View Full Version : Infiniti I30/I35
- Side skirt installing method
- How great are these cars?
- New to me - I30 with no history, valve covers, what else while in there?
- Looking for general advice
- 2001 motor mounts - plz help!
- Red film over tails?
- 04 Infiniti i35 W/Nav System??
- Roof spoiler adhesive?
- I35 side skirt hardware
- 2000 I30T Ball Joint Assembly
- 01 I30 Speedometer Erratic
- 2002 Infiniti I35 randomly stalled on road
- Car shut off
- Spark Plug Tube Seals
- 00/01 i30 gauge swap
- SS muffler tips
- Accelerator is tricky...
- Blower Motor
- 2000 I30 four CEL codes + ABS
- i30 sleeper project
- 2000 i30 rear view mirror mounting
- Odd problems with 2004 Infiniti I35
- so who here is planning on getting a q50?
- time for tints!
- I30t headlight assembly replacement
- bose sub finally started to cut out...
- 2000 I30T wheels
- How To: Change 96-99 i30 Fog Lamp
- FSTB help
- cefiro lights
- 6 Speaker Non bose Factory Amp
- Eibach Springs
- Strut tower Bar
- 1999 Infiniti I30 CV Shaft replacement
- I-35 nightmare -
- South Africa Maxima/i30
- Grille for 03 I35
- need to get a CARB sticker for my 1999 I30!
- aftermarket radio antenna
- Dash/console lights
- Got code P2135...
- Ionic Dynamics Rear Window Visor (Pics)
- Exhaust...which one...
- i35/i30 Headlamp assembly
- LED Bulbs...disappointed
- Radiator replacement - 2001 Infiniti i30
- Cat-converter
- Starter Issues? Need Help Please!
- Dash parts needed
- power seat wont work...how do I manually move...
- 2000 i30 dashboard half lit, headlight voluntarily shutting off
- 370z rims on an i35
- How to add a single din and keep factory navi??
- Auto Headlights
- 8 inch or 10 inch sub?
- 00-04 I30/I35 Window Visors Same as Maximas?
- I30/I35 Front And Rear Lips!?
- 2000 I30 Rear Sun Visor/Spoiler/Wing HELP!
- 225-55-17
- have never wanted to murder my car more than i did today
- Looking For: Infiniti third brake light cover
- lights out
- 250+ amp alternator
- Pics are up!!
- please help; starting issue
- Back in the game!
- Please help diagnose this engine sound
- Automatic Transmision Control Module
- I35 brake conversion for 2001 I30 with 16'' stock wheels
- i30 to i35 gauge cluster swap
- How to install i35 side skirts on and i30?????
- i35 or is300
- I30 OBD2 problem
- My 2000 infiniti i30
- CT--- Please help code P1320
- 02 I35 Coils and firing order
- Question About i35 and oil
- i35 mats for sale
- 97 I30t Keyless entry
- Free G35 Center Cap
- LED Daylight Running Lamps
- P1320 and cold-start issues, cheap place to buy Coils?
- New owner of 2003 I35
- Weird Noise when shifting. Trany or other? (with audio) HELP!
- 2000 infiniti i30 a/c problem
- should i have any problems out of it?
- 2008 M35 RIms 18''
- Ses p0445/1448
- 2000 i30 foglight aim?
- A33 Clear Corner/Side Marker Lenses by Klearz
- the infiniti is hurting :( do you guys think its totaled?
- FS: 1999 i30 Touring 5-speed 70k miles
- 96 i30 132km key fob problem?
- boost sensor help...please
- Rear back curtain (2001 infiniti i30)
- What Type Bulb is the Cornering Light?
- Will an Infiniti i35 trunk lid license plate piece fit on a 2000 infiniti i30?????
- my i35, suggestions??
- sound system
- 2000 Infiniti I30 shuts off when put into gear
- Oil Changes-What Interval?
- 2001 Infiniti I30 engine starts but will not stay running at idle
- 6-speed I35 swap, finally.
- Who has done G35 muffler on 01 I30?
- I30t having issues
- Any experience with this grille?
- i30 warpspeed y pipe
- Is my tranny finally failing?
- OEM coils
- Who Has Done HIDs in an A33?
- 01 i30t Shaking
- 2004 trans same as maxima?
- p0443 cel
- F/S 95-99 i30 limited floormats charcoal
- Bad belt squeal
- I35 Cluster Panel Lights went out
- Grindin noise
- Which Exhaust Tips?
- I30 base to I35 headlamp conversion
- Help low MPG
- New Struts
- Can someone measure...
- 04 i35 loud engine
- I35 memory seat buttons not working and don't light up.
- I30 Major Disappearing Motor Oil
- p1320
- infiniti i30 body kit
- Thinking of picking up an i30
- 2000 I30t full size spare question
- i35 Navigation
- Optima Red Top fitment
- Finding a donor transmission
- I30 Bose Radio Interchangeability (1996-1999)
- I35 Center Cap Emblem?
- FM static
- G35 Coupe Photoshoot 12/22/12 | Arman[t] | Carbon Creations | Incurve Wheels
- Bundles of problems
- My BiXenon HID Retrofit Build with LED xB Angel Eyes
- What is this?
- $1,000,000 Color Question
- 2000-2001 I30 Window Maintenance
- LED Tailights (Need pics of them installed)
- Interior color tone?
- LED Tails not working?
- Do the 99 tail lights fit on the 97 i30?
- Buyint items for suspension, need help to make sure I buy what needed
- Can a fuel pump stay on??
- QUick Question regarding the door swapping
- Sorry about the racing thread!
- What is this box?
- 1996 i30 smokes 2011-12 Honda Accord!
- Ambient sensor wiring
- TW: 2002 Infiniti I35 Part Ou
- 04 I35 Speaker installation frustation
- Ignition coils and spark plugs ?? p1320 code
- FS 1998 i30 92K miles Clean title Automatic
- car will not start !!!
- CARFAX Run
- Power steering issue?
- i30ds?
- High beams and Fog lights on at same time
- specs.
- Rear sunshade good for roadrage
- Buying Tires, a few questions. Please Look!
- I35 120k miles coming up soon
- Coolant Hose
- headlight/gauge problem
- 370z OEM Wheels
- Restored headlights
- 2002 Infiniti I35 Xenon Headlight
- I35 Loses Power/ TCS/ABS lights come on
- Pinging...and long term fuel trims
- Solder vs Crimp (also whine noise)
- Turn Asist Bulbs
- New To the board!!
- Really Weird knocking sound... I30 01
- Updated Pics
- Need touring HID headlight, can I use Halogen version and swap parts?
- 96-99 i30 spoiler
- i saw this parked up the road from my house
- just bought an i30t for $900
- How are the Infiniti's lately?
- After market headlights for 2000 i30t
- help! no turn signals
- P0420: Which ECMs Need Reprogram?
- Persistent transmission issue 03 I35
- P0720 .. Which sensor?
- Can We Make A Trunk Valet Switch??
- AC Pressure discrepancy?
- I35/Maxima dual exhaust
- Infiniti I30 oil dipstick?
- HID installation. Headlights/Fogs, PICS
- Aftermarket Headunit in my i35, but problems.
- jcwhitney suspension products
- Newbie to the Forum from Monterey MX.
- check out my i30 thread
- Battery keeps getting drained while running
- Cam position sensor replacement
- Front End Bouncing After Jacking Up
- Paradox Systems is closing its doors.. Selling items
- I30 Trunk Mat
- New I30 owner, suspension question
- Help please
- What is a good aftermarket GPS to replace the 2004 OEM nav system
- I35 Clock Light Bulb Replacement question
- Loose Steering/Play
- NEED ADVICE ASAP (headlights)!
- Question: Is this the OEM grill for I35?
- New Member with an i30
- My I30
- Does the I35 Navi package have heated seats?
- Rear Window Switch LED Size
- Power lock problem for rear driver side window
- 99 I30 corner re-wire
- 2000 I30 exhaust question
- need help fellow i30ers
- Color matching
- Any other 1st gen I30's under 100K?
- What is wrong?!
- LOST ALL KEYS TO CAR , PLEASE HELP !
- The $9 Lip
- Looking to TRADE my oem headlights with angel eyes to stock
- Umnitza Orion V2 Angel Eyes Review
- Air intake for "Middle East" Nissans/Infinitis?
- Weird car problem on start up
- Alternator Pivot ( the longer bolt ) bolt size and length.
- Rear Parcel Cover to Take Out Third Brake Light?
- Looking @ an I30 - Opinions?
- Bought myself an I35..Pictures!
- Car audio question ..
- Wondering which o2 sensor to replace
- Halo headlights on i30
- Newbie purchasing used I-35... help me out.
- 2000 i30 and 2002 i35
- dimmer not working
- Maxima v I30 transmission question
- 2000 i30 headlight swap to hid
- Weird car problem
- 200,000.
- Can't find clear side markers anywhere!
- 2001 i30, squealing sound at times.
- Best Resonator for my I30?
- 2000 i30 Radio not working. Fuse?
- running power wire to amp location
- Koni Yellow Stiffness Setting
- Cefiro Dash Kit with single DIN stereo?
- '01 "blu" eye-30 retro-ish projector job
- Engine pinging around 2000 RPMs
- Who here has replaced the factory NAV / Bose with Aftermarket? Lets see some pics
