- V2 Belt Shredding Fixes
- Differences with Z32 or J30 MAF
- for those looking for turbo piping
- V1 for an 01?
- Turbo piping
- Boosted VG stalling solution.
- Turbo piping
- Would 370cc Venom Fuel Injectors work?
- Funny *** VID!!!
- Going to dyno in a few weeks,what psi did the stock injector max out?
- Turbo too big?
- Problem with my brakes.
- Help,which wire did you hook your WB to the Emanage??????
- Pic Of Stuff Going UNder Hood. (large Pic)
- NC25B1-X kit opinions?
- FS: Vortech FMU
- which wideband
- Fuel Flow and FMU Calculations, Stock and A32 MAF+400cc injectors
- SUpercharger or Turbo
- New toy
- Adventures with no MAF signal
- fs: 95-99 max adapter plate for pathfinder throttle body
- Turbo Feed Pipe for sale
- Wierd clutch issues
- Turbo timer not needed based on turbo???
- Emanage Version?
- might be scrapping the turbo
- How is chris'smax...
- Thank you all.
- hks f-con v-pro
- wtb:cold air intake for V2
- Pics of re-worked piping
- pathfinder throttle body
- 410cc injectors+Z32 Maf+A32 Ecu+4:1 FMU Disc= A Little Rich
- Where can I source a reverse Y-Pipe?
- Perfect a/f ratio?
- New intercooler
- Mounting reverse y pipe
- complete turbo kit
- Any 5th gens with BLUE eManage timing harness?
- 3" Muffler ?
- I think I broke an i30
- Relist of my custom pistons for sale
- VG Turbo with 10:1...
- Mounting Gauge on Steering Column ??
- TRE transmission build is complete
- 0104 (Speed Sensor) ?
- 12 psi on v2
- Dyno numbers
- gauges for s/c?
- Need some help
- NOPI Nationals
- No Hydro.pressure On The Cluth After Boosting! ON MY 1993 MAX. WITH THE VE30DE MOTOR
- Going to the track.....
- Aluminum Griffin Radiator (New Toy)
- charge piping diameter
- Purchased the PLX R500 wideband O2
- Carnal c30???
- Methanol Injection?????
- Need help on boost controller!!!!!!
- bucking and ish..
- FS: JWT-ECU, 96' 5spd
- anyone have any emanage setups they wouldn't sharing?
- I have 3 trannies and going tp prep the internals for cryo who.....
- Supercharger question
- Looking for a V2 Supercharger
- Anyone is ditching their oem foglights?
- Anyone have pics of VQ30DET manifolds?
- My Emanage Ultimate is here!
- 550cc injectors
- New Track Times
- Few questions on maitence
- Advantages of a: Built VQ35 vs Built VQ30
- Walbro & FMU/FPR Install Questions
- S/C or Turbo'd max with 142,000 miles
- how will this turbo perform on a vq30de
- SC Problems
- 00VI or MEVI???
- How Much Boost?
- Maf and nitrous question...
- What are the part numbers for the hex head bolts holding the V2 to the plate?
- V2 Blower and Plate on Ebay
- Supercharger Vs. Turbo
- 01 turbo question
- When will this turbo spool?!
- What are you Using for Cold Air Piping ?
- What plugs?????
- how much??
- WTB Stillen 2.5" charge pipe.
- Supercharger Pros I Need INFO!!!
- Oil feed and return lines
- Emanage Pressure Sensor help: orientation of harness plug
- counting my blessings.. and learned a lesson..
- i can get a supercharger insalled for $700 need help
- Clips of Non-NA max
- Stillen Supercharger. Whats a Good Price?
- jay25 MOD
- Got the Cartech FMU, Aeromotive FPR and Walbro 255:Anything else I need?
- Put the car on the dyno (A few issues)
- WG spring regulated boost question
- 3" Exhaust
- J&S gauge install...
- Just finished SC install!
- AN hose sizes converted to inches
- Oil line kit for turbos - all in one place, inlcuding BSPT fitting for block
- for those of u that want to squeeze a few more ponies
- Green flashing active light on e-Manage
- melting coils
- FS: NYC 3" Ypipe
- Need Help With Fmu Disk
- Blitz blow off valve adjsutment
- Dyno update...should I be dissapointed???
- What is our max oil pressure under normal operation?
- People with MAP sensor for boost referenced tuning, what one do you have?
- anyone know boosted95??
- Why two Blow off valves???
- Track times at US 41 Friday.
- Just Got My Turbo Maxima Back** Need Help
- 410cc Injectors & Z32 MAF is in....PROBS!
- A32 ECU, Z32 MAF, 550 inj and 10psi results
- Custom internals possible for sale
- Grand National Turbo?
- jdm vq30det
- JWT Cold Start - NProbe Data
- BOV and Wastegates
- Where's the missing boost pressure?
- V6P link for FI issues...
- F/S: Calsonic r32 Intercooler (pics)
- polishing a turbo..
- SR20DET swap?
- another 3" charge pipe question
- what do think about that turbo
- Brand new stillen kit for sale
- Dead Spot when Cold !
- Measured 3rd gear thickness of 01 AE LSD - 14.31mm
- V1 rebuild with V2 internals?
- Has Anyone had problems with the VB Mod?
- gauge pod pics
- how much did u guys pay for a turbo
- Thoughts about MAP-ECU?
- Possible for sale : Quaife
- more air?
- VQ30DET and VQ30DE differences?
- FS: Cromex Stillen Piping
- where to buy 4th gen SC?
- Pics of the Engine !!
- JWT ECU, Z32 MAF, and 550's are in....
- Rough Idle when Cold
- Two quick set up questions
- MAP Sensor Code.
- who has achieved torque numbers well over 300 with a SCer?
- just one question: what do i need for 10 psi turbo?
- shops in the northeast
- Is a 100 PSI Fuel Pressure Gauge enough when running a small pulley?
- Turbo or SC?
- What would be the ideal pipe diameter from blower to TB? 3"? 2.75"? 2.5"?...
- Anyone running the Innovate Motorsports Standalone Wideband Gauge yet?
- PVC as charge piping?
- down pipe
- Interesting JWT discovery.
- TURBO OR TWIN TURBO ?????? maxima 95
- thought you guys might wanna know about this site...
- Most basic supercharger setup
- How many hours to remove heads and timing mechanism? Weight of shortblock/crank
- UR overdrive pulley
- Opinions piecing together a turbo kit
- Postion of wastegate
- what clutch should I get???
- s/c tuning?
- solution to v2 kit?
- Good info on vertical flow ICs
- difference between intercoolers
- About to by boosted95s max have some ??
- How beneficial would this rebuild kit be?
- Anyone using a HKS 40mm wastegate?
- Intercooler Depth
- How much did you spend on your FI setup?
- WTF is the problem with my car!!!
- power range with injectors
- Gauging Interest: FS: V1 S/C Plate
- FS: 370cc injectors and weapon r afpr
- Pics Of Jeremykedel's Custom Trubo Setup In His 2k2
- installing fuel pump
- question on vacuum lines
- Hks-ssq
- update on z32 maf on noncharged side
- wastegate spring rate
- dynamic/carbon seal???
- switching pullies
- Quick BOV Question ?
- Manumatic Help
- clucth changes
- EVAP Code with JWT
- intercooler size
- best type of resonator for sound supression?
- Installing a quaife from a 4th gen to a 5th gen trans?
- 91 turbo VG pics
- Greddy's Profec E-01 ...
- Z32 on Charged Side Update
- 550cc injectors from a 2JZ
- Pop! goes third gear...
- Boosted timing?
- what a/r
- 2nd gen + 8 psi = x
- Just a little up date
- Swap after FI?
- for all boosted
- Need Some Turbo Explanation
- JWT ecu/timing question...
- Installing a AFPR....
- Oil Feed + Return Line (make $$)
- Article on tuning with EGT
- looking for used SC for 5th gen
- MAP Sensor Code.
- Problems with Emanage?
- Symtoms of a Bad MAF ??
- The weakest links of the vq
- Stock Shortblock
- I got a laugh outa this. (ebay link)
- Noob to boosting
- 5.0/5.5 gens...PE380cc injectors(used)
- F/S Chrome 3.125 pulley+ gatorback belts
- Why did my base FP drop? MEVI related
- Oil Coolers
- anyone have a S/C on stock parts?
- Plug Gapping ??
- FS: J&S SAFEGUARD
- Xterra Supercharger
- FS: Cartech FMU
- stillen blower parts
- Hmmmmm....i Don't Knowww....
- Got the car back FINALLY.
- Where to buy compressor wheels
- clicking from top of the motor...
- i found a pretty good turbo-to-engine size chart
- 9 lbs boost with 3.125"??
- looking for used 4thgen V2 kit for 5speed
- 4th gen V1 kit to 5th gen kit parts?
- z32 placement question
- Well All my Stuff is in, Problems !!
- EGT and hottest Cylinder?
- Any of you guys need a 300TT fuel pump?
- How tight do you adjust your bov???
- Difference in Z32 Connector
- Ways to test MAP sensor?
- Went to the track for the first time...
- vortech fmu with an afpr??
- sard fpr vs aeromotive
