torque for springs/strut bolts
does anybody know the proper torque for the bolts on the front and rear springs/struts? i'm planning to install some h&r springs and wanted to make sure that the install people torqued the bolts back on correctly.
Front
Top 3 bolts should be 32-38ft lbs of torque
Bottom two on the strut should be 130-139ft lbs.
Rear
Top 2 bolts should be 18-25ft lbs
Bottom bolt on the strut should be 80-94ft lbs
Your welcome
Dixit
Rear
Your welcome
Dixit
Originally posted by nick778
Are you sure about those bottom front strut bolts. i was under the impression, the mid-range torque spec was about 107 lbs. Did you get this from a service manual? If so, what year? Thanks....
Dixit
Originally posted by BigDogJonx
Front
Rear
Your welcome
Dixit
Front
Rear
Your welcome
Dixit
Originally posted by MAXRAY
thanks. but what about the center bolts?
Front center strut bolt at the top
44-65ft lbs
Rear Center strut bolt at the top
15-18ft lbs
Dixit
Damn partner, you looking for everything.......
44-65ft lbs
15-18ft lbs
Dixit
44-65ft lbs
15-18ft lbs
Dixit
litch
123
Jan 4, 2024 07:01 PM
knight_yyz
Nov 1, 2015 01:34 PM
RealityCheck
Oct 2, 2015 06:34 PM
