Wheel Hop
Re: Wheel Hop
Originally posted by DJalbNY
any of you lads (or lady's) have advice to help prevent wheel hop? i know better engine mounts are one (partial) solution but is there anything else i can do?
When I ran full tire pressure on my stock 15's with junk tires, I had horrible wheel hop in 1st and 2nd. When I started running with tire pressure at 25psi, the wheel hop disappeared.
Any of you auto guys experience any wheel hop??
Re: Re: Wheel Hop
Originally posted by The New CLIMAX
Motor mounts are the cheapest, but you can get a canadian or I30T tranny, with LSD, or a quaife LSD and that will reduce wheel hop
This isnt true. When I put in my Quaife I got MORE wheel hop. Must be bad harmonics.
Originally posted by Nealoc187
I drop my tire pressures if I get severe hop. Radius arms are the solution (or Poly motor mounts) but warpspeed hasn't put theirs into production yet.
Originally posted by Aaron92SE
If I experience absolutely no wheel hop at the track, will poly motor mounts help my track times at all? I've heard they will allow more HP to reach the wheels.
Originally posted by ericdwong
Launch it harder and it'll prolly hop.
I get so much wheel hop driving down the trak at Rockingham that my dash shaks and it turns on my winshield wipers.
This is very odd; my '92 SE-R never had any type of wheel hop at all. Always two well planted black marks.
If you guys are getting that much wheel hop that's not good, that's acutely slowing you down...what you need to do is keep your left foot on the clutch, and see if your car is about to have massive wheel hope, when it starts ... like u feel the first hop, press the clutch in some, not all the way just some, and slowly release it as your accelerate threw 1st gear...this should stop the car from any massive wheel hop
I mean if you dump the clutch at 4000 rpm what do u expect, yeah your going to get wheel hop...but if u launch that way u need to keep working the clutch and SLOWLY release it.
-ChRi§
-ChRi§
Oh gee... who said I have to dump the clutch at 4000rpm??
ALL I have to do is push it to the floor in second gear at 4000 RPM and the damn thing roasts the tires. Street or strip. 6speed HLSD equiped.
Originally posted by MaxSpeedSE
SR i that was to everyone not just you, i wasent trying to singel you out, i take it you have a 2002 maxima, becuase i said 6 speed....maybe all you need is a upgrade in rims..maybe bigger, maybe wider... if you dont already have some, if so then tires, 2002's are monsters
-ChRi§
-ChRi§
If you have to tap the clutch you are going to lose et as well.
Andy29
Sep 29, 2015 05:32 AM
