AMSOIL Synthetic GL-4 75w-90 Manual Trans Gear Oil - Wholesale Pricing Available
Old Jan 5, 2013 | 06:39 AM
talkinghorse's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
Don't use a common gear oil that's labeled as meeting GL4/ GL5 in your manual transmission. Those oils are typically designed for use in differentials with hypoid gears and the additive packages are too aggressive and will adversely affect the shift quality of your manual transmission and shorten it's life.
AMSOIL GL-4 75w-90 Manual Transmission & Transaxle oil is specifically formulated for manual transmissions/transaxles to provide proper synchromesh operation, smooth shifting and maximum gear protection. Not corrosive to yellow metals commonly used in synchromesh systems. Excellent cold-shift winter performance and outstanding protection in the most demanding high temp, high stress situations. Keeps seals pliable. I sell a ton of this oil to our members and the feedback is outstanding! http://www.amsoil.com/lit/databulletins/g2077.pdf
Please send PM or e-mail direct to lonestarlubes@gmail.com for additional information and/or pricing. Pls include zip code and/or state of residence so I can calculate correct sales tax (if applicable) and shipping. Detailed description of all products, an on-line application guide and a free on-line maintenance tracker can be viewed/accessed thru my website at www.lubedealer.com/lonestarlubes
20-yr Nissan owner, 10-yr org member, AMSOIL Certified Dealer, Maxima.org Sponsor & Donating Member. Outstanding feedback with hundreds of satisfied customers throughout the US and Canada.
Wholesale pricing available!
Old Jan 14, 2013 | 05:37 PM
AMSOIL Synthetic Manual Transmission & Transaxle Gear Lube is a premium blend of the finest synthetic base oils and advanced, high-performance additives. It is formulated specifically for maximum protection in demanding manual transmission and transaxle applications where an extreme-pressure GL-4 gear lube is specified, including those where high-horsepower/high-torque engines and towing or heavy loads increase transmission stress.
AMSOIL Synthetic Manual Transmission & Transaxle Gear Lube helps prevent the thinning effects of mechanical shear. It is formulated to maintain its viscosity and superior film strength for consistent, long-lasting wear protection. Synthetic Manual Transmission & Transaxle Gear Lube excels in hot and cold temperature extremes that exceed the limits of conventional mineral oils. It protects against rust, keeps seals soft for long life and is compatible with brass synchros for smooth synchromesh shift quality.
Please send PM for price quote. Wholesale pricing available
Old Jan 18, 2013 | 02:43 PM
My deals don't expire. Wholesale pricing available on premiere quality AMSOIL synthetic lubricants; complete line of filters by AMSOIL, Wix and Mann; NGK ignition products; Mothers; Trico and more.
20-yr Nissan owner, >10-yr org member, AMSOIL Certified Dealer, Maxima.org Sponsor & Donating Member, Veteran-owned business. Outstanding feedback with hundreds of satisfied customers throughout the US and Canada. Pls send PM for customized quote
Old Jan 22, 2013 | 05:31 PM
Fantastic product for those of you with manual-shift cars! AMSOIL Manual Trans Gear Oil improves shift quality in hot or cold environments and protects in the most severe operating conditions. Provides twice the service life of conventional fluids!
20-yr Nissan owner, >10-yr org member, AMSOIL Certified Dealer, Maxima.org Sponsor & Donating Member, Veteran-owned business. Outstanding feedback with hundreds of satisfied customers throughout the US and Canada. Pls send PM or e-mail for customized quote
Old Jan 29, 2013 | 06:42 PM
GL-4 is a hard to find product. I have it!
Old Feb 6, 2013 | 05:14 PM
Fantastic product for those of you with manual-shift cars! AMSOIL Manual Trans Gear Oil improves shift quality in hot or cold environments and protects in the most severe operating conditions. Provides twice the service life of conventional fluids! I sell a ton of this fluid to our members with fantastic feedback.
Old Feb 16, 2013 | 07:01 AM
AMSOIL Synthetic Manual Transmission & Transaxle Gear Lube is specifically formulated for demanding manual transmission and transaxle applications requiring the use of a GL-4 lubricant.
Designed to excel in severe-service conditions that exceed the limitations of conventional fluids. Reduces friction and maintains viscosity for long component and fluid life.
Shear Stable! Provides a thick lubricating film and protects against wear in severe-service and shock-loading conditions.
Excellent cold-flow properties promote smooth, fast engagement of synchronizers and gears. Protects against wear caused by high-horsepower engines.
20-yr Nissan owner, >10-yr org member, AMSOIL Certified Dealer, Maxima.org Sponsor & Donating Member, Veteran-owned business. Outstanding feedback with hundreds of satisfied customers throughout the US and Canada. Pls send PM or e-mail for customized quote. Wholesale Pricing Available!
Old Feb 20, 2013 | 05:24 PM
Old Feb 23, 2013 | 05:44 AM
Don't use a common gear oil that's labeled as meeting GL4/ GL5 in your manual transmission. Those oils are typically designed for use in differentials with hypoid gears and the additive packages are too aggressive and will adversely affect the shift quality of your manual transmission and shorten it's service life.
Old Mar 1, 2013 | 05:39 PM
Hard to find GL-4 75w-90 Manual Transmission and Transaxle oil...I have it! I sell a ton of this oil to our members and the feedback is outstanding!
Fantastic product for manual-shift cars! AMSOIL Manual Trans Gear Oil improves shift quality in hot or cold environments and protects in the most severe operating conditions. Provides twice the service life of conventional fluids!
Old Mar 6, 2013 | 03:18 PM
Old Mar 17, 2013 | 06:55 AM
Old Mar 18, 2013 | 05:43 PM
Old Mar 23, 2013 | 02:50 PM
Old Apr 7, 2013 | 11:10 AM
Old Jun 8, 2013 | 07:42 AM
Old Jun 15, 2013 | 03:14 PM
Old Jun 29, 2013 | 06:34 AM
Old Jul 20, 2013 | 06:20 PM
Old Jul 27, 2013 | 05:52 AM
Fantastic product for manual-shift cars! AMSOIL Manual Trans Gear Oil improves shift quality in hot or cold environments and protects in the most severe operating conditions. Provides twice the service life of conventional fluids! http://www.amsoil.com/lit/databulletins/g2077.pdf
Wholesale Pricing Available! Pls send PM for customized quote or e-mail direct at lonestarlubes@gmail.com
Old Aug 3, 2013 | 06:22 AM
Old Aug 25, 2013 | 02:08 PM
Old Aug 31, 2013 | 06:20 AM
20-yr Nissan owner, >10-yr org member, AMSOIL Certified Dealer, Maxima.org Sponsor & Donating Member, Veteran-owned business. Outstanding feedback with hundreds of satisfied customers throughout the US and Canada. Pls send PM or e-mail direct at lonestarlubes@gmail.com for customized quote
Old Sep 7, 2013 | 03:52 PM
Please send PM or e-mail direct at lonestarlubes@gmail.com for quote. Wholesale pricing available
Old Sep 14, 2013 | 03:13 PM
20-yr Nissan owner, >12-yr org member, AMSOIL Certified Dealer, Maxima.org Sponsor & Donating Member, Veteran-owned business. Outstanding feedback with hundreds of satisfied customers throughout the US and Canada. Pls send PM or e-mail direct at lonestarlubes@gmail.com for customized quote
Old Sep 22, 2013 | 06:07 AM
Old Oct 5, 2013 | 06:26 AM
Recent quote from one of our members:
"AMSOIL is AMAZING! I finally got the clutch job done. New clutch, pressure plate, throw out bearing, a resurfaced flywheel and the amsoil gl-4 fluid i bought from you. And let me tell you, it shifts amazing! Much better than it did before. And this is with a new clutch breaking in, which we all know is not fun to drive at the beginning cause of the new feel. Great product, would recommend to everyone driving a manual transmission car. Thanks a bunch! "
Old Oct 13, 2013 | 08:30 AM
Do not use GL-5 rated gear oils or products from other lubricant manufacturers labeled as GL-4/GL-5...those products are designed for use in rear diffs (hypoid gears) and the aggressive additive packages will attack the soft metals used in the synchros and will adversely affect shift quality when used in manual transmissions specifying GL-4.
20-yr Nissan owner, >12-yr org member, AMSOIL Certified Direct Jobber, Maxima.org Sponsor & Donating Member, Veteran-owned business. Outstanding feedback with hundreds of satisfied customers throughout the US and Canada. Pls send PM or e-mail direct at lonestarlubes@gmail.com for customized quote
Old Oct 20, 2013 | 07:30 AM
Old Nov 9, 2013 | 01:02 PM
Old Nov 17, 2013 | 06:52 AM
Old Nov 23, 2013 | 01:10 PM
20-yr Nissan owner, >10-yr org member, AMSOIL Certified Direct Jobber, Maxima.org Sponsor & Donating Member. Outstanding feedback with hundreds of satisfied customers throughout the US and Canada.
Old Dec 2, 2013 | 05:21 PM
Old Dec 29, 2013 | 08:29 AM
Old Jan 3, 2014 | 03:54 PM
Old Feb 2, 2014 | 11:56 AM
Old Feb 15, 2014 | 05:50 PM
Old Mar 8, 2014 | 07:47 AM
Old Mar 15, 2014 | 11:56 AM
Feedback from a recent customer:
"Thanks so much for suggesting AMSOIL 75w-90 to me. Of four gear lubes I've tried, including Redline MT90, the (AMSOIL) 75w-90 is making for the smoothest shifting by a wide margin. I appreciate you providing me an excellent product and outstanding service"
Old Apr 4, 2014 | 07:01 PM
LoneStarLubes - Cars like us, because we like cars!
