What's the front camber suppose to be on a 4th gen?
Old Oct 29, 2001 | 08:17 AM
Dave B's Avatar
Not DAVEB the parts guy
I got my car aligned after installing my Intrax springs and the machine said my front camber was -0.9 and -1.0 degrees. Do I need camber bolts? My car tracks straight, but it will pull anytime I'm on a graded roadway that either slopes in or away which leads me to believe I have a camber problem. The steering also feels looser than normal.
Dave
Old Oct 29, 2001 | 08:25 AM
njmaxseltd's Avatar
Camber, in degrees.
-1.00 Minimum
-0.25 Nominal
+0.50 Maximum
+0.75 Maximum left and right difference
Old Oct 29, 2001 | 08:31 AM
Bags's Avatar
VG Ridah's Biatch Hoe
Re: What's the front camber suppose to be on a 4th gen?
Dave
here is what nissan says camber should be
minimum -1.00 degrees
nominal -0.25 degrees
maximum +0.50 degrees
left and right difference +0.75 degress or less
your right on the edge of it. your l/r are not close enough, unless it was like -0.934 or something. i think you do need camber bolts, unless one of your suspension compents is either loose or damaged
Old Oct 29, 2001 | 09:18 AM
96sleeper's Avatar
what about mine?
B&G aren't supposed to be as low as intrax, but my camber was -1.0 and -1.1 on the front. I was told that my car was pulling because of the toe, and that camber didn't affect pull that much.?.
Old Oct 29, 2001 | 09:29 AM
bill99gxe's Avatar
Evil Administrator - "The Problem"
Dave
Could've been answered without the wasted bandwidth:
http://forums.maxima.org/showthread....2&pagenumber=2
stevesmax
Dec 17, 2020 11:57 AM
Finkle
Sep 27, 2015 09:53 PM
95Maxi
Aug 25, 2015 08:01 PM
FlaMark
Aug 20, 2015 12:17 PM
ViciousVQ30
Aug 5, 2015 05:40 PM
