child saftey lock on shifter
my girlfriend has a '90 max and she has this little lever on the shifter that she has to push down so she can put the car in gear. i was wondering if there is anyway to get rid of the lock. i did do a search but i could not find anything.
thanks
thanks
Re: child saftey lock on shifter
thanks
thanks
It's not a child lock!
Children are not supposed to use the shifter anyway, so why the lock?
as thebull said, it's for emergency only, so you can take the shifter out of park into neutral so you can push it if the car can't be started. You should never have to use it under normal circumstances. Why does she has to push it to move the shifter? Pushing the big button on the side of the shifter (at the top of the shifter) should do it. That one's needed so that you can't accidentaly knock the shifter to another position (like into reverse while moving, etc.)
thanks
thanks
My car has been doing the same thing.I push the side button in and I cant get it out of park.I have to push in the emergency release at the bottom of the shifter to get it out of park.WTF? It just started this about a week ago.
Re: Re: child saftey lock on shifter
Check the switch that engages when you press the brake pedal and releases the shifter. It probably rests in peace.
Or if it is not the switch, then electromagnet that pulls the prong that blocks the shifter - one of those two.
ok so its not a child saftey lock, thats what she said it was. so what you guys are saying is thats its broke.
i also have this problem but what i've realized is that i only had this problem when i start the car in the morning. but i just let the car warm up for a min. or two (let the temp gauge go up a lil as well as letting the rpm go down to regular idle) and it works fine after that.
so in other words, let the car warm up a lil
Press the brakes, you should hear a click. This is the shift lock opening up so you can move the gear shift into drive. Turn on your headlights, go to the back of the car, if you see your tail lights on, fine..if not you have to replace the "tail light" fuse or the "brake light" fuse. If those fuses are fine, it could be the shift lock fuse as mentioned by egmitchell.
it's not a big deal.
Hey, I checked my fuses today and the shift lock fuse is OK but the tail lamp fuse was burned. I replaced the tail lamp fuse and it blew immediately. Could this fuse or short or whatever be the problem. Please help Im driving without brake lights AND the shifter is jacked up. Any ideas? Anyone?
I encountered a similar sounding issue on my '92 SE that was easily cured. It took about 10 minutes to perform the repair.
Sometimes the car wouldn't start unless 1) I jiggled the shifter a few times or 2) I pushed the release and moved the shifter into Neutral.
I also notice another annoying problem, when the car started and the shifter was moved to drive or reverse there was an excess delay before the transmission engaged. All these problems disappeared when I replaced the two small plastic linkage bushings that are referenced on this maxima forum. Total cost was about $6.00 for the parts.
One of the bushings was completely gone -- as in missing -- after 115K miles. Mr. Nissan parts man told me the bushings are super high wear out items on these cars. With worn or missing bushings, the shifter linkage has excess play causing these sort of problems.
--SAM
--SAM
Ok I finally broke down and did a search on this problem and it looks like the brake light switch, or the light panel in the trunk is the problem. My panel looks good and the wires are in good shape so my guess is that the switch under the dash is bad. Like I said I have no brake lights, the car cannot be shifted out of park without using the override switch on the console, and the fuse keeps blowing when I hit the brakes. I have to fix this or Im gonna end up making a $75 dollar donation to the state. The only problem I have is how to shoehorn my tubby butt under there to fix it. Wish me luck.
do you have a link on the shifter brushings replacement? also you're refering to a automatic right? cuz thats whut i have
--SAM
--SAM
Here are the part numbers for the two plastic bushings--
34552-D4000
34407-01E00
--SAM
Well I think I may have found my problem. The power side of the light bulb terminals for the brake lights melted down. The lead connectors on the bottom of the bulb were melted into the socket. I think a short caused this, so much for a simple switch. Even though I already replaced it anyway. Ill keep you all posted when I find out what the problem is.
HerpDerp1919
Sep 29, 2015 02:02 PM
Andy29
Sep 29, 2015 05:32 AM
atriuum
Sep 28, 2015 01:19 PM
