- Grey electrical connectors...
- polyurethane bushings
- Initial Brake noise....
- Haft Shaft Removal
- y-pipe rattling, buzzing---anyone else?
- Newbie - Good first modifications?
- Help Po155 O2 Sensor Code Keeps Comimg Up
- Cefiro headlights
- Brake Caliper Rebuild - Problem
- The best write-up for changing 02 sensors?
- EGR Solenoid Valve? What and where is this?
- help! while replacing KS..
- Tips on adjusting clutch travel?
- Is it bad???
- Trunk spoiler brake light wiring
- What is my car worth? Thanks guys
- Updated Pics-Next mod Budget Y pipe?
- The Damn car won't start
- NO Spark
- WOOD TRIM dash kit is fallin oFF HELP!
- HELP Need to replace my 98 GLE alternator
- Rear Oxygen Senson
- Exhaust System: any comments or recomendations?
- Who knows how to install INTIMIDATOR II
- Picked up 99 5 spd
- muffler tip opinions, links included.
- write up on ebay cold air
- need some blubs sizes LOOK
- question about clearing tails.
- Rear Heated O2 sensor
- wheres a good website to get some black or gunmetal 18's with a polished lip?
- If my KS is good, how come I still have the code?
- question about e-bay hks exhaust
- High Flow Cat on Ebay ...Any good?
- question about hacked airbox noise
- Suspension set up.... what do you think... price/good deal?
- Template for spoiler install
- Twisted the heads off! (splash shield screws)
- changing shift knob???
- Value of 97 GLE
- Short Ram vs. CAI
- Question From 99 Owners.
- Brake pads recomendation
- Who has HID's?
- how do i get rid of the blue bulb look in corners?
- anyone have a g tech?
- window rolls up stops then rolls up the rest of the way
- my motor whistles while in park?
- Where can I get my Technosquare ECU???
- Odd tranny related (I think) problem with a 99 Max GLE..the car "kicks" when stopped
- will ABS hit in faster if my wheels/tires are bigger than oem's ????
- Is it a good idea to put my DMS udp on my car?
- Sylvania Silver Stars
- About to do Suspension Upgrade, need help!!!
- Severe cylinder misfire, different codes though!
- brake dust shield
- Unsteady Idle advise please
- How bout emblem on front of hood?
- Need help with a diagnosis
- Stock alternator amperage for a 4th Gen Max?
- HELP !!! Keyless Entry Install
- broken gasket seals getting oil to spark plugs?
- aiming headlights
- hesistation at wot
- unorthodox underdrive pulley - is it worth it?
- Anybody had this problem
- Hey lucky non-barebones-GXE owners
- Dropped Max In the Snow ..
- Rear O2 Sensor
- Bearings
- custom B pipe
- Good Recommendations on Headlight Bulbs?
- intakes on EBAY any good?
- OBD-2 Vehicle Explorer
- TIP: Suspension noises
- ripped cv boot
- Who thinks 98' Maxima & 99' I30 have same steering wheels
- Finishing Interior Swap, whos done this???
- red clear turn signal bulb number
- O2 Sensor help
- Injen Intake Installed - Boost Sensor
- Auto zone store "pulling" cpmputer codes
- Q about eyelids
- 95-96's post up picts of you RED tails
- 350z projectors in a 4th Gen Max?!
- Right Turn Noise
- Wiper problem...help..
- CLEAR/RED Tails, How to take of the orange??
- Welp, it's time for me and maxima's first trip for Fort Dix, NJ
- Will rear 02 sensor affect emissions
- New Pads, Rotors and calipers 1k?
- Acceleration ticking noise.
- How does a MEVI operate????
- What are the best fog light bulbs?
- Alternater sp
- What the F**K is going on. Codes galore
- Who has the Evo exhaust?
- Should I bother with strut dust boots?
- High Idle Problem / Question
- Back End lags around turns, Help?
- Deep Sound...NOT RICIE...what muffler/exhaust should i buy
- How much does it cost to do a drop???
- Chipped fiberglass easy to fix?
- Maintenance Q: Idler adjuster arm/pulley replacement
- shifter trim same in 95 and 98?
- 5th gen muffler
- power steering problem... please look!
- ABS problem on 97 SE
- Do you have a name for your Maxima? What is it?
- Gas Milage worse with Jwt???
- power steering leak
- cat back exhaust install HELP!!!!
- redlinemax M Bumper
- Post pics of Cefiro Headlights Installed please.
- Debadged Trunk Post 2! Pic's!
- bad rear bearing??
- Re: Help?
- paradox systems fstb
- 32-35% tint pics
- 4th gen body kit
- $215 Credit At Custommaxima - What Would You Guys Get?
- The Best Ride In A Long Time
- Parts List 95-99 Maxima, Very Useful!
- Help on posting pictures
- what do you uthink?
- Macco's legacy >=(
- Odd torque curve...?
- hids
- noisy strut spring
- Exhaust Emergency Help ME Please!!
- for those with the ebay revotech fstb
- Sterling Mist w/ Body Kit
- Vibration at low speed and idle?
- What are the best looking and brightest gauges?
- HELP!! the lights in my gauge cluster (speedometer, fuel, etc) went out
- speaking of mods
- Blue Climate ocntrol button questions
- Absolute Pressure Sensor CODE 0803! Please Help!
- OBX Type-H Pics
- CEL .. weird
- Spring Question
- Question about Suspension...
- what to get?
- Top Speed of a STOCK 4th Generation 5-speed Maxima?
- P0325 KS ghost code is on!!!!!!
- Input on next mod... this should be interesting
- how to run a power wire from the cab to the battery?
- what mod should i do next
- Magnaflow muffler
- Suspension Info?? Need Info!!!
- Having a few problems with the Max...
- New here.. looking for some info.
- Who's succesfully replaced knock sensors themselves?
- Y pipe vs mpg
- bad water spots won't come off
- HID's on 98 - Will I ever stop getting flashed??
- Nameless CAI
- If 2000 has the same engine as 99(VQ30DE), what gave it hp gain?
- DeBadged my Trunk but Max sign/logo still shows a bit. Pictures!
- Valve Cover Removal Writeup?
- Illuminas with stock GXE springs?
- Ripped at the Dealership
- I know maxmods says no GR2's with Progress Springs, but a lot of .orgers...
- window tint
- cosmo intake filters
- KYB Dust / Strut Boots Consensus?
- Other Body Kits
- squeaky belt
- im at 135,000 miles - whats some maintanence i should do??
- tuning the max
- What R signs of a failing Transmission: Auto
- Door Rattle is Driving me CRAZY!
- possible to do auto climate in GXE?
- whats budgets website? where i can get a y pipe
- For those who have a midpipe with a jwt filter
- URGENT! Adjusting Idle
- interior mod, help me out
- Where can i pick up MEVI ?
- Nissan logo
- replacing knock sensor this week. need info.
- Tach being weird
- My 1995 5 spd Maxima vs. my friend's 1995 5 spd M3
- HORRIBLE Gas Mileage 220/tank. Overdrive Contributing?
- Rattling noises from the dash
- Strut bearing changing...grease it or not grease it Help!?
- evu code 0705
- For the last time...Warspeed vs. Budget y-pipe...what's better???
- 2000 Maxima floor mats on a 95?
- The mod bug got me today...
- My Oxygen sensor frustration is OVER!
- 95-96 Maxima kits
- wet rear floor mats
- How can you beat a 98 V6 accord with a MAXIMA 98 V6 *both auto*
- cruise control problem
- front/rear lip
- Exhaust 5th vs 4th gen
- damn warping brake rotors
- AE Pedal Question
- recall on alt.
- exhaust problem.....need help ASAP
- What % should I tint my windows? And is $175 a good price for all windows? Ca
- strut bearing
- 2001 starter
- Are '97 headlights a direct replacement for 96's?
- Clear corners just falling off.
- tranny question
- help with a problem please.
- Q about ebay intake
- Any of you have HP Tokico shocks and the new Illuminas on your Max? Half & Half?
- remote programing
- Thinking about buying
- How Does the Skyline Body kit fit?
- Where Can I find Polished Intake Manifold?
- Looking for Polished Intake Manifold??
- Need help/tips with installing half shafts
- FYI: Clunking noise when coming to a stop or braking in reverse
- Hi everyone
- My Max in Max Pain!
- Cel 05,05
- Emergency brake light going on/off/on/off
- my search isnt working, got a few questions
- Another 4th gen tranny goes down in the blaze of glory =(
- Coils for my 99 GLE
- how do you fix evap control volume?
- is random tech free flow cat converter worth buying?
- How adjust hood heigth?????????
- Newbe
- New to the Forum and Maxima's! Wanted to say hi since i've been peeking around.
- to those who ordered a Warpspeed Y...
- Few Questions.
- Got CEL 07,07 & 03,04
- Damn Maxima....
- UDP measurements
- Oxygen Sensor simulator
- shocks/stuts
- b-pipe
- pads
- Whats your favorite online store for Max parts?
- UPD installed with pics!!!!!!!
- Need Info On Complete Tune-Up
- Cattman Headers
- How low to drop?
- car won't start, need help...
- Tranny Rebuild Kit
- finally done!
- Brake Lines
- Wrecked my Max
- 2000 coils in a 99 Max?
- VB Mod (Mobiltek) can someone help
- Can Ne One Tell Me Where To Get Clear Corner Lights For My 96 Maxima?
