in the ECU; I reset the light and after about a month of driving the light has not come back on. Error code 35 points to an EGR temperature sensor malfunction, but since the light hasn't come back on I'm not going to look into it further. The car has always performed well and I haven't noticed a change in gas mileage so let it be.
This is kinda off topic but IMHO: Both of the Nissan dealers' service departments that I've been to in my area SUCK big time; I've found them to suggest repairs that were not even needed. In my mind, this is the biggest problem Nissan has. I will probably not buy Nissan next time because of it and I do like their products. I bring this up because of a thread I read today from some poor person who sounds like they were about to get taken for a ride with suspect repairs.
Old Feb 1, 2001 | 03:22 PM
kafene's Avatar
yeah, i know what it is.
-Shing
the first time it came on, i had my tech at the dealer check it out. it read it was the exhaust. then he looked under my car and said there's no precat. he said that would set it off. the 2k's have problems w/ the precat and they already had notified nissan. they had two other cars before mine that had to have it replaced (stock max's). he said it would eventually turn off, but it would take a while. surely enough it did go off, but when i put in my Stillen intake, it came right back on, turned off, now it's back on after it rained and got really cold.
Old Feb 1, 2001 | 04:12 PM
DOM's Avatar
DOM
After I had my California Y pipe put on my light has been on. It stays for a month, goes away and then comes back after two weeks. Then my won't rev past 2500rpm.
Man, I love my car!!
maxinout93
Oct 27, 2015 01:29 PM
beboski
Aug 16, 2015 05:23 PM
Team STILLEN
Aug 10, 2015 04:29 PM
