- Need help installing a steering column
- 6 speed drain and fill plug
- Won't start
- i35 5.5 headers don't exist anymore?
- Steps forreplacing my fuel injectors? VQ35 5.5 gen
- Engine oil weight
- Inner tie rod ends
- High idle- 2000 Maxima
- Attn everyone who "screwed up" their throttle body by cleaning it
- 2000 Key Security Transponder plug help
- 5th gen Gauge Cluster Problems
- another throw out bearing
- Need decent oil
- How to get rid of p1800 code after VIAS delete
- Transmission wires
- you guys still breaking poly mounts?
- any reason a 2002 knuckle woudn't fit a 2001?
- Nissan Maxima 2001
- New fan assembly running constantly
- Lost all my keys. Options?
- How to improve handling/control
- Thermostat Under Intake Manifold
- Mitsubishi logo on revolution sensor
- P1610 and P1612 codes
- Car kicked into limp mode
- New Here. Looking for a Smart Entrance Control Module for a 2000 Maxima
- 2003 Maxima 3rd Gear Slip
- Blowing motors
- Striking Rod Seal Replacement - How to Remove the Pin
- Cranks but no start
- Engine hot plus coolant leak
- Megan Racing OE-RS Muffler / Stillen front lip
- Wiring 2002 Factory Hid’s up to a 2000 SE
- Any possible gains from upgrading the fuel system?
- Both Cooling fans not kicking on low or hi
- Cleaning the Bose audio system
- Brake Shield/Baffle
- Aftermarket radio intermittently will not turn on
- P0720 High Revs with No Power Sudden Onset
- Just bought a 2001 Maxima/Infiniti I30 but its stuck in 3rd gear
- O2 Sim. Instead of a new o2 sensor?
- Car sat for 1 year. How do I flush stale gasoline?
- Moly coating inside the VQ engine
- Took the car on a 3k mile trip and it ran beautifully, except for a new p1448 code
- Blower Motor will not shut off
- Air bag light not coming on at all...
- No hot wires on the MAF sensors..?
- GAB throwing a code..?
- Oil Disptick Length
- Brake Pedal Stopper
- DTC P1336 solved!
- Need pictures of throttle body
- Engine knock solved
- P0300, unexplained misfires
- Regarding Bose Audio system
- Ac question
- 00 Maxima Blinking Check Engine light, and now won't start
- 02 maxima gutters and dies
- Will it work
- VIbration/thumping from front when off throttle.
- that rear wing for mpg
- 2K 5 speed in limp mode but no codes
- Infiniti i30 subframe bushings - front suspension
- 03 i35 slightly overheat at highway speed
- Exhaust flex pipe repair
- Need help with idle relearn procedure
- 2000 maxima abs and tcs off light blinking
- Intermittent starting issue
- Abs and Tcs off light flashing/blinking
- Loud click when shifting into D or R
- 01 maxima alternator not charging the batter
- 3.0 valve covers on 3.5
- What did you tow with your Maxima?
- Cooling fan and alternator go bad 2 days apart
- 5th generation “starts then dies”
- 2002 maxima- car is shaking
- Fuel gauge install
- 2000 Maxima SE Alternator interchange
- Head and tail light question
- Maxima/Cefiro (A33)- Erratic throttle at 1.5k RPM
- Odd "Misfire" After 3000rpm
- Help
- 2nd Gen 3.5 re ring/ upgrade + timing guides
- Crankshaft position sensor
- Trip Odometer Keeps Resetting On It's Own.
- Oil press gauge install
- Front Motor Mount 02 max
- Timing Issue Causes?
- Cabin A/C Filter: 1 piece?
- Bad Coolant Temp Sensor Causing Bucking?
- To cam or not to cam
- 13.4 to 13.7 too low running voltage?
- What is proper MAF reading
- A/C Controls Interchangeable?
- Previous issues solved with new programmed key
- ca smog test
- Help wwith a project
- Good Slave Cylinder Brand?
- P0300 on 2nd gen VQ
- Striking Rod Seal
- 5th gen 2001 knocks when I slow down
- Car won't start. Help!
- P1440 question
- How to find paint Color from VIN
- 2nd Gen DE Swap Questions
- why do some alternator parts listings exclude 2001 year?
- where to start? loses acceleration, abs and battery light flashing P0732 P0733
- Swap problems
- Vacuum hose size
- Mass air flow keeps going out
- 6 speed shifter height
- P1800 and P0455
- Engine
- No throttle response when pressing accelerator
- Gas/Brake/Clutch pedal “upgrade” options
- Scan tool?
- No longer able to open trunk with key fobs
- Need a new engine, but need to know how much newer I can go than just the 2003 model
- Time for refreshing
- 2002 Maxima with stock navigation
- Sunroof intermittently opens/closes. Venting buttons always work.
- Help Me Understand The Stock FPR
- Help needed: Manual tranny fill plug won't budge :(
- oil too high all the way to the top of the dip stick
- No spoiler?
- Rebuilt engine, issue with getting it to start, have P1320 code
- Replacing Motor Mounts - Auto w 267k miles
- Oh the Memories
- Hood alignment help
- 03 Maxima Gone But Not Fogoten.Forgotten
- One front wheel running warm
- Oil leaks and worn out belts
- Clunking noise in front end when turning
- 2002 Max GLE- Lf Front Speaker- Wires or Head Unit OR?
- What is causing my stalling issue?
- Need help to find ignition coil fuse or relay
- Rear caliper brkt design
- Maxima oil
- Drivers power window switch problem
- anyone familiar with wiring issues? like common harness issues?
- Engine making grinding/knocking noise
- Put in cheap plugs, now car dies after warmed up and won’t restart
- Trying to swap a 2010 motor in my Automatic 02 what parts do I need?
- new serpentine belt is bigger than one on car
- High beams killed engine?
- 6th gen axle set up
- No fuel pressure 2000 maxima trouble shooting
- 300zx calipers - opinions wanted
- Need help
- A/C recirculation only works when accelerating
- Power steering leaking onto 02 sensor
- Don't buy garbage Anchor motor mounts
- Lowering driver seat and keeping the stock seat
- Customizing
- Fluids
- 2 thermostats
- Square³ hole on block under air filter
- (pending) P0303 - Misfire cylinder #3 question...
- 2003 maxima - Bose radio questions
- Alternator lights on (brake/Battery) during cold starts. 11.9V. What else to check?
- 2003 maxima wiring issue
- 04 Bose radio problem
- Vq30de Rotate but no start ,
- P1491 and P0306 Help
- SE Stock-like coil spring recommendations requested
- Knock Sensor: Common Fail?
- Help! Need a part and cant find one anywhere!
- 2001 Bose system with no sound
- Cut and reweld rear lateral link
- VIAS spring jb weld necessary?
- new to this page need help
- p011 & p021
- Cooling fan assembly
- messy steering rack after boot leak
- Identify this sensor
- Dead window motor, cant reach bolts...
- 2000/2001 Maxima Engine Cover Screws
- Please Help! Rear Main Seal
- Ignition Coil Correct Resistance Readings
- Another 5.7 swap compete
- 2003 Nissan Maxima to 6th gen engine swap list
- 2001-AC clutch not engaging
- 18x8 245/40 or 255/40
- Trim levels
- Gabriel Ultra , not bad
- 2001 20th Anniversary with p1130 code help
- Vehicle feels unstable at interstate speeds. Rack and Pinion?
- Installing Factory Hid's on my 2000
- Any Good Builds?
- Maxima 2000i dle cazy and won't take idle relearn
- Oil leak / front cam cover / front valve cover
- Engine stalling at idle, but only when cold
- Where do IAT wires go?
- Replaced clutch and flywheel now car won't budge. Goes into gear without pressing clu
- 5th Gen Thrbody gaskets & metal intake piece?
- Crankshaft Position Sensor Connector Stuck
- Car stalling issues
- Tranny swap
- Piggyback tuning a 4'' intake
- Recommendation for wideband?
- Potential rim choice for my 5.5gen
- Horn/Alarm not working
- 2001 AE front lip
- Anyone else get the recall notice?
- Maxima is rattling and making loud noise
- Bought these headlights. What else do I need to install them?
- Flywheel Teeth Broken
- New to the forum and my 5th gen 2000 Maxima
- ISO: Stillen supercharger kit for my 2000 Max
- CV Axles boots split.
- Power Steering Pump, fitting or rack leak
- Best Valve Cover?
- Lower control arm bolt thread pitch size need to tap the hole as it’s stripped
- Can't fill the tank easily
- Nissan Maxima 2002 fans turn on but no power
- 6-Speed swap
- Bypass the governor help
- Transmission: Revs like Neutral in Drive
- Rattling: Timing chain?
- Unknown clutch noise
- Airbag diagnosis sensor unit Question
- Limp Mode
- Fuel door lid no longer flush?
- 2000 SE 5 speed flywheel question
- Shifting problem 2002 Maxima (96,000 miles)
- Voltage backfeed into under dash fuse block
- sensen struts
- 2004 Infiniti I35 wont shift to OD if it's cold outside
- Eventual muffler replacement
- Steering knuckle assembly
- Fuse box assembly
- will 2007-2008 seats fit in my 2001?
- 5Th Gen- power steering leak
- 00 Maxima 3.0l V6 Questions about issues it has...
- Idles out a lot
- Transmission woes
- 02 5.5 Doors won't stay open
- Door lock not working
- Searched, couldn't find info: Rear seat pass-through frame needed?
- Random no start, just clicks
- Do I need lower control arm bushings?
- Replaceing and painting hood
- Did the 3.5 Motor Have Major Reliability Problems?
- Takata recalls -- Disconnect module, never go off?
- 2000 Maxima: Help! I can't unlock my doors; not even manually with my own hands!
- i30 vs i30t headlight
- i30 vs maxima hood
- Alternator Problems
- Looking for an OE radiator core support
