Took My Max to the Track
I went up to Cicero, NY at 89 degrees and 60% humidity. The elevation up there is pretty high, i'm guessing since it is by Syracuse. Tell me what you guys think of the times. They were much slower than i thought but maybe it's due to elevation?
I have the same setup that is in my sig when i went there
Run 1
Reaction: .525
60ft: 2.374
ET @594ft: 9.105
1/8 ET: 9.714
1/8 MPH: 73.78
1/4 ET: 15.020
1/4 MPH: 93.50
Run2
Reaction: .835
60ft: 2.286
ET @594ft: 9.040
1/8 ET: 9.652
1/8 MPH: 73.42
1/4 ET: 15.002
1/4 MPH: 91.43
I have the same setup that is in my sig when i went thereRun 1
Reaction: .525
60ft: 2.374
ET @594ft: 9.105
1/8 ET: 9.714
1/8 MPH: 73.78
1/4 ET: 15.020
1/4 MPH: 93.50
Run2
Reaction: .835
60ft: 2.286
ET @594ft: 9.040
1/8 ET: 9.652
1/8 MPH: 73.42
1/4 ET: 15.002
1/4 MPH: 91.43
I found my 1st run slip (the others above are 2 and 3):
Reaction: .606
60ft: 2.397
ET @594ft: 9.151
1/8 ET: 9.760
1/8 MPH: 73.77
1/4 ET: 15.090
1/4 MPH: 92.24
Run 2 above (now run 3) I fell asleep at the line...after that I was done...would've beat the Firebird next to me if it wasn't for that
Reaction: .606
60ft: 2.397
ET @594ft: 9.151
1/8 ET: 9.760
1/8 MPH: 73.77
1/4 ET: 15.090
1/4 MPH: 92.24
Re: Took My Max to the Track
Re: Re: Took My Max to the Track
Originally posted by Aaron92SE
Cicero, NY is at 400 feet elevation. 400 feet isn't enough to make you run that slow. That altitude usually takes off about 1 tenth. So, something else is wrong. The 89 degrees is enough to make a few tenths of a difference over 50-60 degrees. So, now you should be running about 4 tenths slower than other Maxima's with those mods. BTW, what are other Maximas with your mods run in the 1/4 mile?
Re: Re: Re: Took My Max to the Track
Well, if I am running 4 tenths slower with the conditions I ran in, I should be at about 14.6, right? This around the time I was hoping to get. I do have the heavier 17" stockers on which might slow it down a bit. There are a couple of maxes that post really good times...like 14.8 for a bone stock SE 5spd and those with mods similar to mine are at 14.4-14.7 i believe. I never thought track conditions can have such a big impact on one's track times. If stock 5spds do 14.8-15.1 in the 1/4, I'm trying to figure out if my time is slow because of: 1) it's my 1st time to the track and am not experienced enough 2)track conditions 3)my car is just slow
Apr 16, 2020 05:15 AM
mkaresh
Mar 12, 2018 06:48 PM
magiconthetire
Oct 26, 2015 09:03 PM
