going to the drag strip....racing gas..ok to use??
Old Aug 23, 2002 | 08:15 AM
infinitiblast's Avatar
A few of us will be hitting the drag strip tonight. Is it ok to run racing gas from the track, any known issues running it?? Or is it not worth the 3 dollars or so a gallon?
Old Aug 23, 2002 | 08:19 AM
BriGuyMax's Avatar
For your car there is no benefit at all. The high octane of racing gas is for reducing the likelyhood of detonation in very high performance engines and specifically engines that are TUNED to use racing gas.
Race Gas may actually hurt your car.
Old Aug 23, 2002 | 08:20 AM
Ramius83
But if you insist on using it, only put in about a gallon. Some peeps do this to richen the "regular" octane gas....
Old Aug 23, 2002 | 08:26 AM
Dave B's Avatar
Not DAVEB the parts guy
Re: going to the drag strip....racing gas..ok to use??
Absolutely not. Race gas is higher octane fuel which is used by cars pushing super high compressions due to turbos, SCs, nitrous, and high compression pistons. The Maxima has a relatively high compression for stock, but it's nothing that necessitates the use of 94+ octane. High octane fuel DOES NOT equal high performance. Higher octane fuels are more resistant to igniting. Why do high compression race motors and boosted cars run high octane fuel? To reduce detonation. Because the high octane fuel is more resistant to burn, it will not detonate under high compression like a lower octane fuel will.
YOU WILL RUN SLOWER WITH RACE GAS
High octane fuels also have high levels of lead (increases octane) which will burn out O2 sensors and clog cats. If you see a guy filling up with race fuel at the in his non-boosted with a internally stock motor, laugh because he knows nothing about performance.
Dave
Old Aug 23, 2002 | 08:37 AM
speedtrip's Avatar
If you have money to burn you could spend $5 on some off-the-shelf octane booster. It may help your car run better (not necessarily faster) if it has a sensitive knock sensor or if there is poor gas in your area. I notice that my max runs better on the occasions that I have used octane boosters.
Old Aug 23, 2002 | 12:03 PM
Dreizehn's Avatar
Re: Re: going to the drag strip....racing gas..ok to use??
Good thing nobody was looking...
Made this mistake last time at the track. Needed gas and didn't think much of it at the time. My times weren't even near average. Since then I've read a couple things about it including this thread. Wish I had read more about it before. Life is learning right?
Maxima_Joe
Nov 25, 2015 08:19 AM
VQ'ed
1/4 and 1/8 Mile Racing
Aug 30, 2015 05:32 PM
Maxima_Joe
Aug 27, 2015 12:01 AM
Xi MaX SC
Aug 7, 2015 08:47 AM
