Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   Infiniti I30/I35 (https://maxima.org/forums/infiniti-i30-i35-49/)
-   -   18" G35's, What size tire? 2k I30 (https://maxima.org/forums/infiniti-i30-i35/623246-18-g35s-what-size-tire-2k-i30.html)
DCZC Oct 27, 2010 05:54 PM
Just picked up some wheels, needing tires and wanted to get some feedback from others who gave done 18's on an I.
Thanks in Advance,
DCZC
Rhyno02 Oct 27, 2010 07:49 PM
245/40/18.
Joeker82 Oct 27, 2010 09:04 PM
Originally Posted by Rhyno02 (Post 7792917)
245/40/18.
I'm run'n 225/45/18. it depends if your planning on dropping it...if you are than run 40's
Rhyno02 Oct 27, 2010 09:52 PM
A drop doesn't have too much to do with the difference between 225/45/18 and 245/40/18 bc I think they're a similar diameter. The g35 18s are an 8" rim so I personally think 245s look better than 225s and wider is better...
Joeker82 Oct 27, 2010 11:52 PM
I guess? All I know is the 245/45/18's I ran, rubbed in the back.
Then I switched to 225's and it's all good!
CustomLowz Oct 28, 2010 03:25 AM
I am running 255/35/18 on my 5.5gen with a 2" drop.
phatboislim Oct 28, 2010 05:05 AM
i had 245/40/18 on my Gs when i had em, loved em...next set i got was 235/40/18..had a stretched look...i hated em, ended up trading for the wheels i have today
Rhyno02 Oct 28, 2010 06:16 AM
When i had the 245/45 they rubbed too, that's why I went to 245/40s....
J RO 9 Oct 28, 2010 08:36 AM
225-40-18 tires are the cheapest, but that size will throw off your speedo but only a little bit like 1-2 mph
235-40-18 is best if you don't want to throw off your speedometer
245 is too wide IMO
Joeker82 Oct 28, 2010 10:24 AM
I went with the 45's. We have alot of potholes and such in chicago. I like having a little more sidewall on my tires. That way I'm not blowing tires. And a 45 is still a very low profile.
So, I guess the answer is...there is alot of different sizes you can run. Lol
Its all preference?? ;)
din9lebeRrY Oct 28, 2010 11:44 AM
No 235/45/18 is ideal because it retains the closest diameter/circumference to OEM tire/rim combo. These tires are also expensive.
225/45/18 all around if you wanna be cheap and save money on these specific rims.
245/40/18 all around if you wanna be cheap and save money & are running a staggered for example (i.e 8.5 in the back).
Joeker82 Oct 28, 2010 12:59 PM
Sounds good to me. But, my tires ur not cheap? Plus, I think the tire rack calls for a 235/40/18 as recommended and no one mentioned that yet??
I spent 190 a tire. And I think the 40's were only 30 bucks more a tire.
Sounds like he has some options....
Rhyno02 Oct 28, 2010 01:12 PM
Stock:
225/50/17 = 25.9" diameter
Options for G35 18":
225/45/18 = 26"
245/40/18 = 25.7"
235/45/18 = 26.3"
There you have it OP, they are 18x8" rims so you can run anywhere from a 225-255 width. Its up to you want you want...its not about being cheap either.
Joeker82 Oct 28, 2010 01:36 PM
Originally Posted by Rhyno02 (Post 7793536)
Stock:
225/45/18 = 26"
245/40/18 = 25.7"
235/45/18 = 26.3"
Yea, I'm not cheap! ;) lol
burgy Oct 28, 2010 06:21 PM
The answer COMPLETELY depends on what you want from the car. Are you gonna slam it so you tuck rubber? are you trying to track it at an auto X event? are you looking to negate the fact that the wheels are staggered? Are you worried about retaining accuracy in the Speedo? ALL these questions need to be answered before anyone can give you the "BEST" answer.....anyone that tells you different is either lying or doesn't know any better.
an example is my wifes I35 in my sig has 225/40/19 on a 9" wide front wheel but she tucks rubber and doesn't rub at all? but she doesn't auto-x and could care less about the speedo being dead on. Oh and she ran the anniversarry edition Z wheels for awhile on hers too but we stuck with the stock rubber sizes.
DCZC Oct 28, 2010 06:34 PM
All,
Thanks for the responses.
SOme additional info
I dont plan on lowering the car, I dont want any rubbing issues, I want a clean look with some wall but no bloons,
TIA,
DC
Roz-CA32 Oct 28, 2010 06:35 PM
I went with 235/40/18. I'm pleased with the look at the performance. . .
ShippedOut Oct 28, 2010 06:41 PM
245/40/18 Rear
225/40/18 Front
I'm lowered 1.8F and 1.6R on Megan springs. When I get coilovers and max them out ill just get my rear fenders rolled or pulled
Joeker82 Oct 28, 2010 06:41 PM
I love your wifes I35. Looks awesome! Kudos!
burgy Oct 28, 2010 06:52 PM
^Thanks, I think she did a nice job of putting it all together style wise.
Originally Posted by DCZC (Post 7793960)
All,
TIA,
DC
there are a few options because you should have any issues with rubbing etc at stock height or even near stock height. I personally would run a 215/45 or maybe even a 215/50 depending on the actual stretch because you would fill the gap some more but not get a ballon effect on the sidewall and still have a nice turn in with the stiffer side wall from being stretched. I would not run the 245/40 up front as it will have a slight balloon and be sloppy compared to the rears. if you want a very stock feel and still a bigger look you may just want to run a 235/40 but they aren't cheap...hope this helps some.
And here is the sickest calculator ever. (not all tires manufacturers products stretch the same so the calculations on stretched tires may be slightly different but they are damn close)
http://www.willtheyfit.com/
din9lebeRrY Oct 29, 2010 08:24 AM
^ I agree with you. You can run anything you want, from 215 to 255.
Can you go with stretch? Sure. Does it run the risk of bending your rim over pot holes now. Yep.
Can you go with a fat side wall? Sure. Do you wanna rub on the loose stock suspension, or if you're dropped? Up to you.
With that said, my post was based on speedo accuracy/matching up the diameter/circumference CLOSEST to OEM tire specs (215/55/17, for i35 for example). Your link, as well as http://www.miata.net/garage/tirecalc.html can explain further why (to those that dont understand).
On my second point, and as a general rule of thumb, 225/45's and 245/40's are comparatively cheaper to buy than 235/45. If you need more proof on that, price out on tire rack.
I have rolled fenders, realigned my rear beam after a 1 finger gap drop all around (not pictured in sig), with a very stiff preload and dampening, still occasionally have a very slight rub on 245/40s on my track edition wheels. 18X8.5 +33.
DCZC Dec 23, 2010 06:19 PM
Well, just wanted to update; I ended up getting some lightly used michelin 245 40 18's for a deal. I love the way the wheels look on my I30; much more agressive IMHO and the steering feels much stiffer.
Thanks for the recommendation guys!
MERRY CHRISTMAS!!!:santa:
VQ'rInWLA Dec 24, 2010 01:16 AM
Have pics? Would love to see the stance.
DCZC Jan 15, 2011 10:34 AM
Better late than never I guess
Here is a pic with the wheels,
I'm overall satisfied. Thanks guys:D
http://forums.maxima.org/picture.php...ictureid=23345
http://forums.maxima.org/picture.php...ictureid=23348
VQ'rInWLA Jan 15, 2011 10:49 AM
Looks good. A moderate drop would set it off. You wouldnt rub either. Noticed that you didnt wanna drop because of rubbing issues....
Joeker82 Jan 15, 2011 04:24 PM
Looks good! Looks like my ride in black..
DCZC Jan 16, 2011 08:13 AM
Yeah, I saw yours posted in the audio forum awhile back(think it was audio, after you upgraded the bose). Clean car.
Thanks for the compliment.
-DC
Joeker82 Jan 16, 2011 09:48 AM
-DC
Welcome buddy! Hey, just my opinion....you should lose the pin strip!?!
VQ'rInWLA Jan 16, 2011 09:51 AM
Wow didnt even see it till you mentioned it! :sprint:
DCZC Jan 16, 2011 01:07 PM
Yeah, bought it like that from the original owner, old Judge from DFW area, all wor done at Sewell Dealership. I guess I was willing to deal with it for a low miles clean car; Plus I love black on black. Its not a decal, its some sort of light paint that would need to be wetsanded and buffed out.
Joeker82 Jan 16, 2011 01:47 PM
Ooo, never mind then. ;)
jviv35 Jan 19, 2011 11:18 AM
CustomLowz, now that's what I'm talking about...wide and low...but not too low. Anyone else running 255/35/18...on an I? (pics please) Facing slight dilemma w/my 02 I35. About to throw on some GR-2's and Megan springs (1.8f, 1.6r I think) with 06 M35 18's (haven't seen these used much but they're hot to me). Maxima bodywork is quite sporting compared to I30/35 so its hard to tell if suspension/wheel/tire set-ups translate equally. Seems like many dig the 245/40 but I'd like a little less side-wall with that wide look...of course I'd like the tires to fill the wheel wells also. After calculating it all 265/35 is closest, but that may look silly on 8" rim. Think I'm gonna drive the tire shop crazy trying on 4 or 5 different sizes LOL:D
A324DSC Jan 20, 2011 10:43 AM
not bad but imho it would look better if you dropped it a bit.
