How do you remove a window mount cell phone antenna?
I have an old one mounted to the rear glass of the car. It's broken, adn I dont use it. Is there a way to remove it, or is it glued with a special glue and it wont come off without risking breaking the window? Its just bugging me....
One good side shot with a hammer should knock it loose.
Disclaimer: I am not to be held responsible for any breakage of glass which may be directly associated to the actions mentioned in this post.
Originally posted by Albertt
Isn't there a wire leading into the car?
I installed cell phones, all you have to do is scrape off the inside and outside mounts with a putty knife. Then scrape off the old adhesive with a razor blade. As for the wire, you can cut it, stuff it, of remove it entirely. If the inside mount is on the defroaster wires be careful.
The Frye
09-02-2021 11:03 AM
03-12-2020 12:06 AM
ef9
09-05-2015 11:18 PM
