Car door static annoying!!
I live in a dry area and everytime i get out of my car and reach over to the door pillar to close the door, I get a very unpleasant shock. I think it conditions me to fear touching my car door and I hate it!! I end up pushing and therfore smudging the window to close the door! Why do some cars do this and others dont (what causes it)? And what can I do to stop this annoyance?
how about this
Check this out
http://www.zapno.com.au/home.html
or
http://cartalk.cars.com/Columns/Arch...ctober/01.html
also this one
http://www.static-sol.com/articles/s...of%20my%20car?
and this one
http://homepages.pavilion.co.uk/jeremys/home.htm
and this one
http://www.pei.org/static/index.htm
That Yahoo is really useful!
or
also this one
and this one
and this one
Re: Car door static annoying!!
Re: how about this
Originally posted by GreenSE
Check this out
or
also this one
and this one
and this one
Check this out
or
also this one
and this one
and this one
Re: Re: Car door static annoying!!
Originally posted by pjalst
When that happens to me I just tap the door with the key before I touch it with my hand . That does the trick. Just a light tap.
I recently read on article on the static electricity problem. This wasn't just a problem with nissans (thank God), but n-e ways. The article was basically talking about the problems that can be created by the electric current, mainly how people go to gas stations with this electrical buildup and when they remove the gas cap (instead of touching the door) it creates the shock you're talking about and it mixes with the gas vapors and starts a fire. it was kind of a notice from the petroleum industry. So I try to touch the door or something metal when I get out of my car, I also don't get back in my car which is where some people go wrong also, and I don't use my cell phone at the gas station b/c of the same problem. Happy maxn
..what you have to do is have your passenger ground the car before YOU do. mwuhahaha.
have you ever seen static travel 4 inches to ground?!?! here in the desert. i swear i can lite **** on fire with the electrons i get off my car!!!
i shock myself quite a bit when i drive alone. thats exactly why i let my passengers get out first!
PEI
Although the part of the cellular phones is considered a hoax. I think there is an adultered version that talks about the cell phones and also something about women being more prone to these accidents.
What causes static electricity?
For our example, getting out of the car, it's friction. At the molecular level there is an exchange of electrons between the seat fabric and our cloths as we get out of the seat. Electrons are negative. So strong atomic structures gain electrons and become negatively charged. Weak atomic structures lose electrons and become positively charged.
Why do I get shocked?
Humans are static sponges. As the friction occurs between the seat and our cloths a charge is formed. This charge is then absorbed by our body. Since our body is not grounded and is covered by an insulator (cloths, shoes) this static charge keeps building. When our body comes in contact with ground (metal door) the static charge is discharged and we get zapped.
Why are some cars worse than other?
Seat material, specifically composition and texture. Seat fibers with alot of nylon and polyester will create alot of static. Conversely if a manufacturer substitutes other material instead of nylon and polyester the propensity to create static is less. Leather is much smoother than cloth seats so there is less friction. Less friction means less static. Now the cloths we wear also influence the static charge immensely. Cotton is the best choice to reduce static charges. Wool or synthetic materials are the worst.
How can I stop getting zapped or lessen the effect?
The suggestions up to this point all work. Fabric softner works but keep in mind this is just coating the seat fibers. All coatings wear off. How often you have to spray your seats will have to be deterimed by you. Touching metal before you start to leave your seat and maintaining contact as you get out is the best way. This way your body is in constant contact with ground and there is no chance of a static charge building. Now lets say you forget to do this and your looking to bite the static bullet. Use your elbow or the heel of your hand to close the door. This displaces the static discharge over a larger surface area. When you reach out with your fingers and go to touch the door a very large static charge is heading for a very small, focused point, your fingertips. Visable static discharges are in the area of 30,000 volts and can go much higher.
Originally posted by speedtrip
It's a little early but here is my once a year explanation of why we get shocked and how to lessen or avoid it. I deal with static elimination in all enviroments, industrial to clean rooms.
Originally posted by atljade
There's still a possibility of getting shocked then when you have tint.
Also, I have leather seats and still get shocked even during the summer. Don't think Scothguard is the answer in this case. The key thing is great, but I can even feel a shock from the key, only less severe. I've just learned to live with it (it happens in every car I get out of) and chalk it up to my electric personallity.
Lakersallday24
Jun 16, 2019 01:35 AM
King_Ten_Ahead
Sep 30, 2015 04:27 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
