Transmission problems after engine swap
About a month and a half ago, I brought my car to a small auto shop owned by my friend's father. I took the car in because the timing chain system was bad. the mechanic suggested that I replace the engine because there were metal shavings in the oil pan. I was quoted for about $1600 for the entire job which included a used engine w/ about 84k miles on it and labor. I felt it was a great deal and agreed for the work to be done. When the work was done, I went to go pick it up and was told by the mechanic to take it for a spin. I drove the car for about 5 minutes then the car started to jerk when I'd accelerate. Finally just a few blocks from the shop, I tried to make a 3 point turn and got stuck because I couldn't put the out the car in gear. I would press the gas and the engine would just rev. Luckily I was near the shop and was able to call them to tow the car back. My question is this. Do you guys think that the transmission was damaged when the engine was replaced and is the mechanic liable for this damage? Mechanic did say that it is possible that something in the tranny was touched or knocked loose in the during the engine work. All I know is that I had no issues with the transmission prior to me bringing it to this shop. I am aware that 2005 Maximas are notorious for having faulty transmissions and timing chain systems. I'm also aware that there is was a class action lawsuit involving this year/make/model. Unfortunately the mechanic is too and seems to not be taking responsibility for this damage. What do you guys think? Did the the mechanic damage the transmission when he removed and installed a new engine? Or was my tranny already messed up and this is all just a case of bad timing??
Make sure the drive shafts are fully inserted into the transmission. Chances are the drivers side is not pushed in. If it won't stay in, check the C clip on the end of the shaft for damage.
Originally Posted by Ike83
(Post 9119741)
did the shop actually do a test drive prior to your arrival? are they going to make an attempt to find out what's exactly wrong with the transmission? the mechanic is not going to do anything. you'll need to talk to the mgr/owner/someone in charge and let them know that your car is officially undriveable. you will not pay for any repairs to the engine until the car drives the way it came in. if the transmission shifted correctly when you bought the car in then it should shift correctly on it's way out. an engine swap doesn't entail making impacts on the transmission or anything unless they dropped the transmission and engine assembly during removal. i assume they added the fluid back in to the transmission...if not then these guys are idiots. |
Originally Posted by JSutter
(Post 9119865)
Originally Posted by DanNY
(Post 9119949)
did you talk to your friend's father who owns the shop and discuss your concerns?
© 2024 MH Sub I, LLC dba Internet Brands
