Rear Windows and Locks Don't Work
Old Jun 8, 2007 | 02:28 AM
SpeedCrazie's Avatar
So I am out of ideas and am getting ready to head to the dealership to figure out this problem.
Hopefully there are some members that can help me with this problem.
My rear windows and locks do not work.
-The rear relays do not click when using the switches.
- None of the rear window switches work.
- Front main switch does not control the rear windows or locks but does control the front windows and locks.
I have tried replacing one the rear switches and that had no effect. I also tries replacing the main switch on the drivers side and that did not work.
Could this be related to the BCM? Since the relays are clicking in back is there something I should check?
Thanks for the help!
JP
Old Jun 8, 2007 | 02:40 AM
MorpheusZero's Avatar
So wait, do the relays click or not?
Old Jun 8, 2007 | 02:44 AM
You can here the clicking of the relays when you roll down the front windows but when trying to roll down the rear windows they do not click.
Old Jun 8, 2007 | 03:16 AM
Well, it sounds like the controls to the rear doors have been completely cut off. Check any connections that would lead to the rear, seems like a harness is unplugged or something. And be happy it didn't happen when your windows were down.
Old Jun 10, 2007 | 06:30 PM
Bump Bump.....
Old Jun 10, 2007 | 08:31 PM
naijai's Avatar
look at your fuse the one marker elec parts top right hand corner
Old Jul 28, 2007 | 01:43 AM
Problem solved, Figured I would update this:
I guess that the 95 and 97 have diffrent rear switches. When I swapped my rear leather door panels from my 95 into my 97 I left the switches intact.
I was running out of ideas so I decided to swap panels agian and sure enough they work.
Old Aug 5, 2007 | 03:14 AM
Maximas's Avatar
2DA MAXX
That is exactly the same thing that is happening to me; my rear door locks and windows don't work. I even tried to replace it with infiniti switches and it makes this electric buzz sound when I try to connect them.
I'll try to find switches from the same year and see if that solves my problem.
Huttig2009
Sep 25, 2015 03:31 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
kenc15
Aug 5, 2015 08:29 AM
kjm900r
Aug 5, 2015 07:14 AM
