I searched and could not find a How to on..
Here is a simple way.
Go to www.oxygensensors.com
buy the sensor
jack up the car
Look back by the cat. The sensor will be right after the cat or right on top of it. I always forget wich one it is.
Remove old sensor
Put some anit-sieze on the new one and screw it in.
buy the sensor
jack up the car
Remove old sensor
Originally Posted by Jaybe
Thanks alot Mike the funny thing is they (oxygensensor.com) are saying 2 are required. Is this Bull or what?
Try looking up the 02 sensors for a 97 Maxima. It will show the o2 sensor you need, the one after the catalyst. I would probably just order that. It should work fine.
Originally Posted by I30tMikeD
Your right. For a 97 I30 they only list the 2 sensors on the y-pipe and those are not what you want. I wonder why they don't list the 3rd down stream sensor???
So you can either just go to the dealership and pay $120, try the sensor for the 97 Maxima, or try the one from the 96 I30 (from 96).
anybody else have any ideas.
Damn it I already processed the shipment. I looked under '96 and I see the one I need. I hope I can cancel or readjust the order. I think I hope the '96 one will work.
The thing is that I think the sensors that are on the cat are different than the ones after the cat. The 96 I30 sensor will probably be a after the car sensor, while the 97 maxima one will be a on the cat sensor......You can probably tell if it's the right one before you install it, so maybe you can return if it's not the right one.
doctorpullit
09-10-2015 06:33 PM
