- Autotragic went, $2,500.00 burned....
- can someone photochop my car?
- Another N/A auto in the 14's
- BAD sound, please help me identify it!
- squeaking from springs!
- Which springs should I go with?
- 95 red/clear tails......question?
- Shifting Question
- Neeper Rims
- Weapon R
- 96 bumper lights
- Door Molding Problem? Plz help
- 96 starting trble
- Will front end mask for 97 fit 99??
- exhaust problem...need help.
- radiator
- I broke my Max! Help Noise from suspension or dashboard...
- check GD's for red clears
- my 1st accident
- problem to start engine (long story)
- Need help with rims....
- rear window spoiler?
- Having second thoughts....
- K&N drop-in filter question
- Questions about transmission fluid...
- Dome light
- Need help with ground wire system...yes I searched...
- Spiral cable assembly problem?
- Anybody got the new z wheels on their max?
- 4th Gen Kill List
- Nippon vs Primax wheels
- Is my knock sensor dying? 535 ohms
- Want to install my fstb today and need HELP!
- Camry V6 or Maxima?
- Need Help with Tails
- clearance light
- Need help with identifying sound when turning off engine
- how do you remove spark plug tube seals?
- Where's Gregs Maxima. custommaxima.com
- hard starts
- do I need to drain the radiator if I want to remove the thermostat?
- Loud Tranny noise on 97- 5-speed
- Warpspeed Y Pipe! Y Pipe in General?
- Please Help, Tranny?clutch? Problem?
- Walbro fuel pump on NA Maxima?
- MEVI vs stiock intake manuifold porting
- Question before I install dead pedal...
- FS: tranny problems
- rotating tires....
- Budget Y Question
- SE/GLE door panel question- fuzzy insert
- Who knows about VITEK clutches ?
- Need advice on interior squeaks and rattles
- ngk or bosch spark plugs
- Installed New Battery, now Viper Alarm wont go off and other things dont work, HELP..
- Momo Shift Knobs Cheap!!
- 97-99 Stillen Rear Body Kit
- trunk mod
- My stupid friend thinks his car is fast
- is this a good deal...>
- Ordered Cattman RSB today!
- GLE --> which parts are leather/vinyl ?
- oil pressure switch needs replacing?
- 5spd hydraulic question
- spark plugs pictures to diagnostic
- Trans/Drivetrain ques on 7 SE
- does performace always = loud?
- Need personal opinions on new front bumper!
- People with autos... did the drop resister mod with a switch.. one problem though...
- Suspension spring placement incorrect?
- sound off.... who makes your y pipe?
- Does anyone have 17x9 rims in the rear OR will it fit?
- Those that have automatics with superchargers
- Hey UNCDooD!!!!
- taking EGT probe out, but fill hole with what?
- Factory Weight?
- Aerospeed Intake
- Black Widow Wing
- perfomace exaust fo 99 Maxima SE
- Tein springs for Max's!
- Tire size suggestion??
- Morning pics of the car 1st time!
- Jwt Ecu Ques
- timing chain?
- Which of these tires would you recommend?
- Tire size question?
- Successful MEVI install tonight
- Budget Y installed
- need new clutch
- Interior Painting
- **Pics of my Max**
- 5 speed transmission woes
- Quick question....
- What kind of set ups on e-brake/shifting knob do u have?
- dead knock sensor confirmation
- checking the timeing
- Tach Transplant... SUCCESS!
- Installing MEVI, tach signal? HELP
- cigarette burn
- warranty ?
- exhaust blowing white clouds of smoke
- whats your top speed?
- Alignment with conversion
- Ebay stuff
- Quick Q about Clearance Lights
- A few questions about changing the bumper lights
- wierd lag when shifting
- Clutch problems
- The plug debate one more time......how 'bout AC-DELCO ??
- Has anyone ever taken apart the rear-view mirror?
- Throttle Body Cleaning Intervals
- $79 worth it?
- Starter question
- 96' Maxima
- what Shift knobs will fit a STS?
- Error code p0110
- Dead cylinder?
- my oem clutch
- painting inside of headlight...
- My leathers look terrible
- How many have done the 5speed conversion?
- Need to Borrow 95-96 Red/Clears for Photo Shoot
- Got a story to share....
- Automatic Transmission Issue
- For all who have aftermarket pedals,,,
- Need Help: Crazy brake noise
- Brake Fluid Change Process?
- Anyone need I30 Woodgrain Climate control?
- Quick response needed on buying a transmission...
- Need your help....
- AE valve cover?
- Water Pump
- I30 Destroyed.........
- opinion on which belt is squeeking
- Dead Maximas......
- anyone else have #$%*ed up speedometer?
- Anyone who has added a factory spoiler to their car check in please....
- What edition Maxima do I have?
- Paint Job.....question?
- Removing passenger side fender
- wrx vs. max
- why are we underestimated??
- Budget Exhaust
- Did you buy a clear front bumper lense from ebay?
- which bulbs are brighter?
- Cheapest place to buy Dust Boots anyone??
- hard starting
- What Tire size should I get for stock rim?
- 18" rims suggestions
- How slow is Budget with E-mail replies?
- Maxima wheel guards
- Had Porterfield R4-S pads installed last week...impressions/questions (kinda long)
- What Motor-oil do you guys use?
- Ghost Code - Rear Heated O2 Sensor
- Maximas with skyline bodykits
- Who has installed drive axles?
- Adjusting head light....how?
- one more question on brake pads install.
- APEXi S-AFC Installed - Pics
- Who would win at the track?
- Help a Newbie!
- Valve body mod....question?
- HELP ! McCulloch Xenon HID kit installation
- Need info. on headlight parts
- need a quick answer on brake pad install
- 18X8 vs 19X8.5?
- Unknown harness
- Price for 97 GXE??
- Benfits of polishing
- 96 maxima
- 4th gen most reliable premium midsize!
- TIRE Question??
- wax after new paint
- What is required for rear spoiler removal?
- Question on buying chrome 18's with a budget
- haynes or chilton
- Any pictures of disassembled Manual Climate Control?
- asome blue maxima must see!!
- which angel eyes set should i make... pics
- Notice anything wrong with item for auction?
- At last Pics of my Max !!!
- question on repairing sunroof
- Timing belt service interval/valve clearance
- 4th gen price
- VENOM fuel pump???
- who has grey leather in their maxima?
- gas milage after Alternator recall
- question about bump stops and dust boots...
- Quiet but yet powerful
- Need Help!!!
- should this setup sound nice??
- what does the rear heated oxygen sensor do?
- Any owners who have cut Eibach springs installed? If so, please help!
- low end torque for auto(long)
- need help in climate control problem(s)...
- 90k tune up......how necassary is it???
- K & N filter
- K&N Fuel Filters?
- Man my car weighs ALOT....
- Problem with lights behind AC control...Please help me fix...
- Anyone buy the FSTB from Budget?
- Exhaust system upgrade components
- mevi install instructions
- carbon fiber opinions... what do you guys think. please read
- Wrx Vs. Max
- weight difference? 4th vs 5th gen rims
- Tire size saga... need advice quick please!
- y-pipe install Q
- who has a Budget SS mandrel Y-pipe?
- Brake Bleeder Opinions?
- by-pass oil filter
- Good prices for r/c, yes im searching too
- annoying vibration sound coming from shifter...
- Rear Door doesnt close smoothly
- any eec programmer available?
- Is it possible to have a true CAI
- what all-season tires to buy?
- Gas mileage has slipped into the teens
- Car has a hard time starting
- I need a new Starter. Any suggestions?
- Engine Light came on Please help...
- 60K tuneup link in FAQ doesn't work
- Time for a Winter Car.
- OEM Spring Modification
- Best way to make pedals feel better
- question about cat scales
- Service Engine Soon after Clutch burning smell
- maxima insomia experience
- noise with wsp y-pipe, b-pipe fix without resonator?
- Finally finished Mods
- analog for digital swap: odometer
- Speedomater gears
- sorona front bumper
- Q: about my dying starter and my clutch which didn't work.
- Acceleration: 15" vs 17"
- I'm in desperate need of help with taking off clearance lights
- white gauges/aluminum bezel
- Fuse box configuration
- White SE gauges.
- Wider tires + Traction
- What do you guys think?
- how many of you think my alternator is going bad?
- ? on stillen intake
- Spark Plugs
- warpspeed y-pipe
- Grill for Skyline front bumper...
- Shaved Trunk Question
- New Pics -- '97 SE w/ 2k2 Wheels!
- Fuse for headlights?!?!?! please help!!
- How to take off the Driver side door panel?
