zero2sixtyZ's 5.5 replacement...
You embarrass me.
is a 335i coupe. The 5.5 reached the end, it was time to call it quits.
Details:
2007 335i 6MT, Black Sapphire Metallic on Black Dakota leather. Sport, Premium, Cold Weather.
Mods:
Engine/Drivetrain:
- MHD Stage 2+FMIC 93oct, linear throttle flash tune
- BMS DCI
- VRSF stepped 5" FMIC
- VRSF 3" catless downpipes
- CDV delete
- BMS clutch stop
Suspension:
- Fortune Auto 500 Black Edition coilovers
- Swift coilover springs 8k/12k
- Koyo radial bearings
- M3 rear lower camber links
- Powerflex rear upper mounts
Wheels/Tires:
- Advan RS Dark Gunmetal Metallic 18x8.5 (F), 18x9.5 (R)
- Michelin Pilot Super Sports 235/40-18 (F), 265/35-18 (R)
Exterior:
- OEM Performance grilles
- JBSpeed painted reflectors
- 35% Suntek tint
- GP Thunder 7500k AE & fog light bulbs
- OEM LCI taillights
- OEM Performance high-kick CF spoiler
- Osram Xenarc 66144 CBI D1S
- OEM M-Tech front bumper, w/ Xpel clear bra
- OEM M-Tech rear bumper + 335is diffuser
- Rho-Plate license plate mount
Interior:
- M-Sport shift **** and E-Brake
- 3M 1080 Brushed Black wrapped trim
- AirEnabler Apple AirPlay w/ X-Fi Go DAC
- TopGearSolutions interior LEDs - OEM brightness
Fluids:
- Brake: Motul RBF600
- Differential: Motul Motylgear 75W90
- Trans: Redline D4 ATF
How she sits currently:
First day of ownership:
At the wash. Don't worry, only using the water there.
Parked next to S/C S2000 and single turbo RX7.
Hopefully more pics to come soon.
And yes, I will always miss this. There is no substitute for a VQ in a tunnel:
When she was at her prime, sigh...:
Details:
Mods:
Engine/Drivetrain:
- BMS DCI
- CDV delete
- BMS clutch stop
Suspension:
Wheels/Tires:
Exterior:
- 35% Suntek tint
Interior:
Fluids:
+1 good replacement car for sure and a heck of a lot better aftermarket for those as well. The 5.5 was an awesome car back in the day but as the years roll on there are certainly better and newer cars to tinker with. I plan on getting rid of mine as well next spring
Ah, yes. That does look good. I saw that also but wasn't sure how flexible it was and how hard it would be to wrap around tight edges compared to the other stuff.
Have you considered the Msport pedals or covers also? Adds a nice touch and flows well with the other pieces.
Congrats on a fun car to play with. Your Maxima reminded me of how mine used to look with the Tracks and kit. Still miss it, but with cars, when its time to move on its time to move on.
You embarrass me.
Thanks Puppetmaster! I still remember how your 5.5 looked. The 245 width S-Drives on the Tracks you had sold me. I wanted that look. Sigh, I'll miss the Max a lot, but hopefully can add some of the same taste to the 335.
You embarrass me.
He converted from twin to single recently, but has had issues tuning. Last I heard he couldn't rev it over 5000 rpms, and still put down 380whp. Once he gets it under control, he should be able to do the full 9.
Hmm... good luck finding anything but dbags and daddy's money on the bimmer forums.
You embarrass me.
Haha, thanks guys. It's the same story as all forums. There are voices of reason to listen to, like Rochester, and then there are people who will ask "do you stance?" You tune The latter out, and abuse the search function for a while.
I will admit I have had the urge to pop my collar, but I am fighting it.
Well, the 335 has a head start in the power department for sure, lol. Looking forward to seeing any mods you have lined up.
You embarrass me.
Update:
Still no proper pictures, but some "small" progress:
Samuel1021 and I loafing:
Car is finally running an updated tune. In the E9X community, ECU flashing went open source. No cost for a utility + specific cable. Used the new BimmerBoost Flash utility to upload the BMS JB map. From previous dynos, should expect a 80whp/100tq increase and much stronger midrange.
Test fitted my friend's Performance CF spoiler. Definitely want one now:
Went to the same place that did the tint on the Maxima. Solar Solutions in Bedford, MA. 35% SunTek Carbon all around.
Started on the trim wrapping... didn't like the 3M dinoc stuff. Covering the wood trim in 3M 1080 Brushed Black vinyl.
No pics yet, but GP Thunder fog light bulbs swapped in, and hoping to either paint black or replace the lower grilles this weekend.
You embarrass me.
After helping Samuel1021 with his on the G35 per DIY from myG37, I'll be ordering some 3M Gloss Black vinyl as well to do the window trim.
Also, swapping out the rear tires for Pilot Super Sports in 265 width this week. Little bit of a wider patch will definitely help with traction.
Once those are done, I should be good for Fall... then to start setting aside play money for M-Sport bumpers and power mods.
You embarrass me.
I purchased the smallest amount to play with at first, and will be buying the rest from a local shop.
Then a few weeks later I installed a set of Eibach swaybars, and understeer just disappeared entirely. If I attack a highway ramp now (with the traction control off) the car will drift before the front end gives. No understeer, no oversteer unless I intentionally kick the back end out... just drift. It's an amazing thing.
My fronts won't pass inspection anymore. But just a few more months, the snows go on and I'm done with them.
You embarrass me.
At the time, I was very worried about increased understeer, because the G was predisposed to plow when pushed hard. So having sticky PSS in the rear, and the OEM Bridgestone Summers in the front, I was worried... but it just didn't happen. In fact, the opposite happened, and there was more control.
Looking forward to the PSS'. Hopefully I can have some fun with more grip and better ride comfort before the season is out. My rears wouldn't pass inspection, and the tune made the wear worse... correction, my constant acceleration testing has made them worse.
Bridgestone RE050A. Three season, maximum performance tire. It's good rubber, but the tread life is only 10k to 15k in normal, real-world driving. I barely got 10K out of the rears. And as good as it is, the PSS is better.
As for feeling "squirmish" (LOL), like I said, there was a fair amount of understeer. But that all went away after the swaybar upgrades. Which is funny, in a way, because the RWD-Sport G already has beefed up swaybars, so you can imagine how sloppy the base-model G is.
It's all relative, though. Because the base model G still handles better than a modified Maxima. And so on and so forth...
You embarrass me.
Meaty! I believe we can upgrade to the M3 convertible sway bars. Will need to look into that after the LSD... Not the drug.
Pic from this weekend right after install and a 4 hour drive to NY... 265 width Super Sports in the rear just installed. Tire p0rn.
And on another note... GD your wheels are filthy. Before it gets too cold outside, be sure to wash, clay and wax those rims.
You embarrass me.
The car was washed five minutes after this picture, but yes, these damn OEM pads dust badly.
Next Spring will be awesome, though! With solid tread PSS all around. Can't wait.
Nice ride. You need to upgrade the front bumper or put on an aero lip for a more aggressive look! And at 16psi boost, you may look into upgrading your charge pipe to prevent boost leak, or worse, the CP blowing up. My stock diverter valves started leaking after 4 months @ 15psi.
That's what this car misses the most... BMW really messed up by putting an open diff on this car
Which one are you thinking of? Quaife? M3? Wavetrac?
They do dust really badly! I can never keep my rims clean, but they grab on so well though.
... so you picked another black car hey! So that's true what they say, once you go black, you can't go back!
You embarrass me.
CP: I am researching charge pipes and BOVs at the moment. Looking for the best option, as the OEM one will not handle the boost.
Definitely trying to source together the M3 one. I've heard noise complaints with the Quaife, and I'd like to have as many OEM parts as possible. I know the driveline will need to be mish-mashed, but if I get it right, I think it'll be worth it.
Sadly, I didn't want the black one. I originally wanted an Alpine White, Space Gray or Sp. Graphite on Coral Red, but this was is better condition than the others.
Moonlight White was my second choice. And while I love the look of a 3-stage pearlescent color, I dread the day that it needs body work, because it will never, ever match. Period.
Although I have to say, black was a deal breaker for me. I obsess over my cars, and there's no way I'd let THAT kind of obsession into my life. Keeping a black car in pristine condition is nuts. It will consume you.
