- RAPID BACKFIRING sound
- SES Light Code 0414
- whats the best place to shop for max parts
- Stock alarm system rewire question
- Max turns off when turning on head lights???
- Riddle me this homeslices - do I have bad tires or bad clutch?
- stupid question
- anyone know about 97 maxima A/C?? asap plzz
- trying to isolate cabin noise
- Replacing Starter
- Shift Light
- cutting out fog light inserts in 95/96 bumper
- high beam light is always on!!??
- Is it my input shaft bearing or release fork?
- Did I cooked my front brakes?
- Is locking differential the same as VLSD ?
- vortech supercharger
- I need suspension help!!!
- How much do i expect to pay?
- Steeting wheel 97 into 96.
- Crankshaft position sensor or Camshaft...
- tie rods
- Need Help!!!!!!!
- Clutch Choice????
- NEED ADVICE -- Hit a 2 foot-deep puddle...
- 99 Exhaust upgrade... need to replace more than anticipated...
- 2000 Cluster in 4th gen?
- CEL code P1168
- Changed pads, Brakes like a 2ton truck on civic drums
- O2 Sensor Angle and Reading.
- Car making noise in IDLE
- What color headlight housing?
- clutch feels wierd
- CAI into fog light area?
- so one of my headlight bulbs burnt out
- 95-96 maxima hks muffler fits 97-99?
- Maxima R34 Type Dual Reflector Headlights INSTALLED
- infiniti i30
- Lacking power @ mid to high range
- bumper covers and hood, ebay?
- Help Please: Trunk lid needed!!!
- engine bay grounding points
- what fluid is located above...?
- PR CAI installed on a VQ35 4th gen ***PICS***
- Need Super White/bright headlight bulb
- Please tell me it's not that bad......
- weird brake thing
- pattern failure for warped rotors?
- Looking To Do A Tranny Swap
- Smoked Tail lights
- angel eyes??...opinions please
- suspension suddenly rough
- Max won't turn over. Need a Max Doc. Help!
- Axel boot torn on both side… should I replace rubber boots or replace entire axels?
- Rough Idle in Drive and Reverse
- Popping/knocking noise...no one knows the problem
- eibachs/tokico illuminas vs. ksport CO
- what to change on maxima 98 SE?
- Changed front spark plugs no problem but changing the rears was a failure
- My new max with changes i've done
- Axle Replacement Tips - Supplement
- Huge mpg Loss
- Banging, ratlling sounds from under my Max
- Tranny Cooler
- TPS check questions
- Intake Air sensor
- made a couple short acceleration videos of my max
- Interior lights.
- Did a tranny flush and oil changed today....Car runs much more smoother
- 96 lack of power. please help
- True Yellow Foglight Conversion [Mini Write-up]
- Just Installed Addco RSB on my 4th gen and the difference is like night and day!!
- 97 rear bumper on a 95 PIC REQUEST
- Getting Max to control Craftsman Garage Door
- EVAP Canister Replacement
- tranny parts
- Ran into some big problems
- Fuel pump issues?
- Any reason besides a bad cv seal?
- Problem with brake lights
- Best of?
- High-Flow Cat...
- Ebay Cold Air intakes. Does anyone have them?
- Thinking about a transmission swap
- side airbags
- Balancing Issues
- Bose "theft codes" ??
- Suspension Question
- wide rim question
- Sticky Clutch Pedal--
- Insane understeer when wet w/Kuhmo Ecstas?
- Cruise control tops out at 89, any trick around this?
- What's the best muffler to go with
- Transmission clunk? Can anyone identify the problem please?
- Used Valvoline Power Synth Power streering fluid
- Help! Car Wont...
- Belt Problem. Need help.
- need pic of gunmetal wheels on stering mist
- price suggestion
- Package came in mail today.....Pic :)
- how much can i get for my 99? 86,xxx miles
- suspension advice
- $1500 bad viabrations..i hate my tires..what do i do.
- Slipping 2ed gear
- Front lip only??? Yes or no
- Tomorrow's Project (4 pics)
- I need a "There, there." Carwash and antenna. :(
- got 30mpg on a trip yesterday
- PCV/Oil Catch Can. PICS !!!
- anyone here warranty their tokico illuminas?
- What exhaust do u think wil sound better?
- Vandals Snapped my Antenna
- Will headers lean out my engine?
- Ignition switch?
- misfire
- factory car alarm doesnt work
- p0440,po446,p0448 - damn EVAP codes
- Car Was Hit...so i have some questions.
- black or clear bumper lights?
- If the rear main seal was bad
- ebay find
- EU, JWT w/ mevi prog.,or nitruos?
- how much for 1997 SE with 170,000
- P1168 = 0308 = Closed Loop...Now what???
- Cardomain
- Do I need to regrease starter magnets?
- Canadian fits Cali or Fed specs?
- New belts = squeaking?
- Remote window roll-down into remote start?
- Anyone has experience with this kit?
- NJ Inspection strikes again
- bye to everyone
- Best Place to buy Parts
- Angel Eyes?
- Passenger Airbag Removal
- idle problem
- Passenger side axle, one or two pieces?
- retrofit...what do u guys think?
- Part Out
- How to test drop resistor?
- Mul-T-Lock Gear Shift Owners lend me your ears....
- Leaky Injector..Lower O-Rings ??
- One warped rotor: just get it turned?
- Help with Sig Pic
- auto shifter
- Photochop Please
- 5 Speed Tranny Question...
- Serpentine Belts
- Replacement filter for JWT Pop
- Parking brake sticking--HELP!
- Annoying Rattle under the Dash
- Are the rear caliper brackets the same as the front?
- EGR install labor?
- Fog Light Question
- are budget y pipes prone to flex section failture?
- So I bought them...
- Factory Service Manuals for Download: 1995-1999
- Dual Projector Project!!
- Is my auto tranny getting old?
- DR mod while auto shifting?
- how do i reset 4th gen ECU?
- anyone know how to install headers on 4th gen?
- Ticking noise from engine bay.
- Valve ticking is driving me nuts.
- battery not charging
- help all 3 o2 sensors replaced still showing sel
- installed cefiros on my car
- Real Quick ? about Catback Installation
- quick question
- Cleaned IACV (Pics) + some questions
- Bosch Plat vs NGK Plat Plug?
- Car stalled.... wtf?!?!
- Trans codes 0504 and 1105?
- Need input from org... springs problem.
- Pic Request v.PR CAI
- 95-99 Nissan Maxima R34 1pc Chrome Headlight 96 97 98
- egr codes question....
- What kinda dustboots i can throw on KYB GR-2
- Help please! can't work out why car is whistling/whining... :(
- HELP! My park lights arent working
- My fog lights are cockeyed. Can you aim them?
- My cars get up and go, got up and went
- Optimum shifting in 95 SE maxima
- question
- Modified engine mounts for lowered cars?
- 0806 ECU code question
- 1999 Factory Service Manual Torrent
- Fuel, Cranking, Backfiring, but No coil spark??
- OMG help please i am actually desperate PLEASE!
- Wow what a difference....
- Ignition Coils
- Where do you find GL-4 Gear Oil?
- Shift Lock Freeze
- Bored with stock hood
- Clear coat faded on right fender… can I paint it myself?
- Coolant changed colors?
- Help! Coolant leak (photos included)
- Brand New Cardomain page just created! Check it out!!
- how to bypass o2 simulator w/ heater
- trouble getting pas side front interior panel off Help please
- Clutch hydraulic hose.
- putting an image in your signature
- BAD Tranny Leak Prob.
- 5th gen axles question
- 8 tooth vs 10 tooth aftermarket starter.
- Start problem
- minor problems looking for assistance
- Interior Rattle Fix
- Where to buy OEM parts?
- Removing driver side axle from the Trans
- Right Axle Support Bearing
- Huge Jerk in shifting from P to D or R
- ECU Question
- What's the best way to tackle this?
- Cig. Power Converter
- is it the battery or alternator?
- exhaust leak. anyone else have this happen?
- speaker whine
- Compression Test Results
- putting an upgraded fuel pump on a N/A car
- Anyone buy from these?
- Locking vs Non-Locking Tranny....?
- Rust removal
- She's Gone...RIP
- Bye Bye Old Friend
- Fuel pump, coils, Random cut outs, stalls etc
- Easiest way to change ATF
- Bad fuel pump???
- pics of Altima SE_R wheels on white 4th Gen...
- Broke my idler pulley bolt... Need Help
- Ladzio's Guide on Assembling LED Tail Kits
- Airbag replica
- A Whine that increases with RPM?
- E-brake adjustment?
- Cefiro Headlights failed inspection
- This Sucks!!! Car drifts Left
- Ebay Find!!!!
- What happened to my Starter ??
- Auto tranny help...
- 225/55/16 or 215/55/16? Help me decide!!
- Sticky clutch
- leaking iol neer camshaft position sensor
- Need help getting drive side axle in....
- Alternator Belt Tensioner Squealing
- 3rd gear pull n stock 95with a dek (data log) air fuel
- thinking about buying 4th gen ANY INFO HELPFUL
- Clutch Replacement
- I cant figure out this belt problem
- Suggestions on Tranny Cooler?
