How to rebuild vg30et
Hey guys I got a vg30et from a 88 300zx. It pulled out in 4 hours. Now here's what I got to work with. The engine block is fine it had a blown head gasket so one of the cylenders in the middle got sized up. The crank looks fine and all the berings on it are in good shape. Also there is nothing wrong with any of the rods. The Only problem it has are the piston sleeves and pistons. Do you think I should Keep the existing rods and crank or should I get different ones. Does anyone know if these factory rods can handle alot of boost? What do you guys suggest to do to make this work in my 91 gxe? Iv looked at the Oil pan of my engine and the turbo engine and they are flip floped. Im going to check and make sure when I put the mounting bolts on that it will fit in and have clearance. Im thinking about a jimmy wolf tech ecu and will get a bigger fuel pump. I will probably use the fuel injectors that are already on the turbo engine assuming they are working properly. Also do you think I should maybee use the engine block of my original vg30e and just add the turbo to that and go from there. I dont know how my crank pulley with three belt slots is going to hook up to the turbo engines crank pulley with only two slots. Does anybody know if this pulley is going to fit on a turbo crank? Or should I just buy a new crank for my max and put the oem rods on that and get new pistons?
Originally posted by jmrader
If your looking for a operating 300zx engine go to zcar.com and look in the classifieds parts and they are selling engines for 500.
Originally posted by Brave Ulysses
The whole point is to REBUILD the engine he already has in his possession.
look at the names, he (jmrader) is the one who has the engine; he was telling the other guy (kingrye) where to get a VGT
also, good luck with the project
from what I've heard, it's pretty simple and everything just bolts right in
Re: How to rebuild vg30et
since the Z31 manifolds and crossover bolt right onto the VG motor(with some inginuity(sp?)) in your Maxima thats all you need from the 300zx motor...trying to swap the VG30ET out of the Z into your Max is a waste IMO!!! of course the VGT has super low CR, but hell, 9:1 is perfect for boost. just strip down your Max's motor...have your rods "prepped", get some forged 9:1 pistons, figure in fuel/ignition management sysytems and go from there....screw trying swap in the VGT and relocating and rewiring everything, BAH!!!
Re: Re: How to rebuild vg30et
Originally posted by DA-MAX
BY GEORGE I THINK YOU'VE GOT IT!!
Re: Re: Re: How to rebuild vg30et
Originally posted by mykizism
hey da-max.. i already have everything figured out.. if you ever decide to boost your max again shoot me an email.
See the problem is money. The crank in my max engine is chood up at the main pulley and the keyway is stripped so the crank is no good. And the crank in the turbo engine is in great shape. I thought the turbo would already of had forged rods and crank, do you think I should use these rods and crank and put them in my max engine and just buy some new forged pistons? The turbo engine had 120k miles on it, but the rods and crank look fine...
if I'm correct the rods and crank in both the turbo VG and N/A VG are the same...both forged and both ready for boost excpet I think the pre-'89 VG crank has a shorter crank shaft snout.
just get yourself another VG crank and have it knife edged and shot peened(still not too sure what that is??
) get some forged pistons and I guess you can say theres your bottom end.
Why prep your rods (shot peen) when you can buy brand new eagle rods capable of supporting 750hp! Yours for only $420!!!.
Originally posted by jim90gxe
*sales pitch
*sales pitch
Re: Re: Re: Re: How to rebuild vg30et
Originally posted by male
I heard Eagle rods are crapola..to be avoided. Not my opinion, I have no 1st hand knowlege. But you get what you pay for you know. WHy are eagles so cheap compared to other provedn forged rods? I wonder....................
Thanks alot for the info male. Im going to go with the TT crank and rods. But should I use the VGT block or my N\A block to put back in my max? I will also go with bigger fuel injectors. I wana get as much horse power outa this ***** as I can and rip the tranny off.
ARRRRrrr. Just kidding. But you can imagine how much fun it would be. I wana be shootin for 300 hp in the future.
Re: Re: Re: Re: Re: How to rebuild vg30et
ummmmmmm, what are you talking about.....how much are the eagles compared to JE's??? I think without pins and rings they cost about the same.
Your thinking pistons
I just want to see him back up his claim with atleast 3 or 4 links.
AFAIK VE30depower and myself are the only ones on this board who actually have the rods and ve30depwr is the only one who has them installed..
Re: Re: Re: Re: Re: Re: How to rebuild vg30et
What happend to him? He put the engine together, said it wasn't running right, then disappeared. Did he get is motor going?
huh?
huh?
Re: Re: Re: Re: Re: Re: Re: How to rebuild vg30et
Re: Re: Re: Re: Re: Re: Re: Re: How to rebuild vg30et
I fear the worst. ie.. spent a wad and no go.
Did you give DanNY(the bargin stealer) a hard time when he bought the fuel pump?
He just disappeared. I sent him an email a while back but he hasn't answered.
Re: Re: Re: Re: Re: Re: Re: Re: Re: How to rebuild vg30et
you can smack me now.......
huh?
huh?
Originally posted by Dummy
hmm... i think j30_vg30et might disagree with you... currently running 17psi on his stock VG 9:1 comp.
2: 17 psi on 9:1!!!!! Is he running an IC or water injection...Race fuel? That seems an excessive. Has anyone verified this? Just seems crazy, as the vgt can barely touch 12psi with no IC or any other means of cooling, and that's at low compression. Check z31.com and search for posts on max boost levels for a stock (internal) VGT. Just stating what I have heard repeatedly from that site, and there are guys there that know every in and out of the VG motor.
That sounds like a hell of a way to go. I was looking at the JWT ECU and I will deffinately check on those 450sl benz injectors. You said a Master Air Flow sensor from a mustang cobra, and what kind of cams are good? I live in St. Louis.. Hard to find Max parts out here..
Those benz injectors won't work in your car they are top feed and a different style. You would need at the minumin 370cc or 550cc injectors. IF you are adventurous get a set of 50lb/hr MSD injectors and make a custom fuel rail. Then you get your ECU reprogrammed for boost and injectors. Stock MAF should be fine, no need for the cobra maf. Cams, your choices are ISKY, JWT, Motorsport auto.
j30_VG30et WAS running 17psi... last I heard, he'd blown the engine because his fuel pump failed and ran it lean.. then kaboom.
but before that, he was running 17psi full-time on pump gas.
custom built T4. big intercooler. 3" exhaust. all done by him.
AND he was getting over 30mpg.
Yeah, does anyone know what happened to Ve30de Power? I've tried contacting him but he disappeared. Last I talked to him, he was working out some fuel problems (sounded like he needed bigger injectors). I hope nothing bad happened like a blown engine!
Male, are you sure a VG33 block would work? That's something I casually looked into and considered. Though, I never really did enough research to find out. I was just planning on going with a Vg30et but, that would be even better to have a 3.3L turbo! I think I'm still going the vg30et route.
Does anyone have any good source for getting a JDM vg30et? I've been trying to find an '87+ JDM vg30et (I think it was after '87) because I believe those have 230hp stock. I might be thinking of '88-'89. 230hp would be a great base to start with.
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: How to rebuild vg30et
No but he was afraid that he was getting a non-maxima f/p kit. I had to brag the money outta his pocket. Hehe.
hey just making sure...it's not everyday u see one of those around..LOL
James92SE
142
Jan 2, 2024 09:23 AM
Apr 16, 2020 05:15 AM
Mar 12, 2020 12:06 AM
Pied
Sep 26, 2015 03:29 PM
