- Just a thought, what if I had a stripe sunroof?
- spring?
- Car Alarm Rondomly Going Off
- my spoiler is fallin off !!!
- need help with my brake caliper.
- climate control compadibility
- Valve cover Gasket??
- AC doesnt work so well
- Can knock trigger oxygen sensor codes?
- jdm corners on a black maxima
- Driver Side Rear Bose Speaker And Amp
- Fog Housing HIDs
- Parts Store Clutch
- hydraulic hood lift replacements
- Intermittent Sensors
- Quick question r.e. castle nuts...
- Gauge Bulbs?
- Anyone know how to install a new side power mirror?
- Wiper Switch Replacement
- Need some fedback on this
- 5-Speed Transmission Weight
- Road Trippin' To The MAX
- dash lights are dim
- Bumpy Feeling
- Valves Adjustment..is it worth it???
- other parts needed for suspension upgrade..
- 1998 Max with 6th Gen 18" Wheels -- No Drop **PICS**
- drive axels
- Wheelskins wheel cover pics
- For those who want to change their steering rack
- Compustar car starter
- Anybody with es control arm bushing directions?
- JDM black clears on black max. Pics please.
- Car starts really hard..
- 18x8's and tires
- Question bout O2 sensors
- Ball Joint Diagnosis
- 2"-3" drop...what to consider
- Starter occasionally spins on 95 Se (doesn't turn motor over)
- altima ser brakes
- where do i find the pcv
- Help! Could it be my AC Compressor
- steering wheel swap
- transmission relibility?
- looking for part
- I Forgot
- what needs to be replace when air bag deploy
- B-pipe?
- changin front struts
- 4th gear grind
- LSD driveshafts (axles)
- altima ser parts (CALIPERS) and such
- OBX Racing Headers
- Oookay, so...
- Springs.
- Gunna take off plenum soon, plz advise....
- those of you with key value clutches, how many miles/km did yours last?
- whats needed for Qs to fit 97
- SS brake line help.
- TIRES FOR MY TENZO's.
- What happen to the back window repair write-up?
- Installation Guide on Ground Controls?
- Plenum removal.
- maxima on 19's???
- Noise when key is turned
- acetone on gauges
- Pics of the the CF lip for 95-96 maximas!
- Lost my clear corner on the highway!
- Fuel Injector Cleaning
- Where buy Steering Rack Remanufactured
- lowering/strut question
- Change Your Spark Plugs!
- s5 grill
- Brake problem
- what am i supposed to do about this?
- Replacing Lower Control Arms
- Any how-to's on changing ACC bulbs??
- loud bangin
- Does a bad wheel bearing automatically make the Hub bad?
- Mods question.
- Exhaust Help Needed
- Grinding noise while driving.
- Ebrake Handle
- HID Question
- 5 pics = 1 mod + 1 question + 2 problems
- Did anyone see the 4th gen on mtv?
- code 0103, need part number
- Front rotors
- Noise when turning
- hard starting
- hard starting
- tricky wiring question?? help
- Picture Request: Cattman exhaust
- need carfax, help
- fair price for 300zx tt wheels
- maxima burnout vid, then some dude gets rammed
- 245 section tires?
- do we need camber kits for drops?
- '96 Max vs. electic golf cart
- Addition to mod FAQ's?
- i rounded off the SLIDER PIN BOLT on CALIPER
- I have an antifreeze leak, please help
- how do you know when oil pump is bad?
- 99 Maxima vs 04 Jaguar x-type 3.0 S model
- locks acting weird
- Erratic idle in drive or reverse AUTO tranny
- 97 max vs. 02 1.8t
- Broken Belt Tensioner
- Anyone know what this is CALLED ? please
- Harness Wire Switch
- Tell me how good or bad your Gas milage is
- 97 SE with clutch problems
- New shocks for old max
- I heart my transmission
- Quick question - Oil Pressure Gauge
- car alarm siren wired to stock alarm system???
- drop resistor mod???
- Too many code 34's lately!
- HELP!!! CELs ON, CODE "1105"
- Not again!!!
- punished my wheel on a curb
- Engine Resonance
- Rusty Exhaust Tip
- are all oxygen sensor brands basically the same?
- Mevi
- Best place to buy?
- Cattman exhaust
- Cooling Panel interest?
- 5spd swap HELP!!!!
- Heres to the good times
- Charging light??
- removal of molding around stereo ???
- Optima battery for '99 SE Limited
- I'm an absolute idiot
- To those that have done 5spd swap
- Rust on the bottom :(
- Needed - Strut Diagram
- foglight aiming
- * URGENT* Overheating Problem
- 9E000 filter design change
- OEM Motor Mounts are the best?
- Possible RSB rubbing issue...
- Noisy ac fan
- Large rims = axle and other problems?
- calipers
- midas ftl
- quick handbrake question
- Ball Joints
- well, it finally happened (5spd trans bit the dust)
- BBK Pro's.. step in
- strut mount?
- Electrical problem? Need advice.
- Strut+spring Combo question
- engine codes 0908 0103
- how does a bad knock sensor effect car? can it lead to shut offs?
- ebay exhaust - is this junk?
- Anyone know what this part is called??
- Pulley/Bearing Noise
- Do you think theses will look good on a black max?
- which light is the Maplight ???
- extra 26000$
- Ants in car
- BS Potenza G 009, any good?
- LED signals
- vq35??
- You guys seen these?
- Best Tie Rods?
- Uneven steering response, alignment issue?
- "Going Under The Knife"
- I bet none of you fools have this.
- headlight foggin up
- new fan resistor
- Horrible gas mileage < 17 (yes i read the stickies)
- Subwoofer Hookup
- How to get connector off knock sensor
- 95-96 red clears
- i give up. (95 cat 02 bung size) ?
- Wheel Bearings
- 3.5 Turbo?
- Evap codes 07 05 and 01 11
- low RPM's?
- Manual Transmission Seals and FAQ's
- wheel size?
- my LH headlight is not so bright as my RH side ! help please
- which coilovers are the best..
- Nissan Caliper ?'s fitting 11" rotors
- GLE rev limiter thing
- *Rant* (informative here and there)
- REALLY hard to start & no ECU codes thrown
- removing iacv
- LED Tails - taking it to extreme...
- does a lower temp tstat help?
- This is what I get for rushing..nothing too serious but will be costly..
- clear or smoked tails for sterling mist
- IACV Differences
- exhaust gaskets
- dang
- High profile tires and fender gap
- Code 09 03, 07 05
- Tokico Illumina-Dustboots
- Hestiation at 2000 rpm's
- Sunroof ratles when closed...fixable?
- ABS sensors
- Crown Brake Lines vs Goodman
- Car on the bumps feels all over the road!WTF?
- Engine Shutter
- Wheel Spin
- 95-96 All clear tail project
- Left turn signal light wire disconnected !! help ! PICS INSIDE
- brake question
- maxspeed springs..
- looking for 97-99 red/clear tail pics
- I shot some video today..
- Anyone got pics of z3 fenders on black max?
- replacement remotes
- Serp Belt replacement
- Help!! Car's Freaking Me Out!
- When did Nissan change out the timing chain tensioner?
- rear brakes
- Tensioner and Guide *Pics*
- normal compression 96 se
- Act clutch kit, street where can I buy
- Which Walker 02 sensor to buy (3 or 4 wire)?
- ..what I've been up to lately.
- CEL codes (P1446 & P0450) for EVAP problems, need help to pass inspection
- Replace/Upgrade 95 Maxima Suspension
- drivebelt adjuster does not loosen
- Thoughts on Exhaust
- Strange starting problem with my max
- need help....brake lights!!!
- How do I adjust my hood?
- Cattman headers/ypipe combo from CE.. Should I???
- what to look for in a 95 se
- sway bar link
- Sloppy suspension & steering..its getting dangerous!
- trunk lid question
- reset TCM or ECU?
- Few problems can anyone help?
- ??? on water pump installation....
- might buy a 4th gen.
- i need 2 front struts, want factory/stock feel
- 4th Gen ABS worth fixing?
- signal reset
- small bumper light: park to signal rewire -- front already rewired
- New Design for SFCs
- Anyone buy/have iPod adaptors??
- all clear tails?
- Stock shocks?
- 1157 bulbs
