- LED question for a 96
- Indiglo gauges control box
- Are GXE's supposed to be prewired for homelink visors?
- black out clear corners?
- How to clear your gauge needles without sanding them.
- 4th Gen Cigarette Adapter Question
- UPDATED my webpage with some new mods
- difference with 95 sideview mirrors??????
- starting problems
- Help (intake) thanks
- 1999 Cali Spec'ed Max have only 3 O2 sensors
- midpipes- yes or no?
- changing oil
- car fax account
- Online OEM Interior Parts
- Pulled Code...
- anyone got 95 maxima stock taillights f/s
- what 4gen inside door panels fit the 99?
- Bad Paint job Need Advice
- BOSE (BLOSE) Issues
- 99 Maxima - TRAC & ABS light up, misfiring....possible causes?
- Out with the old, in with the new
- Stereo Removal
- 5 speed tranny fluid change
- performance fuel manager
- Put bose in a non bose SE.....
- What's my 99 GXE 5-speed worth?
- ECU Light Going Off??
- 1999 GXE:Strange noise after starting
- Is it me or SAGE MIST COLOR IS RARE OWNERS STEPIN!
- maintenance service questions
- 30, 32 or 35 psi?
- Mevi?
- Trunk 97 in a 95
- Climate Control Display
- Red/Clear Tails
- Change to Chrome rims?
- rough shifting help plz
- Cleaning the Headlights...?
- fidenza on a 95
- Digital clock out...help?
- Knock Sensor ?
- smashed up maxima
- 96' maxima with engine shutdown problem
- Trunk Lid replacement
- how 2 tell if am i droped or not???
- Would this fit??
- Car vibrate during high Speeds
- need help and opinions guys. 97bumper and lip or 96and lip?
- 99 Maxima - TRAC & ABS light came on..then went away.
- HELP!!Car Temprature drops?????????
- Quick Question
- Post painted valve cover pics
- Custommaxima.com's 1157 Polarg Clearance Lights
- Man. tranny conver.
- 97GLE vs 96 BMW 328i
- what the...
- need some wiring/stereo insight
- some pics after wax
- MEVI TQ loss question (dyno Inside)
- Maximadriver.com/Cheston's site/pages gone
- Maxima got totalled, how much it worth?
- Springtech 2" drop
- buttons on climate controle and hazard light dont glow
- Failed the Emission Test Today
- 00-02 tranny or 03 tranny in a 96
- Will 300 ZXTT brakes work w/stock wheels?
- need quick help: what is how much to torque the two starter bolts?
- How to install CAI (BOMZ intake)? in 96
- No Turn Signal
- M/T & A/T Flywheels
- Blue Lighted Interior (PICS)
- ECU won't reset ... huh? (screwdriver method)
- Bose Buzzing Front Speaker
- Help - Blue Smoke!
- Pearl White Parts
- Stuck screw
- Looks like I am gonna need to get new rotors.... Brembo's?
- Is this really out of a Max?
- Lost All My Oil
- Where is the Bose amplifier located?
- who has used regular plastic spray paint for tinting?
- 99 bose HU adaptors for 95
- wanting to re-do interior
- Replacing the main belt
- 92 tranny= fits 96?
- Maxima woes
- help oil and freeze?
- wiring help 96 se
- Another intake thread.... but i have a real problem...
- I skidded into a curb lost alignment
- Front End Vibration
- ARGHHHH timing chain tensioner spring and piston lost...
- Good rear rotors (factory replacment) ??? and where to buy?
- pics of my car
- Need help fast on engine mount
- some one plz help TOKICO ILLUMINA
- Well, Checked the Codes for the First Time
- CEL Codes: Need advice
- Don't buy Silverstars
- a little oil leak
- Engine coolant temperature sensor
- Racing Steering Wheel Installation?
- Infinity Wheels ....
- jack stands floor jack question
- 100/80 W Headlights
- Seat Heater Light
- new mods
- Any one else hear or Megan Racing
- random pics of my car
- maxima 97-99 grill stolen
- what is the cheapest website for after market parts?
- Passanger side headlight and fog light are out..
- need some install help
- for those who made their own grounding kits...
- Click noise with sharp turns
- Hard shifting when it is cold....
- Exedy clutch on ebay...your opinion wanted
- Help!! Cheapest front 97 bumper cover?
- is there a how to on axel replacement?
- clutch engagment
- guy wit sick guages? shift_ice or bling come look
- Cheaper parts?
- Planning to buy a 99 maxima ...suggestions wud be appreciated
- Muffler
- What did it cost to re-build your Auto tranny?
- Heated Seat Switches
- How To Remove Corner Light!?!?
- my mods
- Its Fixed!!!!!!!!!!!!!!!!!!!!!!!!!!
- carbon fiber hood
- quick question
- Suspension overhaul - Question
- Silverstar bulbs in fog lights
- timing chain tensioner
- 97 taillights on a 96?
- Cali-spec '96 SE?
- Can power antenna wire to aftermarket deck?
- For all of you that have dash kits
- Valve clearance check
- clunking noise in tranny!
- Need new foglight lenses...
- Shift Lock Sticking on a 1998
- Strut mount replacement
- Mevi
- Heat only works when RPM is up?
- Gauges
- continuous cigarette charger
- IACV pictures please.
- What do you think of this Intake?
- ProCarParts Diamond Cut Corners
- Trailer hitch?
- coolant, oil disposal question
- Retrofitting
- 16" tires & drop (< or >) 18" wheels & tires
- Are the stock Bose speakers on a fuse?
- cheap HID kit?
- ngk iridium plugs
- help starting
- [flame the noob] bought pedals and curious as to how others installed
- i think my axle just fell off
- Reverse Bulbs
- 1998 i30 and throttle shock
- ebay rear sway bar
- Problem starting car
- Mitsubishi replacement coils?
- hood struts replacement question
- Heated Seats
- Is the Engine the same for the Auto & Manual ?
- help
- Glass packs
- HPR 5 wheels
- Help with strut bar install
- is a Racing underdrive pulley really worth it ?
- replacing starter: buy from nissan or autozone/kragen
- Adjusting cefiro headlights
- Car won't start or even attempt to, pulled codes...
- When car is in neutral...flywheel or clutch makes a knocking sound
- Brake Pads
- knoking noise while turning
- Remove Auto Shift Knob?
- clear corner installation - link in how to doesnt work
- very weird hesitation, NEED HELP!
- best way to rid of smoke odor?
- Question regarding auto tranny code procedure...
- My '97 auto is suffering...
- is the stock downpipe cast steel or cast iron?
- Fuel Cleaner
- Tint spray for tails - local shop ?
- Auto to 5-speed swap...?
- drop it like it's hot
- Need Help!!!!! Clutch Or Tranny
- My maxima's handling sucks!!
- Starting issue - especially when its cold outside
- Never Ending EGR Flash Code (0302)
- Maximum tuning bulletproof auto tranny....
- LED Tail lights
- Headwork ???
- When will it end?
- Does any one have HID installation pics?
- Headlights Blinking .... Not staying started ??????????
- 95 Nissan Maxima color code - where do I find it
- What tool do I need for Knock sensor replacement
- Third Brake Light
- So what did Santa bring you this year...
- Electrical System Issues...
- auto or manual????
- upgrading audio in my 96, know nothing. help?
- what the hell is wrong with my starter?
- question for cleaning battery
- Nissan Hamburger
- Anyone here with Dynomax Turbo Muffler & aftermarket b/y pipes?
- custom exhaust shops Y-PIPES
- some pics for 4th gen friends...
- List of Mod Questions
- Where to put 6 strobe bulbs??
- weirdest problem EVER
- heat controls/radiator not working right....
- stock spring rate?
- y pipe
- Coolant Puddle
- Anti-Theft System Malfunction
- Replacing control arms - how hard?
- Hard starts??
- NEED HELP crank position sensor. What the hell is it
- After resetting ECU doors lock automatically?
- PLEASE HELP - hoses coming off midpipe?
- Suggestions on where and how to mount Sirius
- need clutch and fly wheel!
- heating problem
- 14" wheels with stock size rotors/calipers
- hoses coming off the intake?
- Abs
- EBay mods
- new headligt bulb time!
- Worst Christmas EVER
- fuel and rims ?
- EGR-BPT Part number
- KS removal / Resistor Swap... how to?
- stock cd player malfunctioning
- Ignition Signal Circuit Please Help??
- Dash Kits
- B-pipe
- different visors/rain guards for the windows...
- Tire Help
- service engine soon
- Touble with 98 maxima heater fan
- dismantle ac question
- HELP! Brake light on ODO
