VQ35 DeLorean!!
Not a Maxima, but it's got a VQ35, and, well, it's a freakin DeLorean. Figured I'd share.
http://cache.gawkerassets.com/assets...x_whatisit.jpg |
Do you have any more pictures?? That is by far the coolest thing I've seen all day! Finally a reliable and relatively fast Delorean! I'd roll that in a heartbeat!
Needs more LSx
Yes more pics please...
(Post 8529340)
Needs more LSx
Is that a Kinetix I spy?
Couldn't find anymore pictures, but I found a couple videos of it. Apparently, it's supercharged, and uses a Porsche 915 transmission.
Q
(Post 8529380)
:puppet:
Nice..:D
Originally Posted by dfj240
(Post 8529504)
(Post 8529520)
LSx>VQ35
He's a member here. User name is MarcL.
http://forums.maxima.org/all-motor/3...org-tilly.html |
(Post 8529340)
Needs more LSx
1 Attachment(s)
(Post 8529538)
Not in this case. Too much weight and that engine bay is already as cramped as it is.
LSx on the left, VQ35 on the right Attachment 46156 VQ35--- ~330lbs LS1--- ~380lbs Not a huge weight difference there. Youre argument would be more valid if there was a 300lb difference. |
Blew up the engine earlier this year. I have been shopping for a new one, but not having much luck. Junkyard engines are either too expensive, or mileage is high.. And none of the "speed shops" return my emails when asking about buying a rebuild. I have a lot invested in the VQ setup, but I sometimes wonder if sticking with it is putting in more good after bad..
Also, the LS1 conversion has already been done.. Guy did it as a school project. I have seen it in person, very nice job on it. |
nice car id stick with the vq3.5 just cause im biased lol but also cause its a good engine :D
VQ is a good engine? I have 4 large boat anchors in my garage that say otherwise.
I am not against sticking with the VQ, if I could find one!! or, a decent speed shop that will return my emails. |
Originally Posted by MarcL
(Post 8620609)
(Post 8620609)
(Post 8620609)
(Post 8622124)
What are you going to go with?
(Post 8622350)
What happened to those 4 engines?
2nd one lost oil pressure 3rd one was DOA, had no oil pressure 4th one was DOA, had no compression in 2 cylinders. Engine #2 and #4 have been scrapped already. Engine 1 and 3 are still in the shop, I tried to sell #3 for parts to try and recoup some money, but no one was interested. I may use #1 as a core, if I decide to do a rebuild.
Originally Posted by Quickywd01
(Post 8622399)
Why not a VQ30?
If I am going to rebuild it myself, I might as well use the VQ35 I already own. I got a recent inquiry from a magazine to do an article on my car, so I need to make a decision and move on it soon.. |
o wow im suprised and i feel bad you went through sooo many engines honestly i am very suprised by this
(Post 8529538)
Transaxle options are limited though I have worked with both engines as you can see from my sig and every idiot on the net likes to say the ls1 ruins the weight balance of my RX7. The entire engine is aluminum alloy with a plastic composite intake... its light |
Originally Posted by sciff5
(Post 8622585)
(Post 8622604)
It's light, but it's not rotary light. A 13B by itself (shortblock) is around 140 pounds. I've picked up and carried a few a short distance a time or two. So i'm going to be one of those idiots on the net and say that you did ruin the weight balance of your RX7 :D But if you're using it for drag racing then it won't really matter much.
Not that the weight of the shortblock matters because shortblocks don't run cars, complete motors do and the ls1 is as light. An ls1 shortblock is right around that 150lb mark as well but more importantly the entire engine assembled is lighter than an equivalent output 13b motor http://www.ponycars.net/rx7.htm (take a look 3/4s of the way down for corner weights against a stock Rx7) Weights would be even more in the LS1's favor if you added a larger turbo/intercooler ect. So for similar power output... yes the LS1 is just as light, its just the big t56 that adds the extra 50 lbs and its in the bottom, middle of the car. If you really wanted to be anal you could replace the t56 with something lighter and not gain any weight from the conversion. There's nothing good in practice about the rotary engine. We already created a high output high revving engine that runs like **** and burns oil years ago and it too has been phased out. It's called a 2 stroke. |
(Post 8622476)
Reality is, I will probably end up with another VQ. The cost to do another conversion to an alternative engine would be too much money and effort.
1st one started blowing smoke. Probably a broken ring. 2nd one lost oil pressure 3rd one was DOA, had no oil pressure 4th one was DOA, had no compression in 2 cylinders. Engine #2 and #4 have been scrapped already. Engine 1 and 3 are still in the shop, I tried to sell #3 for parts to try and recoup some money, but no one was interested. I may use #1 as a core, if I decide to do a rebuild. I imagine a VQ30 would be less power, older engine will have higher miles on it. Having a speed shop do a performance rebuild for me does not seem to be in the cards because NONE of them will take me seriously. I have sent a number of builders emails asking for details and prices, and most do not respond. One told me I have to call them (making me wonder why they have an email address, and web site... Why can't I get the information by email?!) If I am going to rebuild it myself, I might as well use the VQ35 I already own. I got a recent inquiry from a magazine to do an article on my car, so I need to make a decision and move on it soon.. So far for my internally stock vq30 I've acquired a variable intake, svt cobra injectors, V1 supercharger, full exhaust, nitrous, closet thing to a standalone that I could find for tuning emanage ultimate, and a few other misc. parts like the walbro 255HP. I still need to work on a water to air intecooler and methanol injection. I could go on for days... Oh btw check out the J&S safeguard, pathfinder cooling upgrade http://vq35.com/blog/2010/07/go-with...ooling-system/ , oil cooling info http://www.modified.com/tech/modp-10...l/viewall.html VQ = poor mans LS :D :wavey: from NJ. |
I am not sure how a VQ30 is better than a VQ35, if you need to do all that work to it anyway. Why not just start with bigger/newer.
(Post 8627127)
Not sure if you are being serious, sarcastic, or just a troll.
Being "practical" is not mutually exclusive to being a "gear head". My goals for this project may not be what you thought. I never was looking to build a "monster". I also don't understand why you are being so hostile because of a simple question. If you have a legitimate reason to state that building a VQ30 is somehow better (practical) than a VQ35, you could have an intelligent, and adult discussion about it. Old man tan is not my problem. I built this car for me, not anyone else. Maybe you have your own equipment to balance engines, but I don't. If that makes me "pay other people to do the work", so be it.. Not practical to buy all those tools just to say I did it myself. You are talking to the person that put a VQ35 in a DeLorean, sorry if you are disappointed, but it was never my goal to impress some random stranger on the internet. |
(Post 8627115)
You can't expect american muscle guys to know about the VQ. No replacement for displacement as they like to say; except technology. You'd be better off having a forum member build or help build your engine. A stock VQ30 can handle a good amount of power but tuning is very important to it's survival. You can turn it into a monster too if you want. I've been planing on doing this at home using some upgraded factory parts along with aftermarket parts; Aftermarket pistons and rods, aftermarket cams, port and polish, nissan gtr vq I mean vr38 titanium valve springs, factory vq high rev oil pump to sustain the revs, and a cheap/junkyard/truck turbo with nitrous to make up for the dead spots. Secondary fuel system consisting of fuel cell in trunk with race gas only used on boost, methanol injection, computer(s) to control all of that, and I'm sure I'm forgetting a thing here and there like a beefier block girdle. Just throwing out ideas. Here's an example of what a stock vq30 can do and this is old: http://www.dynomagic.com/thefast_hlh.htm
So far for my internally stock vq30 I've acquired a variable intake, svt cobra injectors, V1 supercharger, full exhaust, nitrous, closet thing to a standalone that I could find for tuning emanage ultimate, and a few other misc. parts like the walbro 255HP. I still need to work on a water to air intecooler and methanol injection. I could go on for days... Oh btw check out the J&S safeguard, pathfinder cooling upgrade http://vq35.com/blog/2010/07/go-with...ooling-system/ , oil cooling info http://www.modified.com/tech/modp-10...l/viewall.html VQ = poor mans LS :D :wavey: from NJ. What a complete waste of time... you would spend way more than just a standard ls1 getting that running right You can buy a full pullout ls1 for $1500 that puts down 300+ whp stock. If you didn't care about adding around 90lbs you could get a Ls based truck 5.3 for 500$ or less for a complete engine including wiring harness and all accessories and still get 300whp with just exhaust and an ls6 intake ($300) Theres no such thing as a poormans LS. Lsxs are probably the single best platform out there to make cheap power. Stock 5.3L truck motors (the $500 variety found in any parts yard in the country) have pushed cars into the 8s when turbocharged (all with stock parts, including stock exhaust manifolds, other than valvesprings) and made 800+whp One Example, and this car doesn't have the record any more I don't think anything this side of 50k has gone that fast with a vq30 or vq35. Or you could build a super JDM mad tyte vq30 with a v1 blower... your choice |
LOL, a Nissan Motor in a Stainless steel car of the yore, guess back to the future is coming around your corner
BTW I do think the vq35 delorean is pretty cool. It's a good fit for the car unless you want it to go fast, which the deloreans never did...
If you want it to haul *** I would chose a different motor, but for a nice drivers car a vq35 is fine. No reason to go with less displacement in a vq30.. vq35s are pretty cheap as is |
As I said before, the LS1 conversion has been done (it was completed after mine), and although it is a sweet conversion, the person who did it had to make significant modifications for it to fit. The transmission had to be moved forward, and even then the rear fascia of the car was cut to accommodate the front of the engine.
With that said, if I had to do it over again, I may very well go with a different engine. However, I first did the swap in 2005 and all things considered I am proud of what I accomplished and do not need anyone else to approve of it. I knew nothing about the VQ engine before doing this project. I researched a number of engines, and made an informed decision at the time. It may not have been the best, but I will never know "what if". Changing engine platforms now has crossed my mind, but it would be starting from scratch. I have an awful lot of time and money in this project, and it would be a difficult decision to just throw that all away... And then what, 5 years from now when there is some BETTER engine sitting in a junk yard for $1500? I am sure someone will say "you could have" or "you should have". Tell you what, someone wants to sponsor the project, I will put whatever you want in there. This is not some off-the-shelf kit I bought. |
(Post 8627559)
With that said, if I had to do it over again, I may very well go with a different engine. However, I first did the swap in 2005 and all things considered I am proud of what I accomplished and do not need anyone else to approve of it. I knew nothing about the VQ engine before doing this project. I researched a number of engines, and made an informed decision at the time. It may not have been the best, but I will never know "what if". Changing engine platforms now has crossed my mind, but it would be starting from scratch. I have an awful lot of time and money in this project, and it would be a difficult decision to just throw that all away... And then what, 5 years from now when there is some BETTER engine sitting in a junk yard for $1500? I am sure someone will say "you could have" or "you should have". Tell you what, someone wants to sponsor the project, I will put whatever you want in there. This is not some off-the-shelf kit I bought. I'm just correcting the idiots. |
Thank you.
Originally Posted by Galactica
(Post 8529339)
Anything is better than the original engine in a Delorean! A Nissan engine and the Delorean chassis design would be a nice combination!
© 2024 MH Sub I, LLC dba Internet Brands
