AC water leak, water under carpet, HELP!
I have found water under my driver side carpet. I believe it is from the AC condensation resivior over flowing due to a cloged drain hose.
I can see the drain spout from under the car bet I cant shove any thing into it to un clog it. Does any one know how to access the condinsation resivior area from the inside of the car so I can get the crud out of it and unclog the drain hose?
Thanks!
Thanks!
You don't have to rotorouter it -- just blowing a little bit of air will usually do the trick. If you can't get to the end of the outside hose, disconnected it from the inside, but have a cup handy to catch the water. Using a bulb (i.e., ear bulb or turkey baster) skirt some air into the drain and the water should drain.
