Hand brake light in ON all the time
Old Jul 17, 2002 | 10:26 AM
mipinc's Avatar
My hand brake light on 95 gxe is on all the time. The fluid level is ok, brake pads are in good condition, and I have played with hand brake switch which is just a piece of metal touching a single wire connector but no luck. I do not have abs. What can I do next to get rid of this light? Is there a way to reset this light?
Old Jul 17, 2002 | 10:36 AM
njmaxseltd's Avatar
Check to see if the float that signals the lioght to come on when your fluid is low is either stuck or broken.
Those are the only two things that will turn it on in your car. One of them is telling you something.....
Old Jul 17, 2002 | 11:03 AM
RastaManMax's Avatar
Re: Hand brake light in ON all the time
Do you notice that when you pull up on the e-brake that there is a very loose feeling, as though it's attached to nothing, before it starts pulling on the brakes? If this is the case, it happens to my friends Escort wagon and you may need to check the cable...
Old Jul 17, 2002 | 11:34 AM
mipinc's Avatar
Re: Re: Hand brake light in ON all the time
Hand brake as normal tension. It is not loose.
Old Jul 17, 2002 | 04:03 PM
Chunger's Avatar
My other car is a Hybrid
Re: Re: Re: Hand brake light in ON all the time
Low brake fluid or stuck sensor float like stated above...
Old Jul 17, 2002 | 04:36 PM
djPlayboy's Avatar
i had this same prob on a 5th gen i reseted my ecu and played with the ebrake handel while the battery was disconected. When i reconnected the battery every thing was fine
vingodine
45
May 21, 2016 12:46 PM
homeyclaus
Sep 3, 2015 06:15 PM
JMag90
Aug 25, 2015 09:17 AM
Samedi
Aug 13, 2015 04:05 PM
