breaks squeek first couple minutes, then are fine...anyone know why??
I have brembo dimplled/slotted zinc coated rotors which are 2months old...after about a month after I got the rotors & new Nissan Oem pads...when I would start driving the car afer its been parked for a while(like overnight) the breaks squeeked for a short time (like 2 street blocks) and then are very quiet.
I see some rusting occuring on these rotors every morning as well... can it be that the rusting is causing the squeek and then after the pads shave off the rust it stopps squeeking??
anything i can do for this problem??
Re: breaks squeek first couple minutes, then are fine...anyone know why??
Re: Re: breaks squeek first couple minutes, then are fine...anyone know why??
Originally posted by Stephen Max
I've got the same setup as you and I have the same squeeking. I think it's just the rust buildup.
spray some water on the rotors..WHEN THEY ARE COMPLETELY COOLED..and then let them dry. NOtice how quickly rust will develop. Your first braking should be real noisy until the rust is all cleaned off.
You can't help the rusting unless you have a humidity controlled garage or something ridiculous like that
But if they're zinc coated, they shouldn't rust??
Does this happen to you during summer also?
Re: Re: Re: breaks squeek first couple minutes, then are fine...anyone know why??
oh really?
oh really?
i have the same problem with different pads/rotors, it usually only happens until the car has warmed up, then it's fine. Also, i only noticed the rust happening once i got rim cleaner on them, before that they were nice and shiny and fine.
hayne
Oct 5, 2015 11:53 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
