Need help on steering quesiton, please
My car has a power steering/steering column problem. It is ok to drive, but now i am noticing a kinda high pitched sound coming from the passenger side of the car. It is behind the oil tank kinda under the car almost, but I'm pretty sure its in the engine. Any idea what this noise is, and what If i can get rid of it myself??? thanks
Check the PS fluid resivour and make sure it isn't low on fluid. Also check the PS lines from the pump/resivour to make sure they haven't collapsed in on themselves. If all these check out then your PS pump might be dying.
Originally posted by Brendan
Actually it almost sounds like a vibration of two metals together towards the bottom back of the engine, it still has something to do with steering, could anything be hitting together??
I know a decent amount about cars, its not my fluid. Its a vibration sound of two metals hitting together when i turn my wheel any direction, it comes from behind the oil tank but almost under the car. It is not my resevoir or pump.
Does it only make the noise only when you turn the wheel, or does it always make a noise?
worldwiderecognized
Sep 30, 2015 01:16 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
