I don't know if anyone else has noticed this but I have. We are all familiar with what engine's make what power/torque. One thing I find strange is that the 4th gen VQ makes at the wheels what a VG30E (Z31, 2nd-3rd gen maximas) does at the crank. After looking at some 5th gen dynos it appears the 5spd makes the same power at the wheels as the 4th gen does at the crank. I have only seen one auto 4th gen put down over 170hp to the wheels without FI or NOS. However I have seen several 4th gen 5spds put down around 180-186hp at the wheels. Too bad no one wants to experiment with cams other wise I'm sure you can pick up an extra 10hp in the toppend. Hell if my VG with heads and cams could pull to the rev limiter in 3rd gear, surely a VQ with cams should pull to the limiter or close to it in 5th or gain around 500rpm extra in 4th gear?
I hope 5th gens put down more power than 4th gens...
It would kinda make since since they make more power at the crank, too. Could be I'm misunderstanding you, but since a 5th gen makes more crank power than a 4th gen, it's pretty obvious that it'd make more power at the wheels, too.
Re: I hope 5th gens put down more power than 4th gens...
Originally posted by Black VQ It would kinda make since since they make more power at the crank, too. Could be I'm misunderstanding you, but since a 5th gen makes more crank power than a 4th gen, it's pretty obvious that it'd make more power at the wheels, too. No what he is saying is that the 4th gen makes the same amount of power to the wheel as the 3rd gen at the crank. And the 5th gen puts down the power rating of the 4th gen at the crank(190). I think... hehe. -Shing |
Tougher emissions
Is part of the reason.
Re: Re: I hope 5th gens put down more power than 4th gens...
Originally posted by Shingles Originally posted by Black VQ It would kinda make since since they make more power at the crank, too. Could be I'm misunderstanding you, but since a 5th gen makes more crank power than a 4th gen, it's pretty obvious that it'd make more power at the wheels, too. No what he is saying is that the 4th gen makes the same amount of power to the wheel as the 3rd gen at the crank. And the 5th gen puts down the power rating of the 4th gen at the crank(190). I think... hehe. -Shing |
Re: Re: Re: I hope 5th gens put down more power than 4th gens...
Originally posted by Nismo87SE Originally posted by Shingles Originally posted by Black VQ It would kinda make since since they make more power at the crank, too. Could be I'm misunderstanding you, but since a 5th gen makes more crank power than a 4th gen, it's pretty obvious that it'd make more power at the wheels, too. No what he is saying is that the 4th gen makes the same amount of power to the wheel as the 3rd gen at the crank. And the 5th gen puts down the power rating of the 4th gen at the crank(190). I think... hehe. -Shing -Shing |
Isn't the VE...
A SOHC powerplant? In my dad's '89 SE it is. That would explain the diff right there. Nissan also no doubt learned some new tricks with the VQ as well so that they could be competitive in the German DTM series it was originally designed for.
VE = DOHC 4-valve w/ cam advance n/m
Originally posted by Black VQ A SOHC powerplant? In my dad's '89 SE it is. That would explain the diff right there. Nissan also no doubt learned some new tricks with the VQ as well so that they could be competitive in the German DTM series it was originally designed for. |
Peak numbers mean nothing...
The VQ makes strong torque from 1800-4800 rpms and slowly falls off by 5200 and then drops like a brick. Hp climbs at a very linear pace. Put simply, the VQ is not a peaky engine. It pulls well from all rpms.
Dave |
| All times are GMT -7. The time now is 12:39 AM. |
