Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   Members Rides (https://maxima.org/forums/members-rides-65/)
-   -   MZ's 325i sh*tbox build thread (long & LOTS of pics) (https://maxima.org/forums/members-rides/602005-mzs-325i-sh-tbox-build-thread-long-lots-pics.html)
MorpheusZero Oct 29, 2009 05:07 PM
I've been pouring my heart, soul, and way too much money into my ****box E30, so I figured I'd share. It's not that cool, but I'm doing what I can to turn the car into what it deserves to be.
I've got a project thread on r3vlimited too, believe it or not this is actually the abridged version. Here's the story.
Almost a year ago the maxima met its demise which ended up being the best handling mod of all
https://img.photobucket.com/albums/v...1/P1030713.jpg
Poor max
So I picked up a certain girl's 325i that was the only "i" 5 speed in town in my meager price range, here it was sitting at the DMV getting registered, no working heater or AC, no working tach, no working radio, wipers didn't work without you holding the stalk (all of that fixed soon except the AC which had no charge)
https://img.photobucket.com/albums/v...1/IMG00215.jpg
In front of a friend's house a day or so later
https://img.photobucket.com/albums/v...1/P1030805.jpg
Interior was in good condition
https://img.photobucket.com/albums/v...1/P1030802.jpg
First thing I did was a timing belt and water pump outside of my gf's place (no pics)
Then I started picking up stuff I found for cheap
3.73 (stock ratio) LSD, old, little noisy and worn out but axle seals seemed to be ok, does the trick with mobil 1 in it
https://img.photobucket.com/albums/v...1/P1030890.jpg
MorpheusZero Oct 29, 2009 05:08 PM
And being me I had to have lights that worked well, smileys with european grilles (which really don't make much of a difference)
Smilies on the left, old sealed beams on the right
low beam
https://img.photobucket.com/albums/v...1/P1030989.jpg
high beam
https://img.photobucket.com/albums/v...1/P1030990.jpg
I tried out the SEM stuff on some faded plastic trim pieces, worked pretty well
https://img.photobucket.com/albums/v...1/IMG00288.jpg
https://img.photobucket.com/albums/v...1/P1040135.jpg
https://img.photobucket.com/albums/v...1/P1040138.jpg
MorpheusZero Oct 29, 2009 05:09 PM
Painted some other faded trim and door handles
https://img.photobucket.com/albums/v...1/P1040049.jpg
ECU out of a newer 325i (the "173" ECU, Motronic 1.3 instead of 1.1) running a cloned "mark d" tune and bigger multi-pintle injectors as the stockers are running very high duty cycle
https://img.photobucket.com/albums/v...1/IMG00312.jpg
UUC Swaybarbarians (bday present to myself)
https://img.photobucket.com/albums/v...1/P1040142.jpg
Those were fun to install
https://img.photobucket.com/albums/v...1/P1040147.jpg
Brembo blanks and Textar OEM pads (pretty good pads actually) all around, rebuilt front calipers
-#u(k- set screws, $25 craftsman impact driver ftw
https://img.photobucket.com/albums/v...1/P1040166.jpg
MorpheusZero Oct 29, 2009 05:10 PM
Magnetic field from metal on metal near ABS wheel sensor, who cares about rear brakes anyway right? :squint:
https://img.photobucket.com/albums/v...1/P1040170.jpg
https://img.photobucket.com/albums/v...1/P1040171.jpg
MorpheusZero Oct 29, 2009 05:11 PM
[this is partially copied out of another thread, so it's not totally up to date]
Turns out I've had a mild blown head gasket for awhile, it reared its ugly head sometimes and sometimes it didn't. I started shopping around and figured maybe I could get a rebuilt head and stick a cam in it, but it turns out that would actually cost more than just doing an M50 swap.
Cliffs on the M50 swap:
M20 (in the car now), brand new with an intact head gasket: 168hp@5800rpm, ~165lbft@4000rpm
84x75 (2.5L), 8.8:1, SOHC, mechanical lifters (thus the sewing machine symphony), timing belt, cap/rotor
M50: 189hp@5900rpm, 181lbft@4700rpm
also 84x75, 10.0:1, DOHC, hydraulic lifters, timing chain, coil-on-plug
Modest improvement, but a newer motor, hasn't had the oil pan broken, has been maintained and it paves the way for the more powerful S50 down the road
Finally, after gathering parts for a few weeks, I started the swap this weekend, mainly since school has just started, I'm going to be swamped with work sooner rather than later, and I was running out of time.
Ironically, I only spent maybe 7 hours over the weekend (most else was preparing, loading everything into the car, etc). Here's what I've done so far.
Disconnected driveshaft/guibo
Removed selector rod
Removed radiator
Disconnected PS and AC hoses (AC didn't have much of a charge anyway)
Removed O2 sensor
Disconnected harness
Disconnected downpipes
Disconnected throttle/cruise control cables
Pulled tranny brace
Almost ready to pull the motor/tranny, just need to get the clutch slave, heater core hoses and possibly the shift rod.
The workspace (courtesy of a really cool guy in Buellton)
https://img.photobucket.com/albums/v...1/P1040272.jpg
https://img.photobucket.com/albums/v...1/P1040273.jpg
https://img.photobucket.com/albums/v...1/P1040274.jpg
https://img.photobucket.com/albums/v...1/P1040275.jpg
Draining coolant
https://img.photobucket.com/albums/v...1/P1040271.jpg
MorpheusZero Oct 29, 2009 05:12 PM
https://img.photobucket.com/albums/v...1/P1040276.jpg
Fuh raze interior
https://img.photobucket.com/albums/v...1/P1040277.jpg
How I left it
https://img.photobucket.com/albums/v...1/P1040286.jpg
https://img.photobucket.com/albums/v...1/P1040287.jpg
https://img.photobucket.com/albums/v...1/P1040288.jpg
https://img.photobucket.com/albums/v...1/P1040291.jpg
After I pull the engine, there's a checklist of **** to do:
delrin shift carrier bushings/new selector rod/tranny bushing, bend selector rod
Amsoil 75W90 GL4 in the tranny
Lighten flywheel
New control arms/M3 offset control arm bushings for increased caster
E36 rack (3.2 turns lock to lock instead of 4)
relocate brake booster for intake manifold clearance/new vacuum hose
new fuel lines (old ones are cracked to **** and I just cut them)
On the M50:
remove oil pan, loctite oil pump nut, new oil pan gasket
New GRAF water pump w/metal impeller
Semi-synthetic 5w30 (got for $3/quart) and new oil filter
I'm guessing, realistically, it will take another 2 weekends to finish. [WRONG]
MorpheusZero Oct 29, 2009 05:13 PM
Got a good deal done this weekend.
How I found her when I returned:
https://img.photobucket.com/albums/v...1/P1040293.jpg
I started disconnecting the few things that were left
Got sick of the heater core lines so I just cut them
https://img.photobucket.com/albums/v...1/P1040294.jpg
Look at that, it's got an oil cooler. Goodbye oil cooler (doesn't look like there are fittings on the M50 for this)
https://img.photobucket.com/albums/v...1/P1040295.jpg
Finally! Just using the front bracket since I couldn't get to the rear hoist point. I wouldn't do this normally but others on r3v have swear by it, I only had one hook so I gave it a shot.
https://img.photobucket.com/albums/v...1/P1040296.jpg
Removed the clutch slave while it was more accessible (couldn't do it while tranny was mounted)
https://img.photobucket.com/albums/v...1/P1040301.jpg
I haven't gotten the obligatory "in the engine bay" pic because I've done all of this on my own. I'll try and get one, as it is after all obligatory.
You can spot the bracket starting to bend, I figure most who've done it this way might not have pulled the long block/IM and tranny all using one bracket.
https://img.photobucket.com/albums/v...1/P1040302.jpg
I kept it going anyway, my entire weekend would be wasted if I didn't (have no other hooks besides the one already on the cherry picker)
Success! I had to drop the chassis by a good 4 inches to clear the body.
https://img.photobucket.com/albums/v...1/P1040305.jpg
Separated the G260
https://img.photobucket.com/albums/v...1/P1040312.jpg
Hey, ***** clip! **** you! [it's called ***** clip since it's almost impossible to remove while the tranny's in the car]
https://img.photobucket.com/albums/v...1/P1040309.jpg
Used the "hack saw" method of CAB removal [pretty self-explanatory, thread the saw through the 3-piece bushing and saw away]
https://img.photobucket.com/albums/v...1/P1040310.jpg
MorpheusZero Oct 29, 2009 05:14 PM
Used a bench vice and motor oil (I know I know) to press in the new M3 bushings. This one didn't really have the orientation quite right but I matched the other one pretty well, so at least it's symmetric.
https://img.photobucket.com/albums/v...1/P1040328.jpg
Out comes the M50... First time I'd seen its pretty valve cover since I bought it
https://img.photobucket.com/albums/v...1/P1040314.jpg
Up...
https://img.photobucket.com/albums/v...1/P1040316.jpg
And away!
https://img.photobucket.com/albums/v...1/P1040318.jpg
Bell housing assy was a pain to remove
https://img.photobucket.com/albums/v...1/P1040321.jpg
MorpheusZero Oct 29, 2009 05:15 PM
Two of the three bolts that stripped on me, I wound up just hammering a 13mm socket onto them
https://img.photobucket.com/albums/v...1/P1040320.jpg
The flywheel that's going to say goodbye to a few lbs of padding
And the clutch... it's been fine, hasn't been replaced in awhile but has been pretty grabby. Then again I'm not sure how much material is normal, but there's not all that much left.
https://img.photobucket.com/albums/v...1/P1040325.jpg
https://img.photobucket.com/albums/v...1/P1040326.jpg
I'm going to do the pilot and throwout bearing anyway, think I should just get the full clutch kit? Looks like it's got some life left... but how much I don't know.
Anyway my camera ran out of batteries, I took a few pictures with the phone but they didn't turn out.
Few other things I did
Remove steering rack
Reinstall one control arm (although still wrestling to get the lollipop to thread, didn't get it "all the way on" the control arm)
Drain M50 oil and start installing accessories.
MorpheusZero Oct 29, 2009 05:16 PM
Today
https://img.photobucket.com/albums/v...1/P1040329.jpg
AKG delrin shift carrier bushings
https://img.photobucket.com/albums/v...1/P1040349.jpg
These took SO much play out of the linkage, probably about 90% of the play.
https://img.photobucket.com/albums/v...1/P1040333.jpg
Put the new rack in
https://img.photobucket.com/albums/v...1/P1040335.jpg
Dropped it down on the new suspension
https://img.photobucket.com/albums/v...1/P1040340.jpg
It seemed like the CABs froze on the control arms in this position, doesn't look good, but it's better than nothing.
https://img.photobucket.com/albums/v...1/P1040341.jpg
Oil pump nut looks good but I forgot the loctite, so we hold back.
https://img.photobucket.com/albums/v...1/P1040344.jpg
After some brakekleen and a razor blade it's almost ready for a new gasket
https://img.photobucket.com/albums/v...1/P1040346.jpg
My ugly mug, obligatory engine swap pic
https://img.photobucket.com/albums/v...1/P1040348.jpg
Lightened flywheel, 12.5lbs
https://img.photobucket.com/albums/v...1/P1040350.jpg
Old water pump and ****
Probably going back tomorrow
MorpheusZero Oct 29, 2009 05:17 PM
Soo hit a few road blocks last night
First order of business was to relocate the brake booster. We'd have to drill new holes, shave away at some of the firewall and change the mounting position from the "arm" of the brake pedal to the pedal itself.
First we removed the booster, then we removed the pedal. We drilled the pedal, then cut off the "connecting arm" shaved it down and put it in like a spacer to give the new mounting surface more width.
https://img.photobucket.com/albums/v...1/P1040355.jpg
https://img.photobucket.com/albums/v...1/P1040356.jpg
Then we started drilling more for the booster. Ran into a big problem: on one hole (top passenger's side booster hole) we'd basically be drilling lengthwise into the pedal support bracket, and on the other side (top driver's side booster hole) we'd be relocating the bolt too close to the bracket.
https://img.photobucket.com/albums/v...1/P1040367.jpg
https://img.photobucket.com/albums/v...1/P1040369.jpg
Well, fawk. I don't really like where this is going, so I decided just to give up and get a different booster. I just don't like screwing with things that need to hold in order to make my car stop.
Anyway, next order of business was loctiting the oil pump nut and just making sure it never comes loose in general. I torqued it on a little too tight, put some red loctite on it and used a chisel to **** up the threads (can't really see in the pic) but I don't think it's going anywhere any time soon.
https://img.photobucket.com/albums/v...1/P1040360.jpg
MorpheusZero Oct 29, 2009 05:18 PM
Then the new gasket went on
https://img.photobucket.com/albums/v...1/P1040358.jpg
Well, turns out we were missing two bolts
https://img.photobucket.com/albums/v...1/P1040373.jpg
Couldn't find them anywhere, they weren't in the bag with the rest of them and they're the ones you can't get to when the G260 is bolted to the motor, so no flywheel installation or anything.
As a side note, I noticed M20 and M50 flywheel bolts were identical. Exactly the same.
Basically most of the day was spent pulling my hair out trying to figure out a way around the brake booster problem and trying to find those two oil pan bolts. Then I tried to reset the control arm bushings for more frustration and got nowhere. Need to get a thread chaser for one of the bolt holes, hopefully that will make it okay because otherwise I've got to go through the floorboards, and that's no fun.
https://img.photobucket.com/albums/v...1/P1040374.jpg
https://img.photobucket.com/albums/v...1/P1040372.jpg
Going to pick n pull today, hopefully I'll find an E32 booster/MC or something.
MorpheusZero Oct 29, 2009 05:19 PM
So here's the yield from yesterday at pick the part
Got everything plus the C101 harness connector (that I need to make an adaptor for the M50) for $130
Glovebox in decent condition (on top of the old one that I had sitting around in my room because it was broken as fawk)
https://img.photobucket.com/albums/v...1/P1040382.jpg
E32 B35 brake booster and MC with the weird "neck" design
https://img.photobucket.com/albums/v...1/P1040383.jpg
And a nice crack-free dash
https://img.photobucket.com/albums/v...1/P1040385.jpg
After I cleaned it up... now there are a few places that I scrubbed that seem to be discolored, maybe I need to treat the vynil or something.
https://img.photobucket.com/albums/v...1/P1040388.jpg
That's it so far, now it's up to date. Car's in Buellton, might be able to make it up there next weekend if I'm crazy enough.
M1RAG3 Oct 29, 2009 05:25 PM
Nice work...you have definitely put a lot of time and heart into your build and for that you deserve respect
LA02MAX Oct 29, 2009 05:25 PM
Damn, I didn't even know your max was totalled! Very nice E30, though! I, too, am spending way too much time and money on my E36 325is! It was supposed to be just a DD, but it's turned into so much more. Can't wait to install all the new suspension bushings I have; mine are all reeaaaally blown. And you're right about the shifter bushings. Those made a massive difference in shifter feel; quite unlike my maxima's did.
What are your future plans with it? 5-lug and nicer wheels needs to be on the list :) (Yes, I'm evil and trying to make you spend more money). I hate the basketweaves that came on my car, but they're better than bottlecaps. :P
MorpheusZero Oct 29, 2009 05:47 PM
Thanks bud. :thumbsup:
Yeah, was awhile ago. I can honestly say excessive understeer killed my max. :(
You don't know the MEANING of blown suspension until you've driven an E30 maintained by a woman :D it will all be replaced soon enough though.
Actually 5 lug setups are $$$$, and there are plenty of 4 lug wheels that I'd like. Personally I've got a line on some 15x8 Kosei K1s
https://img.photobucket.com/albums/v...Picture094.jpg
Right now I've got a set of bottlecaps with all seasons and a set of 14x6.5 basketweaves with RT615s I picked up on the cheap. Not sure if I'll have the $$ for the Koseis or if the guy will even want to sell them any more when I'm ready to buy (he went 5-lug).
I'm also piecing together a GC coilover kit with shortened Konis (and probably some camber plates). Not sure if I want to go 5-lug yet, but after this I'll probably chill out for awhile since I'll be back to school-mega-broke mode.
LA02MAX Oct 29, 2009 06:42 PM
Thankfully this hasn't happened with me yet...I do drive pretty psychotically... You had a really nice setup, too, with the SFCs and all. I actually rarely understeer..most of the time the rear tires break loose first and it's pretty scary in a FWD car. lol.
Yeah my car's at 198k right now and aside from the struts I just replaced, not a single part of the suspension has been touched...it's pretty bad, lol. Aggressive lane changes are noooot pretty.
mmmm Kosei K1's. I have my eye set on those as well. I'm not gonna lie though, an E30 lowered correctly on basketweaves is pretty damn hot. I hear you on spending too much, though...I haven't bought anything for a couple months cuz I made myself pretty broke before school started this semester on all the crap I bought for that car...most of which I don't even have time to install! lol. Cheap mods FTW, though. I did what you did and painted all the black stuff and used forever black on the side mouldings. Car looks 10 years newer.
maximized98 Oct 29, 2009 06:53 PM
Wow you have done a lot of work to it so far. Those are sure some fun cars to drive. Congrats on the work, I know you cannot wait to enjoy it
bigpopaj369 Oct 29, 2009 07:04 PM
wow man what an awesome build nice work!
DrunkieTheBear Oct 29, 2009 09:29 PM
God I am so turned on by your car.
DrunkieTheBear Oct 29, 2009 09:30 PM
if you repaint it in black, I would really hump it
MaxiNone Oct 29, 2009 09:35 PM
not bad, i'm thinking of getting an E30 aswell. are they as hard to work on as i've heard all euro cars are?...
Conrad283 Oct 30, 2009 06:25 PM
Kudos on the build ... Pretty involved, but it'll all be worth it in the end.
EnervinE Oct 30, 2009 08:15 PM
How much did the stock flywheel weigh/how much material did you get lopped off? I'm planning on getting a stocker resurfaced for my 5spd swap so I'm :reading: a bunch about it.
MorpheusZero Nov 1, 2009 12:57 PM
Yeah, I loved how it handled with all of that. I'd get the rear to come out just enough, but without lifting I'd never actually oversteer. There was a moment or two I've been sideways at about 80 though, that was fun ;)
I only painted one side of the car actually :hide: I kind of wanted to do it the "right way" on the other side and remove the trim, we'll see when I get around to it.
Fun like you wouldn't believe. :) Even fun to ride in.
I'm waiting with baited breath.
O RRY? I really like the lines of the car, but in terms of modded sexiness it's pretty tame I'd say.
No. E30s are nice and simple.
Thanks. And let's hope so. :thumbsup:
Stock it was about 18lbs, he took off around 6lbs. I got a good deal at $100. Generally machine shops charge about $65 an hour, and it's about an hour to shave a flywheel and another hour to balance it. Sometimes more complicated (dual mass, etc) flywheels can take longer. I've never held an A32 flywheel in my hands so I couldn't tell you how simple it was, but I'm pretty sure it's a single mass, and it's a similarly simplistic design.
Should be noted that resurfacing and lightening are two different things though. Lightening is removing as much non-friction material as you can, and resurfacing is shaving down the friction portion until it's even. Resurfacing generally takes a machine shop about an hour, $65ish.
Good luck.
Nrw Nov 1, 2009 07:50 PM
You have great taste. Keep up the good work.
DrunkieTheBear Nov 1, 2009 08:29 PM
you got me looking at E30 M3's :hide:
If one was close and under 15k...the GTP would be gone in a flash...seriously
MorpheusZero Nov 2, 2009 09:33 AM
Will do, though there won't be any work done until this weekend.
Haha, M3s are awesome, but they're also a 4cyl. Go test drive a 325is. The sound of an M20 basically the auditory equivalent of sexy time with Scarlett Johanssen. Then you get a chip and injectors and Scarlett's a screamer.
MrDicks95SE Nov 2, 2009 04:58 PM
good god Nate... still working on this thing?? :noes: good luck dude.
btw, the Koni's are just fine... loose in the housings (a cut up 7up can fixed problem)
MorpheusZero Nov 2, 2009 06:31 PM
:werd2: going insane having nothing to drive. It should all come together in the next week or two.
Awesome. Thought you said they blew out awhile ago? Glad to hear they're still truckin'.
Funny though, I never had any problems with rattling or noise in 'em.
MrDicks95SE Nov 4, 2009 09:59 PM
yeah the lower bolt holding em down was loose too. needed another thick washer. done done and done. just wish i had an alignment and camber plates.
id go insane with nothing to drive, public trans sucks here. i couldnt imagine how bad it is up there...
MorpheusZero Nov 5, 2009 12:44 AM
Huh. I didn't torque the lower bolt down all the way because I had to cut it down a little and didn't want to strip it. It worked fine for me as long as I had the GCs, so for quite awhile.
Seriously I love the E30, tooling around in it was fun even with a motor in the trunk. I need something to drive even if it's just to get away from **** (and go grocery shopping), having nothing is pretty gay.
But like I said, fingers crossed, should be done soon. :D
MrDicks95SE Nov 5, 2009 02:51 PM
u should turn that thing into a track monster. gutted, caged, koni.GC, fuel cell, recaro's, takata 4pt, etc etc. it's already torn apart... :grinno:
Professor Nov 7, 2009 05:32 AM
I love all the Info and Photos !
MorpheusZero Nov 8, 2009 11:22 PM
Alright, did a lot this weekend. Here she was again, waiting for me.
http://i958.photobucket.com/albums/a...p/P1040390.jpg
I got started repairing the threads for the control arm bushing bolts, here's the tap after going through one of the holes. Shavings-a-plenty.
http://i958.photobucket.com/albums/a...p/P1040392.jpg
After re-tapping both holes I got the bushing on in 10 or 15 minutes:
http://i958.photobucket.com/albums/a...p/P1040447.jpg
Then I got working on the brake boosters. Here's the original booster:
http://i958.photobucket.com/albums/a...p/P1040397.jpg
About 5 1/4" from firewall to the center of the pin hole.
And here's the E32 booster, I removed the nut and backed the coupler up all the way on the threads to make it as short as possible.
http://i958.photobucket.com/albums/a...p/P1040398.jpg
5 3/8". I tried it like this, it fit with some ingenuity but it had preload (with the brake pedal in the non-depressed position it was loading the booster) and I wanted to do it right.
MorpheusZero Nov 8, 2009 11:23 PM
The E32 coupling bracket worked fine with the E30 pedal and pin, just used some washers for a tight fit.
http://i958.photobucket.com/albums/a...p/P1040400.jpg
Turns out, though, that the E30 coupler fits on the E32 shaft just fine. So here was the final setup, plenty of room for adjustment and I didn't have to worry about loctiting it so it didn't back out.
http://i958.photobucket.com/albums/a...p/P1040410.jpg
Booster's in the car, connected the brake lines to the MC, cut the little nubby for the clutch master cylinder and connected it.
http://i958.photobucket.com/albums/a...p/P1040418.jpg
Great, I've got to use my old pilot bearing. Check out how much bigger the inner race of the one I ordered is--must be some discrepancy in part numbers or something.
http://i958.photobucket.com/albums/a...p/P1040404.jpg
So I cleaned the old one off, cleaned and heated the center of the flywheel and stuck the sucker in there.
http://i958.photobucket.com/albums/a...p/P1040405.jpg
Here's the clutch and pressure plate
http://i958.photobucket.com/albums/a...p/P1040406.jpg
Brakekleen'd em up
http://i958.photobucket.com/albums/a...p/P1040407.jpg
On goes clutch and pressure plate (centering the clutch was real fun)
http://i958.photobucket.com/albums/a...p/P1040408.jpg
It was about 1AM and the old cherry picker was gone so I finished off the night with a new tie rod.
Still can't believe these things are 6 bucks when the E30 plates are 1
http://i958.photobucket.com/albums/a...p/P1040401.jpg
There, had to use vice grips for the final tightening, used loctite 242 for the hell of it.
http://i958.photobucket.com/albums/a...p/P1040402.jpg
