View Full Version : Fluids and Lubricants
Pages :
3]
- Mobil M1-105 oil filter
- Redline Oil
- Found gl-4 gear oil But ....
- Coolant for our max?
- SeaFoam - how often?
- How many liters of brake fluid would i need?
- Leaking Tranny!!!
- Advanced Q-buy 1 get 1 free!
- which transmission fluid cooler to buy for 01 max?
- mobil 1 80w90
- M-105 = No VTC Grind?????
- which antifreeze and red line water wetter
- Just made the switch to synthetic @15k miles
- Fluid Flush, Just a nightmare away from SCANDAL!!!
- help needed!!!!! for 2001 Maxmima
- Engine Clacking
- Found some GL-4
- Question About Ethanol
- Autorx on tranny....now it slips
- Exactly When to Check the Oil ? What's Wrong with Overfill?
- Mobil1 M1-105 vs. M1-110
- Where to find Mobile 1 synthetic?
- 2002 Original Coolant = BAD??
- Oil - Syn to Dyno and Dyno to Syn = Problems?
- Questions about BG44K and Redline MT-90....
- Wallmart Supertech Full Synthetic
- 5.5 gens step in
- Egr Valve - 2000
- VQ30, using only 4 quarts...
- Anyone want to comment on my UOA?
- AutoRX vs...
- Used Valvoline Power Synth Power streering fluid
- Seafoam...weeeeeee!!!
- Just finished a tranny flush with Amsoil ATF...have a few questions
- Mityvac to bleed brakes?
- Clutch/Brake fluid weirdness
- AutoZone sale on german castrol!
- where are the jack points of 1989 maxima
- Chassis Lubrication Info please
- Penzoil Platinum?
- power steering fulid for 89 nissan 240?
- Want to know how old YOUR mobil 1 is?
- brake fluid
- Matic D-4$/qt?
- How is my OCI?
- Rust Bullet?
- Anyone tried Amsoil TRO (Series 2000 20w-50)?
- synthetic oil...............
- 215,000 too late to switch to Mobil 1???
- For all you Chevron lovers
- $160 for tranny flush or $89 for drain and refill
- 6th Gen ATF Fluid Question
- If you don't remove the engine block drain plugs when doing a rad flush...
- Any One used Neo Gear Lube 75w90 oil expensive...
- Q: Any One using Mobil 1 75w90 tranny fluid?
- can you change oil filter but not the oil?
- Mixing Motul and Mobil 1 oil
- Oil Companies Profits on Premium Gasoline Are Down
- OEM coolant part #
- auto tranny fluid specs
- Anyone use ATE blue ...
- Switching from Conventional Oil to Synthetic
- Auto Tranny Flush
- Kendall synthetic oil
- Advance Auto Parts Oil Filter
- any clues on what shock therapy those?
- Power Steering Fluid - shelf life ...
- Attn: those familiar with Amsoil synthetic manual tranny fluid!
- Tranny fluid
- Want to bleed my brakes - which speed bleeder do you recommend?
- Will changing oilFiler cause spill of current Oil?
- Coolant Level
- 4 speed auto's use dextron III Fluid, right?
- Differential Oil ??
- Tranny fluid
- Coolant flush ...
- Lucas products in my engine..Good or bad?
- Nissan Long Life Coolant
- techron fuel injector cleaner ok?
- Gear oil @ 10k miles, PICS... Opinions please?
- FRAM Oil Filters
- octane booster
- Amsoil XL Synthetic? How good is it?
- Please tell me that my Power Steering system is not gonna die.
- Switching to conventional motor oil after 120k miles on synthetic?
- Tranny Fluid in New Car
- SOONR's AutoRX
- royal purple
- Motul 5.1 brake fluid
- fuel injectors?
- getting rid of used oil
- Anybody switch synthetic brands?
- wow~ first time!
- How oftern do you change MT fluid?
- Question Guys
- Oil analysis
- Was it Matic D?
- Danm - Overfilled Battery with Distilled Water
- Thoughts on OCI with Amsoil 0w-30 and Ea filter?
- 6th gen oil question
- Mobil 1 oil filter sale
- Proper DIY procedure for flushing cooling system?
- flushed my engine today
- What interval do you guys get oil change?
- Oil
- Throttle Body Cleaner
- Choose a grease for starter, plz.
- okay so... 9E000 sucks, whats the updated filter for VQ35s?
- Safe to switch back to conventional from synthetic for Auto-RX?
- Radiator Cap
- Mobil 1 Extended
- Octane booster
- PSI for A/C system
- Does the VLSD tranny take different fluid?
- is it bad to over fill the coolant reservouir tank?
- Castrol GTX High Mileage Oil?
- oil change frequency for hway miles
- what is the best way to get off the Oil filter???
- Higher octane=better gas mileage?
- Anybody want some Green German Castrol?
- whats the best synthetic MTG on the market
- Q: Changed oil mobil 1 3 1/2 qts 5w30 and 1 qt 10w30 accidently
- Does this stuff really works? Lucas Transmission Fix
- How much tranny fluid does my tranny need?
- Brake fluid question, contaminated or not?
- Any *tricks* to remove the oil filter? (w/o getting oil on hand)
- How to Brk fluid and power steering
- What are my options for changing my trans fluid?
- Using nondistilled water in a coolant flush
- Motor Max
- Anybody using re-refined motor oil ????
- Any good over the counter air filters besides OEM?
- Transmission Flush - 30K miles ??? SPECIAL FLUID ???
- 15208-9E000 Price
- Big problem after MT oil change
- How Do You Change The Oil In Your Max?
- looks like 15208-9E000 has gone cardboard!
- 5 speeds! Clutch oil recommendations
- Thinking of doing an engine flush
- where are my spark plugs?
- Royal Purple Max Gear
- 5w-30 versus 10w-40
- amsoil vs mobil 1 oil filters
- How much oil for my VQ30DE 5th gen?
- question about penzoil ATF...please help!
- tinking going cheap on oil, lol
- amsoil engine flush
- I asked an expert about doing a TRANNY FLUSH
- is the filter 15208-00001 = 15201-9E000?
- Mixing M1(syn) ATF with conventional ATF
- Mixing syn and dyno
- How often do you clean your K&N?
- Fluid Changes
- Best motor oil for my VQ30DE?
- Best synthetic 6-speed lube?
- how often we have to do fuel injection cleaning?
- Hey Is royal purple max life 75w90 any good
- Lubricating windows
- Smoke...
- Motorkote oild additive
- Should i change my tranny oil?
- Mixing oil
- 1. GL-4 85w-90 2. GL-5 and EPA???
- sparkplugs?
- Hopefully changing oil soon. Need some help.
- German Castrol Batch Numbers
- German Castrol Strikes Again!!!
- Clutch Fluid & Reservior
- how much seafoam
- New German Castrol?
- 100 octane gasoline for 6th Gen maximas
- Question in regards to a fluid change job
- unusual sound from headers-help!
- Redline Fuel Treatment?
- BRAKE fluid question for 4th GEN (using valvoline one)
- Castrol High Mileage Legends In Motion Club
- loong term storage questions
- Gas Type
- Fuel
- Watter Wetter
- ATF - which oil?
- Synthetic oil in 6 speed manual transmission
- Redline Fuel cleaner?
- Fumoto Valve
- 122k switch to synthetic?
- Premium Gas
- redline or amsoil????
- Sunoco super 93 VS. mobile 93
- 1st oil change via the dealer..
- 3rd Gen ATF Recommendations
- PS Fluid for 5th Gen
- Rebate for free Valvoline Max Life
- Tranny Flush = Cold shift problems?
- Dot 4 brake fluid.
- MAF CLEANER SPRAY!!! Finally!
- castrol dexronIII/Mercron
- what does tranny fluid look like?
- Is AutoRX supposed to lower your idle?
- lucas heavy duty oil stabilizer
- What oil should I use for high mileage?
- castrol gtx or castrol high mileage
- Gear oil-syntec a must?
- got wrong oil in
- need to confirm
- Getting smoke during accelleration????
- alternative to BG-44k that is supposedly just as good but cheaper
- Changing most of my fluids?
- royal purple atf testimonial
- Thinking to change OIL...Any suggestions?
- What gas do you put??
- Steel Seal
- How to clean aftermarket air filters...
- Can you I.D. the difference? Dino/Synth
- How much oil does your Max burn?
- Need advice on an oil filter for a 2004 Nissan Max SE
- recommended lubricant for rack?
- cleaning tune-up
- Egr Cleaning
- Should you wait before going synthetic?
- Lucas oil?
- Fuel Injector Cleaner for Maxima?
- Royal Purple ATF???
- 2 Spoons Of Ammonia in the washer fluid?
- transmission Fluid ?????
- Stock filter sucks
- High Mileage Formulas
- Washer fluid frozen?!? WTF!!!
- Lower Sulfur Gasoline in the USA – Soon
- New set of rear calipers and rotors all around
- What kind of oil do you use
- A/T transmission oil drain plug
- 6th Gen oil filter size, have u up-sized
- Auto RX- how many bottles?
- noticed something strange (auto-rx)
- Nissan's oil filter I feel SCWD!!!
- Mobil 1 or Royal Purple?
- Problem Rear brake could be by brake fluid change
- jiffylube coolant service good or not?
- I was thinking about changing my OCI's
- auto rx in auto tranny
- What brake fluid do you recommend??
- why would this happen?
- having touble with oil pan nut
- Radiator Flush and Fill
- interesting info
- BG Air Intake Cleaner
- 6qts of pennzoil Full synthetic motor oil + oil filter for 2.94
- 5w-40 syn
- anyone know where to get amsoil mtg manual tranny oil
