Nismo Heads for VQ30 and VQ35!!?!?!
Interesting stuff:
http://www.my350z.com/forum/showthre...threadid=67977 http://www.performancenissanparts.co...roducts_id=311 can't find the other thread on the 350z forums but i'll summarize. Apparently you can fit this on to either engine, however on the vq35 since the upper combustion chamber size is smaller it will raise the compression above 12:1. The valve openings are larger and thus you need to use valves from a VK45 (infinity Q45) motor. Also there is room to accomadate higher lift cams, and i think it will work with the nismo cams. Any of you ballsier VQ30 or VQ35 guys who have run out of mods to spend money on can try this. Supposedly they flow MUCH better than stock heads and coupled with the right cams can probably make some serious power. thoughts? |
BTW performance nissan tried to install these and botched it by installing the cams 180 degrees off. they decided to go back to their original set up so that they could still participate in this season's racing with their 350z. I believe they will try again soon. It's going to be quite a bit of tinkering. Maybe Matt or Matt or Matt or Matt would be willing to give it a go ;)
any smart people know a. if these fit a 3.0 and b. what they'd do to it?
I think they'd fit...but...I can't justify spending $2500+ for something that's not going to increase power very much, or require me to run higher octane fuel because of raised compression, etc.
For that money I'd rather save towards FI. EDIT: And for that matter, far more than $2500 because you still have plenty of other parts to purchase to make it work, and I'll bet those cams are expensive. |
For that money I'd rather save towards FI. EDIT: And for that matter, far more than $2500 because you still have plenty of other parts to purchase to make it work, and I'll bet those cams are expensive. I never said it was for the faint of heart or small of wallet :) |
after i get my 2000 dollar extended warantee back i might do something stupid like this. ahhahaha :wall:
Originally Posted by Chinkzilla
Interesting stuff:
No thanks. Im far too cheap to spend money on parts when I can essentially take my stock crap and make them do the same things. :D
© 2024 MH Sub I, LLC dba Internet Brands
