Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   Infiniti I30/I35 (https://maxima.org/forums/infiniti-i30-i35-49/)
-   -   2K I30 HID's (https://maxima.org/forums/infiniti-i30-i35/201029-2k-i30-hids.html)
NewLoveI30 Jan 5, 2004 12:14 PM
2K I30 HID's
Unfortunately my 2000 I30 doesn't have the factory HID's. I have a few questions about my options so I would appreciate any experiences/opinions you may have.
Has anyone replaced their halogen lamps with the factory HID? I would like to know how difficult and expensive it would be. Should I just buy a retrofit?
The things I don't like about retrofits:
The color is not the same as factory. The kit I used on my other car was 9000K (to try and get the color of factory HID), I would probably go with 6500K to get less purple.
You cant just leave your lights on which I like to do. You need to start the engine before you turn the HID retrofit on because they need full power or you may damage the ballast.
I like the black headlamp housing that the factory HID's have. When looking at the headlight, the front of the housing dosent seem to be attached to the reflector. Do you think I would be able to replace just the front part of the housing wothout replacing the entire headlamp?
Well, if you understood any of my rambling I would appreciate some feedback.
mikeI302k Jan 5, 2004 04:47 PM
hey, i have the same problem i just made a thread to find out if the maxima hid kit can be used in the car.
NewLoveI30 Jan 5, 2004 05:02 PM
Why the Max HID? I don't think they will fit.
mikeI302k Jan 6, 2004 10:29 AM
i thought that it didnt matter but i might be wrong. i did talk to a guy selling an hid kit used in the bmws and he said that it depends on the harness so i figured that since the i30 and the maxima are almost the same. they might have the same harness. ill try to look into it more. if you find anything out let me know.
NewLoveI30 Jan 6, 2004 10:48 AM
I dont think the Maxima headlight will bolt up to our cars. The hood and bumper are different and I would be VERY surprised if they did fit.
I am looking for a kit from an I30. I need to ask the dealer how much for all the components, but I am afraid of what the answer might be$
Another question for anyone with the factory HID. Is the ballast bolted onto the headlamp, as in all one piece? I think the G35s are.
mikeI302k Jan 6, 2004 12:36 PM
im probobly going to go to the dealer near my house and ask how much the i35 headlights are. but i think if we can pull the hid kit out of the maxima we can use it. but ill try to find out.
NewLoveI30 Jan 6, 2004 01:38 PM
Let me know what you hear. If I find something out Ill post it aswell.
We definitely need to get more than two people in on this thread.
MaDdFLaSheR Jan 8, 2004 12:27 AM
u'd be surprised at how diff the max and the i30/i35 is. i find that out more and more every day. i used to think they were identical but now i know otherwise
LIUSPEED Jan 9, 2004 12:27 PM
www.hidforum.com
do a quick search there and alot of your answers will be there.
MetaOrbit Jan 9, 2004 05:06 PM
What you A33 guys are going to need are the HID headlight assemblies from either the I30t or the I35. They turn up on eBay every now and then, pretty cheap too.
As for the HID bulbs and ballasts - you can use any automotive HID ballast and any D2R bulb. The real key here for a good retrofit will be getting the headlight assemblies.
A good alternative would be doing something like an HID projector retrofit in your halogen assemblies. Since you already have high beam reflectors, it becomes real easy (don't need to mess around with bi-xenon projectors or driving lights, etc.). The only thing here is that it can get expensive - especially if you're not doing the work yourself.
If you want someone to do the retrofit for you, I highly recommend http://www.illusion-lighting.com/
Take a glance through their gallery and all, it's impressive work.
mikeI302k Jan 10, 2004 05:02 PM
talk to this guy he works at an infiniti dealer he can get some parts pretty cheap
arianmustafa79@hotmail.com
NewLoveI30 Jan 10, 2004 06:11 PM
Thanks for the tips guys.
I have done a HID retrofit before, so I understand what is needed. What i really have a question on is if the wiring upto the ballasts are the same on the HID models as on the hallogen models. I understand that most ballasts use the 9006 harnes (which we already have).
The reason Im rambling on about the wiring is that I want to be able to leave my lights on (so when I start the engine the lights come on automaticaly) and not damage the ballasts by starving them for current.
Any thoughts?
MetaOrbit Jan 11, 2004 12:14 PM
Any thoughts?
I've often wondered if automakers use the same wiring on cars that have HID as an option on their halogen equipped cars. I would assume so, for cost reasons, but I don't know. Perhaps you could call up a parts dept. and ask them to look up if the wiring is different or not?
Alternatively, and I'm sure you already know this, you could use an auxillary wiring harness and not have to worry about the current draw.
NewLoveI30 Jan 17, 2004 07:44 PM
I just spoke with the parts dpt. at my local Dealer.
$700!!! For the I35 Headlights, EACH!!! WTF is that. I have seen them advertised on some site for under $200. On that same site they say OEM MSRP is like $350. I dont want to buy them from the site because Im not sure I trust their product.
Does anyone out there know if this is BS?
Mike I30: I need to E-mail your friend. Have you heard anything from him?
mikeI302k Jan 18, 2004 12:42 PM
yea he said the lights run about 700 each to thats y i didnt buy them. alos i went my dealer he said they were like 875 so idn whos bull****ing. anyway ill try to email him today and find out more info.
mikeI302k Jan 18, 2004 12:46 PM
the actuall HID kit from the light actually. but he did recomend an hid kit that is also as good as the factory so ill try to have him post here if i can.
NewLoveI30 Jan 18, 2004 01:06 PM
I asked the parts guy if that was just the headlight w/o the HID ballast and Bulb and he said it was just the headlight. Does your friend know if that is true? If that price, 7-8 hundred, did include the ballast and bulb that seems to me about correct.
$350ish- Headlight
$200ish- Ballast
$100ish- Bulb
mikeI302k Jan 18, 2004 01:13 PM
ill find out for you as soon as he respondes or if you dont want to wait send him an email and ask.
A-RokI30T Jan 18, 2004 07:13 PM
hey guys. for all u who are lookin to add HID to your rides there's the CATZ hid kit which looks real good on the I30/I35 and it's cheaper than the stock package. i had the links to it saved but seems i've deleted them so i'll get them back and post em up here. i work at an infiniti dealership so if any of u need the OEM hid kit i can get u that but u'll pay lot more for it. i'll be in touch
A-RokI30T Jan 18, 2004 07:22 PM
[QUOTE=NewLoveI30]I just spoke with the parts dpt. at my local Dealer.
you've seen the "I35 OEM headlights" advertised for under $200??? i'd like to see that website cause they definately are not OEM. probably some cheap imitation that won't even fit right. dealership price for a set of the I35 HID lights is $895/set. i work at a dealership and i get all parts at cost, and i'd end up paying $700 even for the set. if you want the good stuff though i would highly not recommend buying the I35 lights at some third world country website you probably saw them in.
A-RokI30T Jan 18, 2004 07:24 PM
hey mike, i did not say the lights run about $700 each. the OEM I35 HID kit i said costs me $700 for the set but it sells at a dealership for around $875-900. it's for the HID SET though, just to clarify that. there's no way they can be 700 each. there's other kits out there u can use that will be cheaper just make sure u don't buy crap
mikeI302k Jan 18, 2004 07:24 PM
hey arian thanks for posting. listen post the links and maybe we can try to get a gd going for other members or the website.
mikeI302k Jan 18, 2004 07:25 PM
on the website i meant sorry typo.
mikeI302k Jan 18, 2004 07:26 PM
o and arian sorry about the false advertising that was my mistake.
A-RokI30T Jan 18, 2004 07:27 PM
the kit i've seen that goes well with the I35s is the CATZ HID kit. like i said i don't have the link to the site off hand but run a search on google for Catz HID kits and see what comes up.
mikeI302k Jan 18, 2004 07:34 PM
will we be aable to use the "auto" function on our headlight switch without damaging the balast or will we have to turn them on manually?
mikeI302k Jan 18, 2004 07:43 PM
heres the site that sells them
http://www.autospeedy.com/catz_hid.asp
i emailed them the question i asked above and i will post the answer as soon as they reply
mikeI302k Jan 18, 2004 08:04 PM
well anyway the cheapers i came up with was here::
http://www.highaltitudeimports.com/a...dex.php/t-9246
mikeI302k Jan 18, 2004 08:05 PM
cheapest***
I30LeNnY96 Jan 18, 2004 10:36 PM
hey mike
Well i am interseted in HID also but i am interested for an I30 96 and the HID would go in my one piece cefiro's.
I was wondering if the catz hid will fit it and also if i can have hi/low?
mikeI302k Jan 19, 2004 09:11 AM
yea they have the h4 too. ill let you know if i come up with anything.
NewLoveI30 Jan 19, 2004 09:58 AM
I30LeNny,
I have seen aftermarket kits out there that will give you the hi-lo function, but I have heard they are crap. I put an HID kit on my other car and lost the hi-lo, but you really dont miss it that much. The HIDs are Sooo Much brighter.
Arian,
Sorry, but did I understand you correctly:
This $800-$900 includes the headlamp housing AND the HID ballast and bulb?
When you said set, that did not mean for both sides ie. two headlamps and ballasts and all?
Thanks for the info. It is really helpful.
mikeI302k Jan 19, 2004 12:21 PM
hey i found this on ebay is this kit any good?
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2454090870
NewLoveI30 Jan 19, 2004 01:26 PM
It looks like an older kit with the integrated ignitor/bulb. I dont think it will fit in our headlights though. You would need a HID headlamp.
mikeI302k Jan 19, 2004 07:49 PM
thats what i figured
mikeI302k Jan 20, 2004 06:55 PM
okay guys,
i found a what i think is a good price on the catz HID kits.
heres the site:
http://www.sportsimportsltd.com/br50hidhecok.html
however i dont know how to set up a gd. also I am only 17 years old so I cant set on up. but maybe one of you guys can?
mikeI302k Jan 20, 2004 06:56 PM
heres the general page:
http://www.sportsimportsltd.com/hidxenon.html
as for my other post i meant set "one" up
mikeI302k Jan 21, 2004 07:24 PM
guys i just got an email froma website that i wanted to get a price quote from and heres wat it said
Sorry, my supplier has just informed me that they no longer carry HID
kits. They stopped because they can get fined because HIDs are illegal
on California Highways now.
If you need any other parts, let me know.
Thanks!
www.bnecustoms.com
www.socalracer.com
Eric Altaffer
NewLoveI30 Jan 23, 2004 01:03 PM
HID Kits have always been illegal, but I think just recently it became illegal to sell the kits in the states.
I have actually been looking at www.hid-online.com. They supposedly use only Philips components which is what most OE manufacturers use. I am in the process of asking questions, and if everything goes well I will purchase and tell you what I think.
