0104 error just went away!?
Old 12-05-2000, 07:42 AM
TexMaximum's Avatar
All by itself after about a week and a half to two weeks after it came on. It was vehicle speed sensor. Dealer said it was the speedo which always has, and still does work fine. The sensor checked out fine also.
Why would the check engine light go away by itself, when I tried everything including resetting the ECU before to turn it off? Will it come right back? replacing the guage for nothing, maybe for the sake of the light would have been $300.
TexMaximum is offline
Old 12-05-2000, 11:17 AM
I'm needing a caw
Jeff92se's Avatar
I believe the ecu will show an error when it happens. Now if the ecu doesn't see another error code for about 50 turns of the ignition key, it will automatically delete the error code. So a few weeks is about right for 50 turns.
Jeff92se is offline
Old 12-05-2000, 05:38 PM
TexMaximum's Avatar
Really jeff? Thats fine by me as everything works. The dealer said it would stay on long as the problem is there though?
mvm062
11-30-2020 09:00 AM
junito1
09-23-2015 12:14 PM
Pnjboyzz
09-21-2015 12:41 PM
Kalrakam
09-16-2015 12:30 PM
Quick Reply: 0104 error just went away!?
