Brake and Battery light
Hi, My 2003 I35 had both of these lights on then when I let the car rest a bit they were off?
The alternator is failing.
Wow really just had that put in like 10 months ago....??? This is actually the 2nd one first replacement had a bearing go within 2 months could something be eating these?
Originally Posted by JSutter
(Post 9205214)
Made in China Alts? Seems to me they should last longer than that.
Originally Posted by Woody91557
(Post 9205237)
Put a volt meter to it 14.5 running 12.5 when not. She drove it today and no light. I'm hoping it was an anomaly :) I guess wait and see.
(Post 9205252)
No, Need to put a load on it? I will try that thanks.
Just tried it still got a 14.5
The last thing I’d do would be a voltage drop test across the charge cable.
If that tests good, I’d maybe agree your trouble lights were a fluke. |
Check that the belt is not cracked and/or worn and that it is tight. A belt that is not fully tight can slip when it gets wet but work OK when dry.
OK, The belt seems fine it was put on new along with the Alt. but I was thinking the same. Don't want it to be the alt. again! :)
Just a quick update still no light!! :)
Same thing happened to me. I had my alternator replaced by a mechanic. It died in a year. I realized that it was a remanufactured alternator that he put in. The second time around, I found an alternator on amazon (new not remanufactured). That second one is now 3 years old and has over 30,000 on it. So if you have been using remanufactured alternators, you may want to look at new. I heard all kinds of problems with remanufactured alternators.
OK thanks.
© 2024 MH Sub I, LLC dba Internet Brands
