- brake bleeding?
- Did all the fixes. Still starts hard. Need advice
- 5 speed conversion
- Gold maxima??
- Where can i find a good place to buy these parts...
- autotragic help after some track races
- questions about exhaust systems...
- flip key w/ remote
- differential bearings and a turbine like whine in 1st gear...
- is this any good? ground wires?
- Is there a suspension install write-up anywhere?
- 98 Reverse Light Question
- Lights for a 1996 Maxima
- H&R
- What does the orange spacer do?
- stiff clutch pedal
- a couple new pics of my interior
- H&R with KYB GR-2s question
- where can i find Philips 9004 HID kits??
- Any detailing/cleaning questions?
- Need your Opinion|B+G w/GR2's
- Lost a PIAA.....
- Poll: I want leather!
- Usefull Info
- Injector replacement
- anyone run H&Rs with oe shocks?
- taller gear ratio
- put steelies back on...
- Gas Station Difference
- Been gone a long time, need some advice please.
- Help.. repair shop says I need new ECU
- Rear Seat...
- clunk in the mornings after going in rev and turning wheels
- problem with brake and shifter
- roter/piston
- wen putting in new tail lights, do i need to buy that black silicone glue?
- how do i separate tail lights from a 95-96
- Power Steering Pulley Wobble
- Real gains of a b pipe
- aftermarket muffler not worth it
- 5.0 Stang ain't no thang'!
- Advice on converting dash lights to blue?
- car locks, but alarm doesn't activate
- Just Got JWT pop charger+frankencar mid. Seem to be missing MAF? Help!?
- warning for those purchasing colored bulbs for interior
- Where do u get a ECU UPGRADE?
- Dash Lights..
- Rotor Questions
- EVAP Control system question 96 Maxima
- Would the Boder Fireball Muffler work on our Maximas?
- People with aftermarket UDP's......
- Help with front end
- IAC cleaning
- Wheel Hub ?
- I know MANY have been looking for this...so here:
- wats best way to paint trunk lock?
- Dark emerald green max owners 95-96 please post pic of red/clears
- Cefiro Spoiler???
- Need help regarding codes 0303/0701 and engine flooding theory
- rough sound from engine
- I need help with a KIT
- JIC-SF-1's...any good ??
- Exhaust System from JIC MAGIC
- I30 Dash on my MAX?
- How do you replace spark plugs????
- did the swap!
- suspension Q's
- Stumbling when accelerator is pressed. ?=o/
- Which Newer Maxima to buy?
- jack placement...help!!!
- full synthetic trans flush
- And I thought I had the baddest sound Maxima in NYC...
- After intake is y-pipe next
- Maxima shakes on freeway..
- Way to do a red clear coat??
- Brake Squeak When Applying Lightly
- I Need Help!!!
- I just learned the hard way...
- Engine running rough
- Anyone replaced KS?
- Lost To A Honda Need Engine Mod!!!
- For those that made their corner lights brighter...
- I need a B.J.
- i am soo stupid
- Plug wrench
- I need help with part numbers.
- Vehicle Accident.
- Doing a suspension RIGHT
- WARPSPEED sucks and so does carsound...
- motor and tranny swap
- How can i make the Fogs work independantly of the headlights?
- Frnt Driverside rotor rubbing in spots.HELP!!
- Alignment done 2x in last 4 months....need advic
- Yes another H & R question.
- Why is my axle mount breaking? 5 spd.
- need help my ride is soooo stiff...
- uneven tire wear after changing shocks
- Exhaust pipes size
- Cattman VQ30DE header pics
- Intake Inquiry!!!!
- reverse indiglo gauges
- injectors
- What do you guys think of this? Real or no?
- Rust
- Is this Normal for an AUTO tranny???
- attempting new ideas: smoked clear corners + altezzas
- Are these "Coilovers" garbage or a step in the right direction?
- jet performance chip
- OT: Just need some opinions!! Plz dont move
- Clutch Questions (EXEDY vs OEM) and more
- Electrical Gurus Help Please
- BMW m3
- Carbon Fiber 97-99.5 Stillen Lip replica...
- should i have this fixed?
- changed ks
- Transmission slippage when accelerating hard
- tinting sunroof
- bose HU screen on a 95 max se
- Energy Suspension Bushing Install
- Products to clean headlights?
- HELP: EXTREMELY poor gas mileage with NEW O2 sensor !!
- New Maxima Member Blk/blk 5-spd
- Question about aftermarket wheels
- painting 95-96 red/clear tails
- Definative color name/code/years available list...
- keyless remote entry question...
- Why doesn't JWT make their ECU reprogrammer
- Need Help Fast!
- Intake installation
- Stillen Hi Flow Intake re: Reset ECU ?
- brake and shifter noise whats wrong
- Skyline R32 headlights fit onto 99 Maxima without modification
- Hood Shocks...
- Auto - weird shifts
- Anyone ever use this Mod?
- Spark Plugs?
- New here- have a serious problem.
- My Max got hurt this morning
- What exactly does the engine coolant temperature sensor do?
- Need some help! Suspension problems
- OEM Nissan Navigation in a 4th GEN???
- What springs to go with KYB AGX?
- Stiilen strut bar
- Annoying whistling noise gone!!
- 1996 Nissan Maxima Auto
- YeeHaw.. just ordered y-pipe
- 0304???
- just installed magnaflow muffler
- Check my alignment specs, anything I should adjust?
- Do drilled and slotted realy healp??
- Got Keyed
- Cleaning the IAC Valve - Already looked at FAQ..
- Need some input on a transmission going bad...
- Brake problem
- Re: Springs
- Question about rear brakes
- Rusted brake shims
- Moisture wont go away
- Hood gas cartridges -- where's a good deal?
- Goodridge SS lines install ??
- knock sensor cheap
- just up date my cardomain page check it out
- 97 non-bose speaker problem
- anyone know what code 03 09 is???
- Just changed the knock sensor
- Fed or CA emissions?
- automatic transmission question/opinions
- Door light not working anymore
- post pics of your painted engine bay
- minnesota people
- Who was the MAX featured in Modified Mag this month????
- My elctrical power is dying....why???
- Starter not cranking....Arching?
- I just ordered my rims!!! WheelMax.com had a 50% off sale
- 9 max vs. I30 brake pads
- Your opinion is needed
- Problems w/ Max
- Maxspeed Springs
- Need help with brakes please
- Is PEP BOYS a good place for this?
- Warpspeed SS YPIPE OR CATTMAN?
- Altezza Covers
- aluminum door sills ..... Buy or not?
- Got pics?
- Exhaust HELP plz
- pics of car tell me what u think.
- Fog Lights not workin
- Leather Install: How do I...?
- Thinking of getting car repainted, suggestions...?
- if u from north jersey check this out.. redirect to reginal post.. PLEASE DO NOT MOVE
- Pictures of My Maxima
- Polyurethane bushings
- Idele problem!!!
- 2000 center caps
- watch out 95's! apparently your cars are dangerous!
- need help once more
- Idle Issue..Already checked IAV
- Possible ignition switch or wiring problem, help?
- BUY your OWN S***
- Cashj2002, you still around, just curious
- Transmission Problem?
- a couple questions for knowledgable maxima owners
- Engine Light just turned on at 80k
- Shifting points for my 5spd
- Raybestos Quietstops or Matrix Metal Masters??
- where to buy?
- Got Headers in the mail!!
- Max got hit, needs repair in ATL. Where to take it?
- Hey wait...These New Kuhmo's aint bad. :D
- Does any have a greddy evol?
- Tein springs
- 1995.. Se..
- wheel bearings
- Cleaning
- Best place to buy....?
- how much power/boost do our engines hold?
- I lost to....
- What could possibly be wrong with this car?
- Cost to replace cv boot?
- question about rear brakes
- Best Springs and Chock Combo
- Anybody want to sell me there red/clears?
- Finally... clear bumpers
- ypipe "gurgling" ??
- Need help with wheel offset....
- Raced a Firebird convertible
- Blitz Realize TT cat-back exhaust
- Found A New A32 Model Car!!! Some Sweet Parts!
- fog light rewire worked only for about 20 minutes!
- thought this was interesting...JDM VIM
- Hood
- New PICS of the carbon fiber spark plug cover by Ionic Dynamics
- anyone have complete ws exhaust?
- Toss up between iridium and platinum
- Spark plug wires?
- just bought a new max, what do you think
- whats the black screw on the egr valve
- Help!! Clutch Slipping!? only 9 months old?!
- got a maxima, but have some questions
- car starter question
- Warpspeed Ss Y-pipe W/ Greddy Cat-bak?
- engine trouble...code 0403.
- FOG light rewire gone bad...please HELP! S.O.S. Hurry!
- quick rotor / cv joint question
- *Need Help Programming Door Remote!*
- installing UDP
- NEW 4th gen Eye Lids in Carbon fiber by Ionic Dynamics, pics inside :)
- noobie motor oil questions
- My exhaust is driving me crazy....
