Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   Group Deals / Sponsors Forum (https://maxima.org/forums/group-deals-sponsors-forum-17/)
-   -   KOP HID's (https://maxima.org/forums/group-deals-sponsors-forum/125629-kop-hids.html)
juice Nov 29, 2002 07:18 PM
KOP HID's
A friend of mine has become a distributor for KOP HID Lighting Technologies. All there products are top of the line and are manufactured from German parts. The are made of the same material as the Phillips HID lighting systems. All products come with a manufactures warranty. Also as a note the higher color temperature bulbs are not the tinted glass like some of the other manufacturers are using. The colors are achieved by using precise gas mixtures. Products available right now
Pics to bulb comparisons
For the 2K2 and up models who want to change just the bulbs.
-6000K D2R - Violet $200 a pair
-7000K D2R - Light Blue $200 a pair
-8000K D2R - Blue $220 a pair
Shipping is $7
These bulbs are a direct replacement for the OEM bulbs
Currently only H3 kits are available. Kits include all necessary hardware including bulbs, ignitors, starters and ballasts. Kits are direct fit into the OEM foglights and tap into the old factory wiring(for on/off)
-6000K - Violet $450
-7000K - Light Blue $450
-8000K - Blue $475
Shipping is $10
9004 and H4 kits will be available in 2-3 weeks and these will be hi/lo beam direct plug-n-play kits. Please e-mail me for all questions and on how to order. Thanks
2M0A0X2 Nov 29, 2002 09:17 PM
do u only have to change the bulb to get more blue of the 6000k?
ThurzNite Nov 30, 2002 12:57 AM
what do you mean by hi/lo beam plug and play? do you mean it uses a diode to keep the hid on when you flick to hi?
Jae
juice Nov 30, 2002 01:27 AM
HID's
Quote:
Jae
2M0A0X2 - If you have a 2k2 or higher, yes all you have to change is the bulbs to get more blue or purple, see link above to pics.
ThurzNite - Actually it uses a relay, and when hi beams are engaged it changes the angle of the bulb to a higher beam pattern.
K Pazzo 6 Dec 2, 2002 06:58 AM
Re: KOP HID's
Shipping is $7
-8000K - Blue $475
Shipping is $10
http://images.cardomain.com/installs...91_38_full.jpg
wow:eek: ...now i gotta save up for these bulbs
funnylittlman Dec 2, 2002 07:04 AM
I'm interested in the low/high hopefully. Price?
juice Dec 2, 2002 10:37 AM
Hi/lo Beam
Quote:
Price depends on the color kit desired the higher color temp (ie 8000k) are more expensive. They run from $450 to $500 per kit
funnylittlman Dec 2, 2002 01:25 PM
Juice,
Just to make sure, the bulb itself doesn't move, but it is similar to a dual filament bulb?
juice Dec 2, 2002 01:46 PM
Hi/Lo Bulbs
Juice,
funnylittlman Dec 3, 2002 05:54 AM
Somethin Funny?:confused:
DanNY Dec 3, 2002 10:14 AM
yes...because a HID bulb does NOT act like a normal bulb. once it's ignited and lit..it stays lit. unless there's another bulb "hybrid" then the HID bulb/capsule will stay lit regardless of high or low beam.
the way they control the high beam and low beam "generally" is they have a relay to control a shield on a H4 bulb. but it does not act like a regular bulb...so juice is incorrect on his info.
funnylittlman Dec 3, 2002 12:58 PM
Oh ok. I got ya!:D
That's what I was wondering, b/c all the "dual's" that i've seen have had a servo (manually moved) or had another bulb on it (the dual xenon that Bimmers use now). My bad:(
juice Dec 3, 2002 01:14 PM
Hi/Lo
The above description is correct for one type of Hi/Lo kit that is available. It uses a relay to allow the bulb to stay on when the Hi beams are engaged. These kits are currently in stock.
The second type of Hi/Lo kit which I attempted to describe works with a solenoid that is able to slide the bulb itself back and forth, hence changing the angle in which the light is output. I apologize for my incorrect information in my above post. However thes kits will not be ready for a short while.
Again my apologies.
funnylittlman Dec 3, 2002 01:30 PM
Juice,
I have heard nothing bud bad things about the Solenoid ones. They crap out fast.
What's your opinion?
juice Dec 3, 2002 01:49 PM
Juice,
Thats exactly why we dont sell the current available ones yet because there are still bugs in the systems. We are looking into other developers in Germany and currently testing those systems. I really can't say when they will be ready because it depends on how long it takes find and correctly functioning product.
