Dissapointed with My 2k2 Max brakes and AC
Originally posted by [maxi-overdose]
why do u need new rotors??.....get some nice brake pads will do the work right. cross drill doesnt do any good, it just makes the car look better...
Originally posted by samiam5345
I need new rotors because these are slightly warped, getting worse, and glazing from being undersized.
if so, everything is covered (even alignment) for the first 12k miles and first year....tell them to fix it under warranty
here is some good readings on rotors
http://forums.maxima.org/showthread....ighlight=rotor
and
AC works great
At first, I was disappointed to w/the AC on my 2K2 Max when the weather wasn't that warm and I had it only only briefly. Apparently, it takes a little while for it to cool down... once it gets going, it works REALLY well. I realized that one day when it was in the high 80s and low 90s outside...
Some on this forum have stated that if your AC came overcharged, it won't work well...
AC and brakes
The two problems I see with the AC are the poor air flow to the back of the car, and the auto temp. system doesn't seem to reflect the in car temperature very well. It feels like my 89 did a better job with the air flow.
I haven't had any problems with my brakes but I don't ride them very hard either.
Originally posted by 92 SE-R 02 SE
Damn, you must drive REALLY hard. I think the AC kicks *** and the brakes are ok for stock. MAybe just get some better pads...If you rotors are shot on a 2k02, you need to improve your driving, unless you are at a track school every week...
Well, the problems are first I live in traffic sh_thole NJ and I dont know the AC just plain sucks, I dont have the auto climate control system though.
ditto, manual controls here. I'm in H-town and even in 100 degree heat and very high humidity the AC does the job pretty well. Add to that the ridiculous rush hour traffic and you get yourself a pretty bad scenario.
have the thing checked, perhaps you have a leak or just need some topping off.
Originally posted by TimW
well, your 2k2 brakes are much better than 2k brakes.. warped? you sure the gorillas at the tire place\dealer didnt over torque the lugs?
Thats probably what happened, I did not think of that. Well I wont have them cut them and they sure are not going to replace them, how are the stillen slotted ones with the pads?
Originally posted by soundmike
The group buy doesn't include 2k2 rotors (slightly larger)
The A/C on my car works pretty good IMO. On really hot days it takes a little longer to cool down but once everything is cooled off (interior parts like dash and seats) it gets down right chilly. I can usually run the fan on the slowest setting and be quite comfy.
Brakes are great, I've got 17,000 miles on the car and no hint of warping. Car stops straight and fast.
I've been getting the tires rotated at the Nissan dealership and they claim to use a torque wrench when tightening the lug-nuts. The few times I've had trouble with warped rotors it usually turned out to be over-tightened lug-nuts or some kind of contamination on the rotors.
One thing I don't use is the tire dressing that's popular with a lot of people today. I don't have any proof but I think it does get on the pads and rotors when you wash the car. Maybe it has no effect on the brakes but I'd rather not take the chance. Brake jobs are expensive these days, especially on 4 wheel disc brake cars!
Re: AC works great
Stereodude
bbsitum
Sep 11, 2015 04:55 PM
