- broken flex pipe = loss of power?
- Problem(s) Kinda Long. Only for the True Maxima Lover
- Few ECU codes
- wheel bearing help....
- spark plug question???
- 2,000 rpm at cold startup, why?
- Thinking of selling my 02SE wheels
- Tugging feeling with drop in RPM when AC is on and car in drive
- PR CAI filter question...
- Acc. belt tensioner shot?
- Car wont start
- NGK Iridium
- antenna and tape eject problems
- does anyone have the old maximadriver How-Tos
- what is the name of the part by CAT
- Guys need Quick answer.....Rims Q
- Tokico Illumina & springs combo
- For those that have done the (AE) tranny swap
- Oil and filters (checked fluid forum already)
- PARK/Neutral Position Switch code question
- Lets see some pics of shift knobs
- Finally found the limit with reverse staggered tires
- need feedback form bosch platinum users
- Does Anyone have this?
- Another Max in an accident!!!!!!!!!!!
- any writeups out there on how to repair key marks in paint?
- Guys what glue to stick on front NISSAN emblem.
- Is this a clutch noise?
- What the heck is that sound!??!
- WTF is wrong with people these days
- How much is SE (200-2003) rims worth approx.
- Pics of Black/Tan interiors.... Please
- Light bulb question
- LED website
- UDP off ebay opinions
- s pipe?
- Ebay buying
- where to buy?
- 5th gen MAF on a 4th Gen
- Noise on startup
- Question about Carbon Fiber Hood (cracked)
- Problem w/ locking lug nuts
- budget B-pipe and Y-pipe best place to purchase
- My Parking Lamp don't work!!! Help Please!
- Do you use Ebay? Here's a recommendation.
- Oil in my intake manifold
- Rear window break light
- New Exhaust!
- has anyone seen the red vinyl tape for the tails??? please help
- Good Place To Shop For Exhaust
- Coil pack question
- cefiro corner light wiring question.. again
- rear (brake light?)
- Are there any metal aftermarket intake adapters?
- 99 Rear popping noise?
- My Teachers Bose Speakers Are Messed Up
- Ebrake Light On And Battery?
- G35 wheels
- Need To Trick My Cousin From Out Of Town !!!
- Just wanted a quick opinion
- Painting Calipers
- Oil Pressure Sending Unit Question
- 2004 18350z wheels
- help, clutch problem.
- Exhaust System
- Clutches?????????
- Not so smooth ride
- painted corner inner chrome black, match ae heads. links to pics.
- Help in need of a alignment...but can't!
- Brake growling noise
- how do i remove radio to install a headunit?
- FS:9004 9000K Helios Hid kit
- LED Taillights: LED MCD?
- !?Low Gas LIGHT?!
- where do u get the red vinyl tape for the tails???
- engine not turning over
- CD Eject Not Working - Disc Trapped
- Tranny Sensor questions
- Speed Sensor, running bad?!
- 96 Foglights not fitting right
- Commonality in clusters
- Alarm mod, different idea
- Custom cold air?
- Starting Issues
- What Needs To Be Done at 210km?
- rims!!! help me decied !!pics!!
- Do you have to take off the bumper to install a fog light?
- Suspension ?
- Tan Interior w/Chrome dash pics......?
- !!Changing Fuel Filter!!
- Help Please
- where to buy headlight aiming clips
- An idea; will this work?
- So is it only JWT?
- micro vision help
- Strut Spacer Replacement?
- Found an extra pound of weight reduction
- 95 bumper support in a 98?
- auto to 5spd swap? help
- Car Won't Start When Damp
- Seafoam video
- Knocking/Clicking Sound
- Air Bag Light
- Cutting bumper!?
- Cleaned TB! Also have TPS Question
- WTF, Car OVERHEATING! NEED HELP!!!!!!
- Replacement coil pack--anyone have problems?
- Brake Pads
- need help fast or won't get to work tomorrow!
- pics of maximas with 2003 g35 coupe rims
- Magnaflow exhaust?
- Failed Emissions - NOT READY
- Raxle Axles? whats the huss??
- Need Help Wiring Power Seats
- Things to check for when buying a used 4th gen
- Rusting
- 4th gen in Fishkill NY
- brake light question - please help
- Retrofits please step in, Who has painted their housing?
- front cross member broken?
- Okay, 300zx wheel guys
- looking into suspension upgrade
- painting stock rims
- How much for a good suspension setup??
- car burns oil any idea what it is?
- Post Pics of Door Pillar Removed
- ford winstar motors?
- burn smell, maybe clutch??
- 0902 & 0608 Ses Help
- newb question: stillen pop charger
- Just got an oil change and now it smells like burning
- Power steering
- Photoshoped Signatures-Comments please
- worth modding?
- Just got ES motor mounts installed on auto max without manual motor mount bracket
- What are codes 0312 and 0213??
- grinding/rumbling noise from rear of car
- Has anyone ever done the "Alarm Beep" mod??
- newb to site, but no newb inside...exhaust?
- y pipe
- where do u get the red tape for the tails???
- humiliating video
- O/D started blinking
- Replacing Exhaust, need some advice
- is she totaled?
- Pennies in the CD Player -- Don't have twins...
- Changed Front O2 Sensors -- Codes Returned??
- How to recondition the starter motor
- Intermittent 'cold' starting
- Knocking Noise
- steering wheel shake
- clutch noise with spec stage 2
- Code 0115 keeps popping up, 4.5 gen need help bigtime!
- are these coilovers anygood?
- F/S lug nuts and wheel locks
- swap to auto climate control mod....again
- Red/cleared my tailights, figured i'd stick some LED's in there
- Maxima Owners in Socal
- light weight battery?
- odd sound in engine bay
- what could go wrong
- where can i find the led clear third brake light ?
- pics please
- lets see some interior mod pics
- Rim Question
- anyone hear of akita wheels??
- Why am I seeing 4th gens with SE-R badging?
- Non official Y pipe poll (real quick)
- exhaust options
- How to tighten up steering?
- Quick Answer Needed (Timing Advance via Consult II)
- check out my minivan wheels. :)
- Bent my 19" Konig....any ideas
- replacing tps what position to screw it on at?
- Battery tie down and one more question..
- Updated Timing Chain Tensioner Question
- what spark plugs are you guys using?
- quick question
- Gold Rims
- Will 5th Gen Struts Fit a 4th Gen?
- engine fuse block prevents car from starting
- Lowered w/ rear sway bar?
- more questions about 9007 conv.
- Want a GD!!
- exhaust prices
- Nice rims, but?
- engine swap labor cost
- steel seal
- Good and inexpensive car cover
- tranny swap prices
- car won't start
- car inspection
- Gave my car lipo
- Touch Up Paint
- G35 muffler on a 4th Gen, yeah...
- strange noise
- Univ. O2 Sensor Wiring
- What cause alignment to get off?
- Which Wheels ?
- Are Ebay Hi-Flow Cats any good?
- 3.5
- tint
- ebachcoil install... need help
- CAI = MAP Sensor Code Trigger?
- 87 Octane = Check Engine Light?
- Lug nut stub stripped or something
- question?.. What does the white se...............
- greddy SP replacement
- Need help with speedometer?????????
- Which stereo fits?
- fise for side mirros
- Sticky stuff that on rear tail lights?
- Angel Eye Headlights
- Omg.. 98SE w/65K..... $6700
- Rear wheel drive 4th gen Maxima
- Manumatic??
- Center Console Bulbs
- Bad sound coming from left wheel
- Vq30det
- stero removal help
- Front Lower Subframe Bushings
- Fans busted!
- replacing stock y-pipe, plz help those nuts
- New Engine Or New Max
- Really Bad Starting Problem!
- Aftermarket Radiator Core Support
- Check out the LED TAILS
- Need Help! Eibach Coils & Ground Control Suspension Setup
- Guess what?
- 18"x8" Mille Miglia MM1 fitment? on gen 4
- Overheating Problem, NEED HELP!!!
- Diagnostic Test Ran. Showed 0413
- Guys with no power steering
- which octane of gas do i use?
- 00VI Write Up
- How much did you pay to paint Stillen kit?
- Good price for a 99 se....
- Boes Stereo
- gauge needles
- What do you think of these Mille Miglia rims on my car?
- Need some help on flowmaster choice
- Timing Chain replacement
- Yellow Oil
- tokico illumina kit help
- Reasons why not to go big (wheel)
- mevi
- I need some advice on what to do with my car
- Replacing Exhaust w/stock: What do the Clamps do?
- Best springs to get
- electrical problem
