Hayne's coolant change and drain/fill method
The last time I changed my coolant, I used the drain and refill method. I did it about four times until the water was relatively clear drained out of the radiator.
I check my Haynes manual last night and was wondering about the mixture. They have a different way of doing the flush. Here's how they did it: drain radiator, disconnect top radiator hose, remove thermostat, reconnect thermostat attachment without the thermostat (so it's full open all the time), plug radiator drain, run water using hose to radiator. Susposedly water/coolant will come out of the top hose. You would watch the water coming out until it's clear (of couse have something to catch the coolant). Then you would connect everything back and fill with mixture of coolant and water. What confused me was since all the old stuff is out and only water is in the block, wouldn't you just add pure coolant to the radiator? I did the same when I used the drain/fill flush method; add pure coolant to radiator. Am I doing this wrong? |
i have a question about this also.. does lack of changing your coolant cause any performance degredation?
i mean does your car like lag or run slower when its warmed up? |
Re: Hayne's coolant change and drain/fill method
Huh? The thermostat is connected to the bottom radiator hose on our car. So, the Haynes manual is somewhat suspect in its suggested method. Those manuals tend to generalize alot. Maybe they were referring to a 3rd gen Maxima.
DW Originally posted by JMAX95 The last time I changed my coolant, I used the drain and refill method. I did it about four times until the water was relatively clear drained out of the radiator. I check my Haynes manual last night and was wondering about the mixture. They have a different way of doing the flush. Here's how they did it: drain radiator, disconnect top radiator hose, remove thermostat, reconnect thermostat attachment without the thermostat (so it's full open all the time), plug radiator drain, run water using hose to radiator. Susposedly water/coolant will come out of the top hose. You would watch the water coming out until it's clear (of couse have something to catch the coolant). Then you would connect everything back and fill with mixture of coolant and water. What confused me was since all the old stuff is out and only water is in the block, wouldn't you just add pure coolant to the radiator? I did the same when I used the drain/fill flush method; add pure coolant to radiator. Am I doing this wrong? |
Re: Re: Hayne's coolant change and drain/fill method
They did show pics for both 3rd and 4th gen thermostat location. I can see that it could be a hassle taking it out and putting it back again. I guess if you're changing your hoses and thermostat, Hayne's way is probably easier. With the drain/refill method you don't have to disconnect or remove anything.
For people who did their own flush, did you guys fill with coolant only into radiator or a mixture of it with water? Originally posted by dwapenyi Huh? The thermostat is connected to the bottom radiator hose on our car. So, the Haynes manual is somewhat suspect in its suggested method. Those manuals tend to generalize alot. Maybe they were referring to a 3rd gen Maxima. DW |
Originally posted by SprintMax i have a question about this also.. does lack of changing your coolant cause any performance degredation? i mean does your car like lag or run slower when its warmed up? |
Re: Re: Re: Hayne's coolant change and drain/fill method
Originally posted by JMAX95 For people who did their own flush, did you guys fill with coolant only into radiator or a mixture of it with water? |
Re: Re: Re: Re: Hayne's coolant change and drain/fill method
So basically at anytime you would only have 1/3 coolant in your system, correct?
Originally posted by iwannabmw I used the drain and fill method. When I refilled it for the last time I used a 50/50 mix of distilled water and Zerex antifreeze, which I made before pouring in the radiator. |
Originally posted by SprintMax i have a question about this also.. does lack of changing your coolant cause any performance degredation? i mean does your car like lag or run slower when its warmed up? http://www.bmcno.org/RadCap.htm When I change the coolant, I open the bottom drain on the radiator and put a garden hose in the filler neck with enough flow to make up whats draining. I run the engine with the heater on high for 15-20 minutes to get all of the old coolant out of the block. I don't think that you need to remove the thermostat, it will open when the coolant in the block gets hot. It will take longer to completely flush the system with my method, but with a lot less effort. |
I have always done the open the drain plugs from the radiator, and the 2 engine block points. The front drain plug on the block is pretty easy to get to, but the rear one is kinda hidden. Of course I was fortunate that I had all the stuff under the car out, like Y pipe, splash gaurds and CV axles, but you can do it. Then, I take a garden hose and flush the coolant out completely. I just use Prestone green stuff diluted with distilled water. I hear some people here use Toyota red coolant in their nissan. Its really expensive but I guess it works. Fortunately for us, we have aluminum block and heads, so the rust isnt that much of an issue as an iron block would be.
Originally posted by sinewave Sprint, check this link out, especially the last paragraph. http://www.bmcno.org/RadCap.htm When I change the coolant, I open the bottom drain on the radiator and put a garden hose in the filler neck with enough flow to make up whats draining. I run the engine with the heater on high for 15-20 minutes to get all of the old coolant out of the block. I don't think that you need to remove the thermostat, it will open when the coolant in the block gets hot. It will take longer to completely flush the system with my method, but with a lot less effort. |
Re: Re: Re: Re: Re: Hayne's coolant change and drain/fill method
Originally posted by JMAX95 So basically at anytime you would only have 1/3 coolant in your system, correct? BTW, I've never heard of anyone actually removing the thermostat in a Maxima do flush the system. Way to labor intensive and messy. |
Damn good point about the aluminum block and heads. Didn't think of that. But then, thinking a little further, rust may not be a problem, but corrosion may still be, maybe even more so than in a iron block engine.
And, you actually got to the engine block plugs:eek: Wow. I saw one of them and din't even bother. Waaaay too tight in there. DW Orignally posted by ericdwong I have always done the open the drain plugs from the radiator, and the 2 engine block points. The front drain plug on the block is pretty easy to get to, but the rear one is kinda hidden. Of course I was fortunate that I had all the stuff under the car out, like Y pipe, splash gaurds and CV axles, but you can do it. Then, I take a garden hose and flush the coolant out completely. I just use Prestone green stuff diluted with distilled water. I hear some people here use Toyota red coolant in their nissan. Its really expensive but I guess it works. Fortunately for us, we have aluminum block and heads, so the rust isnt that much of an issue as an iron block would be. |
Originally posted by sinewave When I change the coolant, I open the bottom drain on the radiator and put a garden hose in the filler neck with enough flow to make up whats draining. I run the engine with the heater on high for 15-20 minutes to get all of the old coolant out of the block. To fill I take the coolant capacity and add the Coolant first (50%). Then for the rest I use disstilled water (minus what is left in the block). Lastly I use a 50/50 mix for the resivior. |
| All times are GMT -7. The time now is 02:00 AM. |
