Who all is running copper NGK's for NA use?
Please sign in.
I'm thinking about going copper my next go round. Which part number are you using? |
:sprint:
I'm using the regular NGKs that are meant for the VG. change 'em about once a year and they're great. screw that $9 per plug, I'm going $9 per set! Dunno if they'll work on the VQ, but I'm happy with them in my VE. |
same as matt here....
I did when I was NA. BKR5E IIRC.
Cheap Asses
Why pay 6x as much for something when you're going to change them every year anyway?
Cheap Asses
1234567890 |
Originally Posted by Stephen Max
If I was NA I would. (I'm boosted and I do.) It's so easy to change the plugs on a Maxima, I don't know why any self respecting car guy would pay for the plats just so he didn't have to change the plugs as often.
I'm running the NGK coppers and I've run my PB with them. I forget the part number, but just tell the guy you want 6 NGK coppers for your 95 Nissan Altima because the coppers won't be listed for the 95+ Maxima.
Dave |
I am. BKR5E-11
No discernable performance difference over the plats. Got em for less than $2 each from Advance Auto Parts. |
Dave FYI you don't need the "-11" part of the part number. That just means they're pre-gapped. If you just get BRK5E's you can gap them yourself. I always re-check and/or re-gap all my plugs anyways. I change my coppers now about every 10k, or whenever they're out (for compression test, etc). Its just to cheap to pass up. |
I was running plats, then i had to switch since i started spraying. Now im running 1-step colder plugs which slightly hinders N/A performance...
Eric |
:wavey: :wavey:
I run copper NGKs in mine too. they're great. forgot the part number though.
Platinum plugs are a waste. 60k miles for $8 or 30k miles for $2. Copper is a superior conductor to platinum anyhow though you won't see any performance difference.
I thought the point of fewer plug changes was because the aluminum of the VQ block was more prone to damage from constant threading. I read that somewhere.
Eric yea i was planning to spray, but not anymore :( so i'm goin back to platinum tip pretty soon... |
Just don't overtighten. All it takes is about 2/3 to 3/4 of a turn past finger tight to crush the washer.
Originally Posted by IwANnAMaX96
Is this with or without anti-seize?
http://www.vqpower.com/v2/modules.ph...howpage&pid=33
Nissan Part # for these plugs are 22401 - 50Y05 |
And use some anti-seize on the plug threads.
I am running copper NGKs.
Originally Posted by deezo
To do the job right, get a torque wrench. You won't go wrong and won't have to worry about overtightening.
I'm not personally worried about it. It's just something I've read. |
I've run nothing but copper plugs in my maximas..
Next time around I will be going NGK copper. |
I pull em, check em, Make sure they're all good and the car is running right and slap em back in. |
i will go copper next go around but i'm worried about gapping. How hard is it to gap?
:sprint:
Haven't sprayed in some time now, however I still run the NGK coppers. |
If the NGK V-Power copper core plugs for the Maxima are similar to the ones I used in my old Mazda, you won't need to gap the plugs at all. Gapping is easy as hell though; buy a wire plug gap gauge (for cheap at Advance Auto or Autozone, they may even have them up at the cashier counter in a stack) and try to stick the proper size wire loop (.044") through the plug gap... if it's too tight, open it up, if it's too loose, close it down a little... they have a little notched tool on the gauge for bending the ground electrode (setting the gap involves merely bending the ground electrode to widen/shorten the gap).
I got about 45,000 miles on my ride and am going to change my spark plugs soon is there a write-up on how to change these I haven't had to change them yet and the rears look like a PITA. Would you reccommend the copper plugs for NA use. or what would the best ones be for my car with my mods.
NGK coppers for me.
BKR5E-11's on my VE with 166k.
Runs great. |
I am
love it! |
I am as well. Probably time to change them. Although, I have no clue how to :(
Originally Posted by happyricefob
:sprint:
yea i was planning to spray, but not anymore :( so i'm goin back to platinum tip pretty soon... I still wouldnt go back to plats simply because their so damn expensive. Also, coppers a better conducter as previously stated. And slightly OT, but why arent you gonna spray anymore? Eric |
I think I'm going to put coppers in my Dads 2000SE today. Has NGK plat's in there now.
| All times are GMT -7. The time now is 06:57 PM. |
