Go Back  Maxima Forums > Classifieds > Group Deals / Sponsors Forum
Reload this Page >
LED Headlight Bulbs for Nissan Maximas! Made in USA! | Diode Dynamics
Old 05-14-2019, 01:36 PM
Maxima Lighting Experts
Diode Dynamics's Avatar
https://www.diodedynamics.com/led-bu...m_medium=forum']SL1 LED Headlight for Nissan Maximas
Diode Dynamics is pleased to offer the USA-made https://www.diodedynamics.com/led-bu...m_medium=forum']SL1 LED Headlight bulbs for Nissan Maximas
If you're looking to improve your Nissan Maxima’s visibility at night, you've probably seen plenty of aftermarket LED headlight bulb options. There are plenty of “high performance” LED lights on the market, but they all have their shortcomings. They're too big to install, have no hotspot in the beam pattern, or they simply stop working after just a few months!
With its compact size, optically correct output, thermally-modeled cooling, and boost-mode electrical circuit, https://www.diodedynamics.com/led-bu...m_medium=forum'] Diode Dynamics SL1 LED Headlight Bulbs are truly the best LED headlight bulbs on the market.
[/color]
Street Legal Output. Don't be fooled by high lumen numbers or "projector specific" bulbs. Your Nissan Maxima’s headlights are designed to focus light. If the light source is out of focus, it doesn't matter how bright it is - you won't have a focused hotspot of light to shine down the road - just more glare. Some generic options have such a poor optical design, they might leave you wondering “how are LED headlights legal?!”
To correct this, the https://www.diodedynamics.com/led-bu...m_medium=forum'] Diode Dynamics' SL1 LED Headlight Bulb was engineered with advanced optical design software, to perfectly match the halogen filament location. This allows the SL1 to focus light just like the original halogen headlights, preserving the focus and hotspot, with no added glare. It produces a functional beam pattern with zero glare, which we call Street Legal.
Tested to Perform. We test the https://www.diodedynamics.com/led-bu...m_medium=forum'] the SL1 in factory car headlights and measure the entire beam pattern using specialized equipment. The entire beam pattern is mapped, and we compare the total output to the original equipment, confirming that the SL1 headlight bulb shines more light in the hotspot, without adding extra glare on the road. The test results speak for themselves: in most lamps, there is 30-70% more light output in the critical hotspot, with zero glare. Thanks to optical engineering, testing, and validation in the application, the SL1 is the #1 LED headlight bulb for reflector and projector headlights.
[/color]
Staying Cool. You might’ve seen led headlight kits that use large straps for cooling, or fans that just make noise. These light bulbs run hot, resulting in degradation of output after a few months. When it comes to cooling, proper engineering is required to efficiently remove heat from the bulb. In the https://www.diodedynamics.com/led-bu...m_medium=forum'] the SL1, a copper core board, thermal phase-change material, and thermally-modeled zinc casting get heat to the base, where base fins release it, designed for aerodynamic performance in conjunction with the flow rate and pressure of the Sunon bearingless micro fan. The result is a highly effective and reliable cooling system, keeping the SL1’s LED chips running at maximum potential.
Fitment. With its patented design, https://www.diodedynamics.com/led-bu...m_medium=forum'] installing the SL1 LED headlight bulb is simple and straightforward, requiring NO cutting or modification. There's no hanging metal straps, just a compact bulb that plugs right into your Nissan Maxima, with a nylon-reinforced shroud. Only slightly larger than a standard halogen bulb, it fits behind dust caps and in tight spaces. The base sizes are keyed specifically to fit your vehicle, not one-size-fits-all! And the compact driver easily tucks away.
[/color]
Reliability. Every part of the https://www.diodedynamics.com/led-bu...m_medium=forum
'] Diode Dynamics' SL1 LED Headlight Bulb is engineered with more expensive OEM-grade features to assure quality, such as the Sunon MagLev fan and PCB wire connectors" In short, these are designed, tested, and built to a much higher standard than your average imported led headlight conversion kit. The https://www.diodedynamics.com/led-bu...m_medium=forum'] Diode Dynamics' SL1 LED Headlight Bulb will keep performing in your Nissan Maxima for years, and is backed by a three-year warranty.
Specifications
Measured Lumens: 1630 (per bulb)
Color Temp: 5700K (cool white)
Power (watts): 20.2
Operating Voltage: 5-16V
Current (amps @ 13.2V): 1.58 Polarity:
Polarity Specific LED Emitter: Luxeon Z ES
Connector(s): OEM-Size Plug and Play
Driver Features: External, Waterproof, Constant Current
Materials: Copper PCB, PP-TD30 Base, Zinc Heatsink
Cooling: Active, Mag-Lev Microfan
Compliance Ratings: FMVSS108 Beam Pattern, SAE J575 Durability Test
[/color]
Click To Order Your Nissan Maxima Headlight Bulb Replacements:
maxima&utm_medium=forum']Diode Dynamics SL1 High Beam LED Headlight for 2002-2003 Nissan Maxima
maxima&utm_medium=forum']Diode Dynamics SL1 Low Beam LED Headlight for 2004-2007 Nissan Maxima
Diode Dynamics SL1 High Beam LED Headlight for 2004-2007 Nissan Maxima
maxima&utm_medium=forum']Diode Dynamics SL1 Low Beam LED Headlight for 2009-2018 Nissan Maxima
maxima&utm_medium=forum']Diode Dynamics SL1 High Beam LED Headlight for 2008-2015 Nissan Maxima
If you have any questions, please don't hesitate to post, PM, email [email protected]
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Jake H.
Diode Dynamics
[/color]
[/b]
[/color][/color][/color]
Diode Dynamics is offline
Old 05-16-2019, 01:02 PM
Should note that this is only plug and play if you have a Halogen setup.... If you have factory HID and want to use a led.. You will need to use power and ground from the factory headlight harness.. For low beam with HID..
Nmax5150 is offline
Old 05-17-2019, 02:28 PM
LED Focus: What you need to know!
Are you looking to make the switch from halogen to LED headlight bulbs? Before you do, check out this video to ensure you choose the best one.
Good optical focus means more light further down the road where you need without any glare. We put together this video to highlight what to look for when choosing an LED headlight bulb for your vehicle. Check it out! And don't forget to shoot us a PM for free USPS shipping on any U.S order!
Jake H.
Diode Dynamics
The Duke of NY
8th Generation Classifieds (2016-)
04-20-2019 02:20 PM
Diode Dynamics
07-02-2018 02:26 PM
WarAdmiral
12-11-2017 08:50 AM
Trickey79
07-05-2017 08:40 PM
R1talin
02-25-2017 08:12 PM
Quick Reply: LED Headlight Bulbs for Nissan Maximas! Made in USA! | Diode Dynamics
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
