Researching FPR problems, if you have a aftermarket FPR, look...
'Trynna' is not a word
Okay, I'm having problems getting my AEM FPR to regulate pressure properly. Researching a bit on the internet, Ive found some problems with regulators that use a spring design, such as the AEM, maintaining a steady fuel pressure. Does anyone with an adjustable FPR know what regulates their pressure? Do you have a spring inside, or some other design. Thanks in advance, I'm trying to get to the heart of this problem...
Not true, they do work, well most of them do... I was running about 35-36psi with my Walborro, fuel pressure is controlled by vacuum, not by the ECU, the MAF and ECU control injector open time, I just pulled my codes... 0505, no problems... I'm gonna put the stock one back on and see if anything changes, and then order a SARD from Thomas...
Originally posted by Dave B
As far as I know, adjustable FPR don't work with the VQs. Lots of guys have tried and failed. The fuel system will compensate and bring fuel pressure within factory settings.
Dave
Dave
Ive had it since September, so I doubt I'll be able to get anything for it. If your not gonna use your SARD, wanna sell it?
Originally posted by Chunger
Hopefully you can get reimbursed for the AEM?
Fuel pressure is not regulated by ECU at all. Yes, the ECU can change injector pulses, but fuel pressure is totally controlled by mechanical FPR.
Dave
Dave
Dave
Okay. But either way, it doesn't work on the stock system. Correct? It's the same way with the F-Bodies. Lot of guys tried the adjustable FPRs and the ECU turned out to be smarter. What's the point of an abjustable FPR without forced induction?
Dave
Dave
I don't see why not. At WOT, ECU uses a preset air/fuel map. The ECU assumes that the fuel pressure will be at 43psi and makes the injectors pulse X amount. Now you increase the fuel pressure by 5 psi. The same exact injector pulse now yields more fuel. The ECU has no sensor to monitor fuel pressure.
Dave
Dave
Because with a 255lph fuel pump, stock fuel pressure is raised 2-3psi at all ranges...
Dave
Dave
catalinvint
09-16-2015 07:48 PM
