Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   General Maxima Discussion (https://maxima.org/forums/general-maxima-discussion-1/)
-   -   What's the optimum launch RPM for 4th gen? (https://maxima.org/forums/general-maxima-discussion/36304-whats-optimum-launch-rpm-4th-gen.html)
Chebosto Jun 23, 2001 12:31 AM
:) going drag racin' tomorrow before i get the SC in, to see what times im getting.
prolyl gonna run full interior and what not. i dont really car for the quarter mi, but i just wanted to have a "well rounded" maxima. hehe. :)
Confused Jun 23, 2001 07:10 AM
All depends on traction
if you can launch at 4k your there,,,, you might want to start at 2k and work your way up.
MardiGrasMax Jun 23, 2001 08:04 AM
Re: All depends on traction
Yep, 3k with a tiny clutch slip and mild throttle manipulation worked great for me, 2.1 60's on street tires.
Sprint Jun 23, 2001 08:06 AM
4k here with 2.1 and 2.0 60fts
Synki Jun 23, 2001 09:00 AM
You guys do know he's auto right? Unless you have a high stall tq converter. For dragging, i usually launch anywhere from 1.7k - 2k rpms depending on traction.
Dave B Jun 23, 2001 10:14 AM
Cheston with an Auto? I think not.
To get the best et, you must be coming off the line above 3500rpms which means you need to wind it up to 4K. Quickly slip the clutch and feed it gas slowly until you feel it hook up and then go WOT. What wheels you gonna run?
I'm excited that you're going to the track to test out the ECU. Is Nabil going? Even if your ets are a bit slow, the trap speed should be a very good indicator of potential et with a good 60'. Good luck.
I'd shift at these rpms as indicated by the tach:
1-2 6500
2-3 6200
3-4 6000
Dave
Sprint Jun 23, 2001 10:48 AM
Cheston and _DRU_ have the fastest Max's every built *sheesh* its nissan's untold secret.. the 97 5spd GXE :D
theblue Jun 23, 2001 11:07 AM
on wednesday, I was launching between 2000 and 2500 and poping the clutch, letting off the gas for just a moment to grab traction then flooring it. Tire pressure is critical to a good launch. I got a 2.191 on street tires doing this.
