Benefit of steel lines and Slotted rotors?
Originally posted by Pappa Grande
Whats the primary benefit of steel brake lines and slotted rotors over stock?
thanks,
PG
thanks,
PG
Slotted rotors are mainly for looks. Old(er) organic type brake pads will outgas when used hard. This could cause brake fade as the gas will get in the way of the pad and the rotor. Crossdrilled rotors were invented to help the outgassing, but they have a tency to crack over time. so slotted is sort of the compromise. But most modern pads do not outgas... so now they are mainly for looks.
-Shing
The steel brake lines don't expand such as OEM there is
a stiffer pedal feeling, SLotted or Xdrilled rotors allow for them to cool faster, but many will say that we don't use our brakes to that extreme where it benefits, but her they look nice.
Re: The steel brake lines don't expand such as OEM there is
"In racing, crossdrilling was designed to alleviate a problem known as out-gassing. In some of the older pad compounds, when the pads reached elevated temperatures consistent with performance or racing use, the binder (that’s the material that holds the friction material in place) boiled off, producing a gas. This gas would build up between the rotor and the brake pad, effectively keeping the pad from directly contacting the rotor. The holes provide a relief path for these gasses, as do slots, so the pad can once again contact the rotor. Crossdrilling was <b>NOT</b> designed to facilitate <b>cooling</b>."
-Shing
Re: Re: The steel brake lines don't expand such as OEM there is
yup what he said.
Originally posted by Shingles
x-drilling is not meant for cooling... check out this sections from Baer's FAQ... Baer's does brakes and only brakes and has been doing it for a long time...
-Shing
-Shing
Re: My stainless lines are great.
Originally posted by Whitemax
one of the BEST upgrades you can do.
-Shing
Originally posted by JDwyer2821
My girl just got those ceramic brake rotors put on her bmw rear and front. I never heard of them before that. I still really dont know much about them.
Everyone thinks it's aluminum,
But it's actually Krylon white spraypaint. Someone on EBay was selling aluminum bezel templates that attact with double sided tape for like $30. There was a group deal a couple months ago. Thanks though. I was bored one night and just popped it out of the guage pod and went to town...
Re: Re: Hey White Max
Re: Re: Re: Hey White Max
Maybe the pads have ceramic in them. Ceramic rotors would probably cost what $10 grand?
Originally posted by got rice?
you 100% sure they're ceramic? if they are, your girl is frickin loaded to blow that much on rotors! (for a street car)
Re: Re: Re: Re: Hey White Max
If not more.. cermaic rotors are only used by the likes of F1, BTCC, CART etc... mega dollars...
-Shing
-Shing
Apr 16, 2020 05:15 AM
doctorpullit
Dec 12, 2015 09:39 AM
