Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   General Maxima Discussion (https://maxima.org/forums/general-maxima-discussion-1/)
-   -   which maxima's are rod shifter and which>> (https://maxima.org/forums/general-maxima-discussion/223480-maximas-rod-shifter.html)
DAREN Apr 18, 2004 09:34 AM
are cable shifted
DAVE Sz Apr 18, 2004 10:52 AM
??? The 2k2s and up are drive-by-wire I believe and the others are rod shifted. I'm not sure if the drive by wire is for the shifter but I know tghe throttle is DBW.
pocketrocket Apr 18, 2004 03:10 PM
I'm going to take a guess that you're referring to the shifter that shifts gears, right?
With our lovely front wheel drive setup, the shifter device is nowhere close to the transmission, hence it's hooked up by cables. The transmission isn't even near the shifter. The throw and feel is simulated.
Unless you have a RWD or AWD (with RWD bias), you won't be rod shifted because the transmission is not under the shifter.
mzmtg Apr 18, 2004 03:37 PM
This is exactly what Jime was talking about when he complained about rampant mis-information on the ORG :squint:
Not only is your logic flawed, your facts are wrong.
To answer the original question: All the 5-speed cars are rod shifted, all the 6-speed cars are cable shifted.
pocketrocket Apr 18, 2004 03:43 PM
Sorry
I am referring to the automatic setup, since that's what I have.
If my terminology is wrong, my apologies. :wall:
