Thank You!!
Thank You!!
For all those of you who had posted messages regarding the Knock Sensor, Thank You. Your posts really helped me. My experience took about an hour but that was only because I had regular home use tools and not shop level tools. Once I got the bolt loose that holds the KS to the block, the rest took less than 15 minutes. I reset the ECU after I got done, No codes any more. Now my car definetly pulls stronger in the lower revs.
This coming weekend I will be replacing the fuel injectors. My car has 143K miles on it and I feel the idle is a little rough and its running too lean. Last time I had a Nissan tech hook up the Consult (Nissan diagnostic tool), whenever he increased the injector opening/closing timing interval, the engine would settle down and loose that slight murmur. That was when the car had 80K miles. I am thinking the injectors are up for replacement. I like to do preventative maintainence instead of repairs. I got the injectors at $75 a piece at www.partsbin.com
Let me know if you think otherwise or if you have had similar experience and you did something else pther than replacing the injectors.
Given the money of 6 injectors I would make sure I'd checked all the affordable stuff:fuel pressure and regulator, filter, cleaned iacv, throttle body, plugs, ignition coil packs, just to name a few. Also, to get to the left bank cylinders (by the firewall) will require removing the upper intake manifold - may as well replace it with a VI.
Originally posted by Umer95SE
...I just put in a brand new fuel filter a year ago. What is an IACV. I cleaned the throttle body a few months ago, replaced the plugs with NGKs this summer...
Dave
