underbody glow kits
Old Sep 8, 2002 | 08:43 PM
LeonBlackMax's Avatar
underbody glow kits
How hard are these to install? I wanna put a green one under my max and they are pretty cheap off ebay.
Old Sep 8, 2002 | 09:10 PM
nadir_s's Avatar
vicodin ... gift of life
They aren't too hard to install. You just want to know where you want to install it, and you just drill them into the under body frame.
Wiring is quite simple. Just run the wire underneath the car, under the hood, and through the firewall and make a simple circuit. Underglow lights -> switch -> battery.
good luck
Old Sep 8, 2002 | 09:52 PM
BippuBenji's Avatar
What ever you do, get a Street Glow Gold Series kit. It'll last you much longer then any other kit, especially those cheap LiteGlow/LowGlow kits, take it from me. I actually posted a online site where you can get them for $139.99 + S&H.
http://forums.maxima.org/showthread....hreadid=146997
Old Sep 9, 2002 | 04:09 AM
purmax's Avatar
yes, go with streetglow, I have 2 Underbody Kits, going on 3 years, the only problem is I keep takin the car off-road and breaking the 2 lights in the front. But the other 6 are still bright as when they were new.
Old Sep 9, 2002 | 04:31 AM
metallic97gxe's Avatar
Master Will
just read the installation directiosn real good and you will be ok I have a white street glow gold series kit and street glow is the best.....!!!!!!
Old Sep 9, 2002 | 10:19 AM
Igor911's Avatar
I installed my friends lights on his camery! Took us about 1.5hr or so. Very straight forward install.
Have Fun!
Old Sep 9, 2002 | 11:27 AM
MaxKlinger's Avatar
good luck
Don't forget a FUSE!!!!!! I put a fuse on everything I do, if you get a short without a fuse your car may be toast...
Old Sep 9, 2002 | 12:06 PM
BippuBenji's Avatar
good luck
Easier said than done. Sometimes, the wires coming from the tubes aren't long enough to run all the way around and up into the engine bay. Also, mounting the power switch isn't that easy, but all in all, you have the right idea.
Apr 16, 2020 05:15 AM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
Pied
Sep 26, 2015 03:29 PM
